So, car doesn't unlock with remote..However it does lock, does open the trunk, does start. Even when i press the unlock button next to the dtc from the inside it will not unlock. Has anyone had this problem before?
I had a problem where my key didnt do anything but start the car (I had to use the actual key part to unlock and lock my doors), used my backup key for a while, then I took the defective one to the dealer and it took them couple minutes to reprogram it and it worked again.
Blown fuse and/or bad actuator. Had to take mine into the dealer to fix it and they replaced the fuse with a higher amp fuse and replaced the front door actuators.
So I replaced the fuse but switched it with the same amp level (15) and all doors open except for passenger. However, it does open from the inside when u pull the handle twice! If anyone ever has this problem its fairly easy to replace the fuse ...Fuse number 57
Replace the fuse with a 20 AMP (that's what we do when we do the repair at the dealer) and then test the locking system with the interior switch 10 times at 5 second intervals, if one of the actuators in the front still doesn't work, there's a kit you can buy to replace both actuators.
Pulling the handle twice to unlock the door is how they are supposed to unlock manually from the inside.
I just had this problem last night. I purchased a 20 AMP fuse and replaced FUSE #57. Drove the car for a block and everything works fine.
Hey guys, so about a week ago i noticed that when pressing the lock/unlock buttons on my remote entry only the driver door would react, now as of yesterday, i have to use my actual key to unlock the door, but the remote will lock the driver door. and i cant open my back doors at all. the button on the center consol will only lock my driver door and do nothing else. PLEASE HELP!!! It is a 2006 325i 6 speed manual.
Check the fuses. If that's not it, maybe bad actuator(s). Common issue on these cars unfortunately.
Current Car (delivered 20/10/21): 2021 G80 M3; 6MT; DravitGrau/Kyalami Orange/Black Extended Merino; Permium Pkg (ZPP); 826M bicolor wheels; Black M Compound brakes; Sunroof (yes no CF roof)
(more pictures here)
Previous Cars: 2018 F30 340ix 6MT Msport(Dec 2017 - Sep 2021); 2013 F30 335ix 6MT Msport (Nov 2013-17); 2011 e90 328i 6MT ZSP (Aug 10-Nov 13); 07 e90-323i ZSP (May 07 - Aug 10); 97-318ti ZSP (Feb 97 - May 07)
"Mit der Dummheit kämpfen Götter selbst vergebens", Friedrich von Schiller -- "Life is simple, people make it complicated", Me (About me)
i just picked up my car from the dealership. Took it on friday after my doors wouldn't open from the inside or outside. Unlock button wouldn't work on key or in car. They replaced the actuators and fuse 57. Also my idrive is gray now not green anymore (they reprogrammed the car because of a restraint system malfunction but im not sure if the idrive has anything to do with the locks.. so just bring it in to the dealership...if your under warranty they fix it free...good luck
Does GM5 sound familiar to anyone, i was told that it might be that
Use the key!!!!!
I had the same issue reported above - the key would lock the doors and unlock the trunk, but would not unlock any door. Had to use the physical key to get in. And for me, I could not open the passenger door from the inside (this seems more than a bit unsafe).
Anyway, replaced fuse 57 as described, and it works great. Thanks!!!!
