Results 1 to 21 of 21
Thread: Idea for a E32 / E34 Cup Holder
    Apr 2009
    Nevada
    01 Audi S8
    I was disappointed with the choices of cup holders available
    and tired of wedging drinks in between the seat/center console
    or holding it between my legs
    so I took a cup holder I had left over from a E34 I once owned
    took it apart and fabricated a piece to wedge in the center console pocket
    (the top piece are just glued on the base)
    edged the sides with a table grinder (don't take too much off, you want it to wedge tightly)
    I also had a travel mug laying around to use
    and it fits perfectly
    of course you can position it where you like,
    keep in mind if you want it in the center don't grind off as much plastic so it will fit tighter
    Feb 2008
    Calgary, AB, Canada
    BMW 850, Alpina B10 Biturbo, Alpina B12 5.0
    Nicely done!
    The kids:
    Alpinas: 91 E34 B10 Biturbo; 91 E32 B12 5.0; 91 E34 B10 3.0 Allrad (mom's car); '91 B10 3.5
    Bimmers: 91 E31 850; 93 E34 525i w/ aftermarket turbo; '01 X5 4.4; 93 E31 850i Dinan TT; 89 E32 750il Dinan TT; 92 750il w/ S70 engine and transmission
    Mercedes: 92 600sel; 93 S600 Lorinser
    VW: 04 Jetta GLS TDI
    Apr 2009
    Nevada
    01 Audi S8
    Jan 2006
    Ocala, FL
    99 540iT
    Nice work. Didn't you like the e34 dual cupholder? That should have also worked as-is in the e32.
    99 540iT - Merlot Truckster (TCG done 134k, might sell...)
    00 528i/5 - Grüen Arrow (sold)
    93 740i - Grün Hornet (sold)
    00 740iL (R.I.P.)
    Feb 2008
    Calgary, AB, Canada
    Totally! I use the cup holder that you have in the first pic as it is basically the only cost effective solution. Did you make the new holder all from the original holder or did you need extra material?
    The kids:
    Apr 2009
    Nevada
    01 Audi S8
    Quote Originally Posted by ndz View Post
    Didn't like how it looked there
    it scratches the top surface of console
    and it flips over if you take a turn too quick
    Quote Originally Posted by cdnalpina View Post
    Used nothing but the original holder for material
    I think my design blends in better with my interior
    and doesn't interfere with leg room when adjusting seat
    this was the E34 I had before
    Having the cup wedge in the center gave me the idea
    the way I have it now, I can fit other size cups
    (well within reason of course, no 64 ouncers)
    Last edited by Bimmerman4ever; 09-21-2010 at 04:04 PM. Reason: Automerged Doublepost
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I have the one from Herb since several years (seller name herb460 on Ebay)
    I know it is not the super best looking, but very practicable. Herb owns an E32 and E34 and had his own ideas realized, produces them as a hobby in his own shop.
    It holds even larger bottles, and the tray is good for my wife, because before she always put the keys and phone on the wood console=scratches. No glueing or bolt necessary. In case the console is leather, then it fits very tight. Just push it into the console.
    Brantford ON Canada
    735iL - 1989
    I use the 82 11 1 468 721 cup holder as shown in photo 1.
    With a #8 x 3/4" self-tapping screw through the vertical tab to secure it in place. It's solid, and easy to remove when necessary.
    Apr 2009
    Nevada
    01 Audi S8
    Quote Originally Posted by E32FAN View Post
    I really didn't want to screw in anything, if I wanted to remove in the future
    or if there is a future owner
    neither liked the big gap of burl near the shift console
    so I took a insert rubber piece from a GM car from the junk yard
    and trimmed it to fit
    It's held in pretty well since it's wedged somewhat
    and I cleaned the bottom with alcohol so it wont slide
    (no adhesives or velcro are necessary)
    I can set my cell phone there with no worries of scratching or it sliding around
    Jan 2006
    Ocala, FL
    99 540iT
    As shogun mentioned, I can attest that Herbs cupholder is VERY tight in leather consoles. I wanted to use it part time on road trips but found it way too tight to be put in and out frequently. It was a quality product but didn't fit my needs.
    00 740iL (R.I.P.)
    Jan 2005
    Japan
    just grind off a bit on the outer side, then it will fit also with leather perfect, emery paper will do.
    Apr 2009
    Nevada
    01 Audi S8
    Understandable. I'm primary the only person in the car so a simple, single cup holder solution seemed like the best option.
    If there is a passenger they're not preoccupied with the task of driving so I feel their hand is the best cup holder accessory that's always available.
    I decided to trim the fat off the rubber insert piece I had to lay my cell phone on. I held it in place with silicone because it will be easier to remove at a later date.
    Muswellbrook, NSW
    1995 BMW 530i Sedan
    Quote Originally Posted by Bimmerman4ever View Post
    More info on this install please.... Mines RHD so I need to fab up something like that!!
    Vancouver, B.C., Canada
    750iL
    I used to just squeeze drinks into that slot on my E34, no cup holders required. I don't think anything ever spilled, either.
    Brantford ON Canada
    735iL - 1989
    I understand the reluctance to drill a hole for a screw to secure the cupholder, because it might put off the next owner.
    However, appreciate that your car is now VERY OLD, and the next owner is probably going to be a scrap yard.
    So, I'm thinking, it's probably OK to do it "your way" from now on . . .
    Apr 2009
    Nevada
    01 Audi S8
    I had two pieces I screwed to each other then wedged it in
    no longer have the car
    have a BMW motorcycle now
    no cup holders, but it does have a stereo
    Anacortes,WA
    E34 535i; E36 325is
    My son has an E28 with a wire bottle holder from a bicycle that hangs of passenger side of the center console next to the shift lever. Anodized paint looks good, right size, works well, holds cup or bottle securely, inexpensive.
    Apr 2009
    Nevada
    01 Audi S8
    Jan 2005
    Japan
    Ultimate Cup Holder also hold 40oz insulated Hydro Flasks and also fits E32 http://www.ultimatecupholders.com/
    seller claims:
    A practical cup holder designed for the real world by an owner who actually drives the cars and uses the holders
    The ONLY cupholder that doesn't take any useable space or restrict any typical functions of your car.
    Out of the way and inconspicuous (more so in actual use than shown).
    Easy, slip-in installation and removal.
    Requires absolutely no modification or alteration to your vehicle.
    Apr 2009
    Nevada
    01 Audi S8
    E39 cup holder
    Quote Originally Posted by shogun View Post
    seller claims:
    I ended up getting an E38 then later an E39. I found the E39 cup holder that sells on Amazon works well in the E38 as well. Unfortunately the E32 is set up differently
    Jul 2011
    Western Pennsylvania
    335i 328i, 535xit, ++
    Sadly, the BMW cupholder accessory 82111468721 seems to be NLA.
    Current BMWs: 14 total. '12 X5, '09 E93 335i, '09 E91 328i, '08 E93 328i, '08 E61 535ix '02 E39 M5, '01 E39 M5, '02 E39 touring, '91 E34 M5, (2)'88 E28 M5s, '75 2002, 74 2002,
    Prior BMWs: Every E-body 5 series including tourings and every E-body 3 series. '74 2002 tii
    First rule of BMW Ownership: Buy a BMW specific scanner!
