I apologize if this is in the wrong section but I didn't want to make multiple threads for each item...
I have the following up for sale:
325 rear subframe acid brushed, 3 coats primer and 4 coats of VHT rollbar/chassis paint. New IE street poly subframe bushings pressed in and also new in the bag IE poly rtab's. Also included is are the new in bag IE sway billet/poly rear sway reinforcement kit.
Looking to get $300 for everything as a package picked up in.
I also have 2 M coupe mufflers, still for sale 2.75" inlet and dual staggered polish tips outlet. $100 for pair won't split.
Two e30 14" bbs center caps one good locking $29 shipped, the other has one lock tab broken $20 shipped
I will have my complete m50 nv swap for sale in a few weeks already wired for e30 (318is) with accessories/maf/ecu/e34 pan PM if interested offers. I have compression test numbers. Also included will be supersprint replica headers with SPD merge dual 2" to single 3" v-band all tig'd by the one and only Jon Volk. Has 6 brand new coil packs/boots/plugs new gaskets and painted block. Ready to drop in.
Picking up an m52 so this stuff must go.
I'd buy that from you if I could, but the female financial committee disapproves.
What kind of price on the Motor package, nothing is listed.
D
Phil the trick is purchase on the DL then admit you've been a bad boy after she's had a few drinks.
Details on the swap after I pull it, gauging interest for now
Ttt
part the... new in bag IE sway billet/poly rear sway reinforcement kit?
Instructor - NASA MidAtlantic, Chump - Racer
Team Constitutionalists Racing LIFE-LIBERTY-BEER
Subframe and rtab's and mufflers sold. Bump. I have a ton of m52 stuff obd2 harness, ecu, maf, knock sensors, 328is oil pan/pick up. Pink top 21.5# injectors. Let me know if you need anything!
