Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 59
Thread: Best Fuel Grade to use in 1991 850i
  1. #26
    Aug 2009
    St. Louis MO.
    1991 850Ci
    I read the octane posts and chose to start using 87 and I had problems with my car going into limp mode in the mornings. So of course I was told to rebuild the DK's so I got some from Tom. While waiting for the motors I decided to run some 93 octane and my car has not started up in limp mode since. So I still haven't installed the new DK's after being told that only having 60,000 on my 8, they were probably fine.
    So anyway no tech talk here just some info from experience.
  2. #27
    Oct 2007
    Calgary, AB - Canada
    1991 BMW 850i
    A side note to this, not sure if related or not at this point. I had the 8 out this weekend for a long road trip and ended up having to fill with 91, as the station was out of 87. Immediately following this, the 8 ran a needle width tick above 12 o' clock while before it was a needle width below as per normal.
    ___________________________________
    1991 Mauritius Blue BMW 850i, J-Spec
  3. #28
    Mar 2011
    Damascus, Maryland USA
    E31/E32 VWs Tesla
    Quote Originally Posted by wokke View Post
    Running 10% Ethanol is not a problem at all. I've been running 85% in my E31850, E34-540 as well as E39-520 and E39-523. The only problem has been poor idle for the first few minutes due to the 30% lower energy content of Ethanol compared to gasoline.
    Wokke--
    Do you still run E85? Does it run well in your car?
    Being a higher octane equivalent, have you found it to be worthwhile? Does the E85 'clean' out your engine/injectors?
    Do the Wokke chips impact the ability to run E85? Are there any other considerations?
    I usually always run 87 octane, but every 5-6th fill up (or If I have full load of stuff, climbing a lot of hills, etc) I'll use 89 and once in a blue-moon, Shell 93 (differential price is cheaper than a pint of injector cleaner)
    '89 735i, '91 850i, '81 MB 380SLC (For Sale), Tesla Model 3, and VW Passat TDI -- Yes, I still repair General Modules, DM for info!
  4. #29
    Duesseldorf, NRW, Germany
    '90 850iM70B54, '91 850i
    Quote Originally Posted by EEDegreeToDrive View Post
    Wokke--
    No, I'm not running E85 anymore. The last time my engine ran like shit. Although from the same gas station it appeared to be of much much lower quality that what I used before. I actually had to cheat the DMEs via the water temp sensor to tell them that the engine is ice cold in order to get enough fuel into the cylinders. Due to the much higher fuel consumption (E85 has about 30% less energy per volume) it also didn't make any worth while difference in my wallet. I even tried different chips with 5° more pre ignition but didn't help. So I can't recommend it although the engine runs quite a bit smoother on E85.
  5. #30
    Sep 2011
    Saudi Arabia
    See my signature
    I enjoyed the back and forth on this thread. For me unfortunately in Saudi Arabia, we only have the choice of 91 or 95 (in Dubai its 95 or 98), but lucky for me gas is only 60 cents a gallon for 95 and 91 is 40 cents a gallon
  6. #31
    United States Of America
    997tt,850,02m5,w140 s500
    WOW, those are amazing gas prices! . lol... 98 in dubai, really?
  7. #32
    Sep 2011
    Saudi Arabia
    See my signature
    yup 98 in dubai for like AED1.60 a liter which is like $0.40 so if u figure 4 liters to a gallon then its like saying $1.60 for a gallon of 98 octane
  8. #33
    Nov 2008
    Maryland
    not enough
    Quote Originally Posted by Racer MXM View Post
    WTF! Unreal!
    Lucky man
    CB42366 - 1991 850i 6-speed. Brilliantrot & Black Nappa Leather
    CD00144 - 1994 850CSi. Hellrot & Black Nappa Leather
    My other projects:
    Supercharged Tbirds, V8 Tbirds, V8 Mustang Convertible, Audi V8 Quattro & Audi S8
  9. #34
    Sydney, Australia
    1997 840Ci
    Wolf, my 2 stroke race engines require about 50% larger main jet to use E85 over RF100 so no surprise you had to tweak to get it to run. I would not recommend E85 for road use due to the high consumption (if you could get it to run OK) and for me, all ethanol based fuels have the natural propensity for water absorption so I avoid like the plague except when I can buy in sealed containers.
  10. #35
    Jul 2011
    Hong Kong
    "95 840 Ci Sport Indi
    thanks for the Question....
    My car is a EURO 840 Ci 1995
    4 liter M60 B40 engine
    I have been using Shell V Power petrol (RON 98) in Hong Kong for the past 6 months of ownership.
    I never realized until now that I was wasting my money so I will just start to use unleaded (95 RON) ... there is nothing Lower than (95 RON) here in Hong Kong
  11. #36
    Aug 2011
    twilight zone aKa Seattle
    e34
    than why is it when I used the 102 octane that's available at one gas station here my buick ran like a racecar leading me to think higher octane=more power
    the end is near
  12. #37
    Oct 2008
    Good old G. :D
    more and more Cars..
    Your Buick is able to read, an 8 (M70) is blind and doesn't know what is written at the fuel dispenser.
    No, just kidding, I bet your Buick has knock sensors and the engine management is able to react...
    to register your 8 @ www.8coupe.com!
    Best regards from good old Germany Harry!
  13. #38
    Ruidoso NM, USA
    01 X5, 97 840CI
    Have not seen a recommendation for the 96-97 840 . Where I live we have 86, 88 and 91. What is the proper to use. Thanks
  14. #39
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Quote Originally Posted by hmfoster View Post
    Premium Unleaded
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
  15. #40
    Ruidoso NM, USA
    01 X5, 97 840CI
    Iceland
    BMW 850
    reviving an old thread.
    What about the S70? Should I be using EU98 octane or is it fine to run 95?
  17. #42
    Jun 2013
    Auckland, NZ
    1994 E31 850CSi
    Quote Originally Posted by Fatandre View Post
    The CSi owner's handbook and tank filler placard call for 95 octane minimum.
    I use BP Ultimate 98 octane.
    Current:
    1994 E31 850CSi Sterlingsilber/Anthracite Buffalo
    Previous:
    1987 E28 M5 Delphin
    1986 E23 M745iA Arctic Blue
    1986 E24 635CSi Polaris
    1976 E3 3.0 Si Arctic Blue
  18. #43
    Iceland
    BMW 850
    But does it Have knock sensors?
  19. #44
    Jun 2013
    Auckland, NZ
    1994 E31 850CSi
    No knock sensors, but it's a high compression engine (9.8:1), hence the requirement for high octane fuel.
    M73B54 engine is similar (10:1 compression ratio) and also requires minimum 95 octane.
  20. #45
    Iceland
    BMW 850
    So it would be even better to use 100 octane fuel
  21. #46
    Las Vegas, NV
    1994 850CSi, 2007 M5
    The gas cap from my S70.
    1994 850CSi, 2007 M5, 1990 VW Westy Syncro, 2010 e61 Touring Manual
  22. #47
    Jun 2013
    Auckland, NZ
    1994 E31 850CSi
    Are you sure that's the original fuel cap for your CSi?
    Last time I checked, 91 octane didn't qualify as premium unleaded.
    [Edit: have inserted a page from the S70B56 engine manual].
    Current:
    Previous:
    1987 E28 M5 Delphin
  23. #48
    Mar 2006
    Harrisburg, PA, USA
    x5, 640i, 850Ci, 850CSi
    Quote Originally Posted by kiwiCSi View Post
    That's the AKI octane number. The owners manual usually lists the RON octane number that is used in Europe. The AKI number is around 4-6 lower than the same RON octane number.
    Research Octane Number (RON)
    The most common type of octane rating worldwide is the Research Octane Number (RON). RON is determined by running the fuel in a test engine with a variable compression ratio under controlled conditions, and comparing the results with those for mixtures of iso-octane and n-heptane.
    Motor Octane Number (MON)
    Another type of octane rating, called Motor Octane Number (MON), is determined at 900 rpm engine speed instead of the 600 rpm for RON. MON testing uses a similar test engine to that used in RON testing, but with a preheated fuel mixture, higher engine speed, and variable ignition timing to further stress the fuel's knock resistance. Depending on the composition of the fuel, the MON of a modern pump gasoline will be about 8 to 12 octane lower than the RON, but there is no direct link between RON and MON. Pump gasoline specifications typically require both a minimum RON and a minimum MON.
    Anti-Knock Index (AKI) or (R+M)/2
    In most countries, including Australia, New Zealand and all of those in Europe, the "headline" octane rating shown on the pump is the RON, but in Canada, the United States, Brazil, and some other countries, the headline number is the average of the RON and the MON, called the Anti-Knock Index (AKI), and often written on pumps as (R+M)/2. It may also sometimes be called the Posted Octane Number (PON).
    Difference between RON, MON, and AKI
    Because of the 8 to 12 octane number difference between RON and MON noted above, the AKI shown in Canada and the United States is 4 to 6 octane numbers lower than elsewhere in the world for the same fuel. This difference between RON and MON is known as the fuel's Sensitivity, and is not typically published for those countries that use the Anti-Knock Index labelling system.
    "EuroSuper" or "EuroPremium" or "Regular unleaded" in Europe, "SP95" in France, "Super 95" in Belgium RON
    95
    MON
    85–86
    AKI
    90–91
    Also, you should use the octane rated fuel that your engine needs, but there is no benefit from running higher octane; you're just wasting money. The octane level is designed to prevent detonation; higher octane fuel doesn't provide more power. Instead, using too low an octane rated fuel robs power by causing detonation (knocking) -- hence, AKI or "Anti-Knock Index".
    Mike Barrett
    Mike Barrett
    94 850CSi, Hellrot over silbergrau dunkel/silbergrau hell
    96 850Ci, Oxfordgrun over silbergrau hell
  24. #49
    Jun 2013
    Auckland, NZ
    1994 E31 850CSi
    Quote Originally Posted by mbarrett635 View Post
    Thanks Mike - great explanation of the 'AKI' - which I wasn't aware of here downunder!
    This means Major Cheese's gas cap sticker is absolutely correct, as 91 AKI translates to approx 95 RON.
    Also, you should use the octane rated fuel that your engine needs, but there is no benefit from running higher octane; you're just wasting money. The octane level is designed to prevent detonation; higher octane fuel doesn't provide more power. Instead, using too low an octane rated fuel robs power by causing detonation (knocking).
    Which is why higher octane fuel is specified for higher compression engines without knock sensors.
    Current:
    Previous:
    1987 E28 M5 Delphin
  25. #50
    Dec 2013
    Braxton MI
    1998 840 Ci
    Back when I was young, we called detonation off of compression alone a misfire.
    Lower octane is more volatile under compression than higher octane. this is pretty rudimentary stuff.
    This is why the lowest grade engines, Diesel, don't use spark plugs. It's such unrefined fuel it ignites simply off of compression.
    My question is can you safely run 89 in a 97 840ci with ethanol? I use gasbuddy to find true gas locations.
    What I was looking for and found this forum was a conversion chart for euro fuel ratings to make sense of my gas cap's value and what that translates to at a US pump.
    I amazingly have not found a converter, calculator or forum which performs both of these tasks... crazy.
