I have '99 M3 and this is the first time since I bought the car I'm replacing brake pad and rotors (all 4). Do I also need to replace the brake pad sensor too?
1999 Tit Silver ///M3
www.racepad.com under tech has a write up.
You need a 7mm short hex driver.
Peter Hsu
You dont need to if you can carefully take them out without breaking the ceramic. There only about $10 ea and all you need is 2 so u might as well order them.
sensors:
The racepad instuctions are dead on, except the part about using a screwdriver to remove the sensors. I had a tough time with this, and just used needle nose pliers. Worked great and preserved the sensor.
In the slow lane
For some reason I thought there are 4 sensor.Originally posted by C///M3
Should I bother saying no there are only 2 sensors?
They assume the two sides will wear evenly. So thus one for the left front and right rear.
Peter Hsu
What pad/rotors are you going to use?
SOLD: '96 Artic Silver M3/2 Lux Click here for pic's. 2003 X5 4.6is: Nav, loading floor, comfort seats
2007 E90 335i: Titanium Silver/Black/Aluminum trim, Sport, Premium, Heated seats (for the wife), iPOD, MORR VS7
2011 E92 M3: Space Grey/Black/Blue aluminum trim, Premium, iDrive, DCT
