Found these on the garage floor while doing some cleaning, used to have them on the "is" before it was sabatoged. A pair of m52/s52 OBDII exhaust manifolds converted for OBDI use.
This is an OEM BMW part which is a good upgrade for OBDI cars. You know the rules race track use only, NO I WILL NOT PAY YOUR LOUD EXHAUST TICKET OR ANYTHING LIKE THAT!
I powder coated them with a hi-temp silver and plugged up the OBDII hole. If you want, I do have my back up set which is un-coated, you can pick between silver, black and gray.
75 + shipping
For an addition 15 dollars I will through in the bung and a used o2 sensor for those of you who like your gauges.
bump
are the studs still intact and not broken? so the 02 holes are plugged up and the channel are weld shut, right?
