Progman can't read vehicle order. I'm trying a BMW 120d 187 08/2007.
1. New session
2. Interface
--> Interface name: OPS1
--> Version: 6.21
--> IP address: 192.168.68.1
--> External interface: x
3. Continue
4. Description: Test
5. Continue
6. 1 Series
7. E81/E82/E87/E88
8. Progman session is being started
9. The vehicle order (VO) is being determined.
an then...
It is necessary to use OP(P)S/ICOM for the connected vehicle for programming/coding control modules. For this purpose, you must close the Progman session and select one of the requested interfaces.
Administration/Settings/Overview
- Operating status: usable
- Sessions: 0/5
- Version: 32.0.0
- SSS_name: SSS_OEM
- IP address: 192.168.68.30
Administration/Settings/Network
- SSS name (old): SSS_OEM
- MAC addrsss: my MAC address
- SSS name (new): SSS_OEM
- Gateway: blank
- IP subnet mask: 255.255.255.0
Administration/Connection test
The connection test for the IP address 192.168.68.1 was successful.
My Interface
- BMW INPA / Ediabas K+DCAN USB Interface
- Ediabas/Inpa
- GT1
- Progman
- SSS
- etc.
- High-speed D-CAN und PT-CAN (500 kbit/s)
- Low-speed K-CAN (100 kbit/s)
- Standard BMW ports (BMW-OBD-interface)
Link: http://www.doitauto.de (1541)
Can someone help me?
regards
If you are using USB K+D CAN then shouldn't update to changesv2. I have same cable, fixed it by mounting changes.iso size[284 KB] and updating again. Let me know if you get a click able CKM option once you pass this stage .
I havn't changes.iso 284kb. I need a download link.
you need special patch to work with Progman w/o OPPS head for a new cars
this require DB update as well
which special Patch? can you tell me more?
Hello
I have this problem. I have v32 progman inpa cable. E46 works with e91 but it is not. What do I need to configure it to work?
Hi , please can you tell me how to add and connect with my DK yellow head in SSS vmware,in the new session because there are only interface with IP 192.168.68.1 OPS1 and i don't have this.
Best regards
