Ok, after fixing the disa seal intake seal leak and replacing the fuel filter (made a huge difference) I feel more confident in the engine being able to perform. The issue now is if I floor it in first gear at 1300 rpms it almost feels like turbo lag, cuts out for half a second followed by a sudden burst of power....
What are your thoughts? Vanos seal or camshaft sensor?
Is this all the time or periodically? Cause I wanna say camshaft sensor...
Now they dropping and yelling, it's a tad too late, Nate K and Rayzah Blade had to regulate.
"A woman drove me to drink and I didn't even thank her." ~W.C. Fields
Two tone leather boots, CF B&R emblems, Matte Black Grills, Smoked LED sidemarkers, CF interior layout, Suwoo highbeam bowls
Rooted Droid2 running stock overclocked to 600 MHz
I actually have a similar problem. Mine does pretty much the same. Starting in first gear it seems like it stumbles when floored at low RPM and then surges. I always thought it was either a fuel problem or some kind of vacuum leak. Do you have any other symptoms or anything else that you thought was a bit out of place with your car? That might help the diagnosis.
VANOS would be rough idle/hiccups at low RPMs... I think its camshaft sensor
Jet, you got VANOS problems I think
UPDATE: New VANOS seals fixed the issue.
