Page 3 of 3 FirstFirst 123
Results 51 to 66 of 66
Thread: 850i Parasitic Leak causes dead battery
  1. #51
    Nov 2012
    Little Rock, Ar, USA
    '98 M3 '79 635csi '74cs
    Update:still stuck...
    I bought another GM (that's the 3rd). Still no luck. I think i keep buying bad units available from Ebay.
    Anybody could try my GMs and RMs on a good setup to confirm they are fine?
    If not i'll have to get the car shipped to Memphis to the nearest BMW place. But at this point I'd like to avoid any further expense.
    Thanks in advance!
    Quote Originally Posted by aeronotix View Post
    Nice - glad I'm inspiring!
    I had an aftermarket alarm correctly wired to the unlock/lock pins of the RM, removed it just in case. Otherwise aftermarket radio and I put back a CD43 on the original radio disconnect.
  2. #52
    Mar 2011
    Damascus, Maryland USA
    E31/E32 VWs Tesla
    HI,
    To understand if I have a localized issue on the GM/RM/relays and not the rest of the car I prepared a test bench outside of the car including the GM/RM/K70/K73/K15/K30/interior light relays. Both the GM and spare one I got on eBay are still not going asleep (.33A). See Excel snapshot attachments, the highlighted pins are wired. The test bench works exactly like in the car: I installed 2 lights to simulate the trunk light with the switch and interior lights. Trunk light never goes out and interior works good (if I momentarily ground pin 6 or 7 on X332 to simulate door opening, interior light turn on for 10s. Should I wire anything else on the GM/RM to make it complete so it goes asleep?
    I also prepared the attached pdf to recap pin assignment wire colors and function for helping others in similar trouble..
    Anybody would be kind enough to test them on a good functioning car?
    I don't of course pay for shipping both ways and more for the time spent.
    Bon weekend!
    Tonight, after receiving a module back from a member that still didn't work once installed, I decided to finally setup my test/bench setup, starting with a very minimal setup, i.e. with just the GM, an LED(+resistor) to represent the interior light relay, an LED for other output testing, and a few inputs. The general module draws about 50mA when powered by itself, with no loads attached. On it's own, the two I tested don't actually seem to power down below 50mA, and mine were fluctuating by about 10mA. (I tested with 2 different modules, same observation)
    I too observed the interior light relay coming on with grounding the door-pin input, though mine didn't stay on 10 seconds without door modules present, might be a difference in model year.
    Wondering if the 'wipers' were trying to reach home, I grounded X253-6 "Wipers to reset position" and X253-14 "wipers to park", no effect.
    Probing x254-2,3,4 (interface to RM) two were solid looking outputs and one was fluctuating every second or so.
    Without a relay module present to 'measure' the feedback current, I couldn't see the power protection relay signals ever engage(x254-24,25), and grounding the RM feedback and current detect inputs didn't change anything. My suspicion is that it's analog and the GM decides if the current is too high to allow the relay to turn on.
    Moving forward, I'm going to try my modules-under-test in my car, and verify what combinations of missing outputs the module still behaves properly.. (i.e. If I remove my door module, will the GM still behave properly, namely still going to sleep after 16min?)
    My suspicion is that the select few "GM still doesn't work after capacitor replacement" failures we've seen have something to do with another misbehaving module in the car.
    I'm also curious what kinds of random things the GM/my car will do when powered up in strange configurations (windows down, wipers not at home, etc)
    '89 735i, '91 850i, '81 MB 380SLC (For Sale), Tesla Model 3, and VW Passat TDI -- Yes, I still repair General Modules, DM for info!
  3. #53
    Mar 2011
    E31/E32 VWs Tesla
    HI,
    So I've confirmed tonight that a general module will not go to sleep if powered up without the 3 wiper relays...
    I repaired a GM for Ed and had my car partially disassembled, so I dropped it in for testing..
    Battery disconnected, Connect module, reconnect battery. Current goes up to about 1.5A while IHKA initializes for about 10 sec. Unlock, Open, Close Lock door, current drops down to about 450mA in my car (With the Trunk lid button pressed momentarily. My EKM is currently disconnected too, so 450mA is a little lower than the norm pre-sleep current of about 500mA). ~20 minutes later I returned to find my trunk light still on.. Thinking "Oh crap-- another dud" I remembered my wipers were mid-wipe and my wiper relays removed.. Reinstalling the wiper relays, they moved slightly.
    I disconnected the battery and repeated my re-lock.. 16 minutes later, the current dropped down to 30mA (29.7mA when I switched ranges-- Note: this is still 10-15mA lower than usual because my EKM is not connected. Also note, the Antitheft LED probably draws 10-15mA too, which is 1/3 of the sleep current load!!)
    SO YES! MISSING (Or bad) WIPER RELAYS CAN IMPACT THE GM's ABILITY TO SLEEP!!!
    Also note, my wipers didn't actually go home, I had them in a mid-wipe position for testing.. The car went to sleep with the wipers in a partial wipe position anyway, so the wiper motor at home input doesn't seem too critical. (Unless it's just counting the rotations of the wiper motor gearing.?!).
    We're one step closer to creating a bench test!
    Other observations:
    The trunk lid button (that controls the trunk lights) doesn't seem to impact waking the car.
    However, the trunk handle microswitch will wake the car.
    When locking the car with the trunk and hood open, the anti-theft LED blinked a bunch of times indicating the car wasn't secure yet. (As Expected)
    Closing the open hood on an already sleeping car didn't wake up the car or trip the alarm.
    The key in the doors can wake the car, as will the door handle microswitches (even if still locked). I'm not sure the exact timing of a car going back to sleep if someone simply grabs the locked door handle to check if it's open, but I suspect it's still a 16 minute reset.
    My car has a misbehaving door module.. Locking and Unlocking the car a few times, there are times where the key in the driver's door doesn't always arm (or disarm) the alarm. I'm fortunate enough to have a passenger key lock, (removed in later models), so walking over and unlocking passenger door is another way to disarm the alarm.
    Tomorrow, I'm going to disable the alarm LED to see just how much of the remaining 30mA it's responsible for!
  4. #54
    NY, NY
    84 633, 91 M5, 91 850
    Nice find. I'm going to re-check that the wipers are working correctly on my car. Any way to verify those relays are good besides just replacing?
    I'm also going to try pulling the door module on my car this weekend, but since my car doesn't sleep as it is I don't know that it will be a helpful data point (unless it fixes it, of course).
  5. #55
    Canada
    95 BMW 850
    I left my car parked for 2 weeks in wiper up position because I had to remove some debris from the wipers. The car went to sleep.
  6. #56
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The relays supply the 0V connection for the motor - without them the inputs (13, 14 and 25) to the GM will all be high and I doubt if the GM likes that!
    My BMW Repair YouTube Channel
  7. #57
    Mar 2011
    E31/E32 VWs Tesla
    Yes, that's what I was trying to say..
    Without the relays, wiper motor is 'floating'. However, the GM monitors all 3 legs of the motor, lets call them 'common', 'low', & 'high'. You need to energize common and either low or high speed to make the motor move... polarity determines direction
    Relay 3 selects the speed leg (low or high), while the polarity of the selected leg is chosen by relay 2 (+12V or 0V).
    Relay 1 selects the polarity of the common leg (0V or 12V).
    At any given point, at least one should be grounded. However, I've discovered that the GM seems to have a firmware bug that it can't continue when it sees all 3 inputs high (an implausible/transitional state, which is the case when the relays are removed, as all 3 inputs are floating).
    Normally, with all 3 wiper relays present, but de-energized, input 14 (motor common) should be 0V, Input 13 should be 0V, and input 25 should be floating.
    Note, most of the GM inputs float up to +12V or +5V and are then pulled to ground by switches, etc. Another interesting thing about this 'trend' is that current through microswitches and door pins is very low, probably pulled up to 5V or 12V with 10K resistors, so likely less than 1mA per activated input. This could make aftermarket equipment upset and certain aftermarket equipment (remote starts, alarms, etc) could also cause cause problems if the ETM isn't consulted first.
    Quote Originally Posted by David9999999 View Post
    David, if you want, you can send one or more of your modules back to me and I can test them in my car.. If you're real lucky, aeronotix and I will have figured out enough to get a working bench test going!
  8. #58
    NY, NY
    Thanks for the offer! My first suspicion is still the GM, I am wondering now if it's possible the software is having issues. I'll have access to the car this evening and will check the wipers.
  9. #59
    Mar 2011
    E31/E32 VWs Tesla
    I did a whole evening of testing the other day on the things that wake the car, the things that will/won't prevent the car from sleeping, etc.. I'll start a new thread when my findings are complete!
    Regardless, I think my next parts order will include a few serial EEPROMs just in case they are borked..
  10. #60
    radlaw's Avatar
    radlaw is offline SoCalEights Member BMW CCA Member
    Feb 2010
    Poway (San Diego), CA USA
    1995 BMW 840Ci
    Please refer to:https://www.bimmerforums.com/forum/s...-Battery-Drain
    Quote Originally Posted by revtor View Post
    ...[H]ave a closer look at relay K72 - it may be sticky. Pull K72 and measure resistance between pins 30 and 87a.
    If the relay isn't sticky don't re-insert it. Then measure the voltage over pins 4 and 8 of the socket where K72 was seated in.
    1) Did not find 87a; found 87b on K72 relay.
    2) Did above test on 87a & b. No resistance on either.
    3) Checked voltage between pins 4 & 8. None.
    Does this imply the both A1 (General Module) & A5 (Relay Module) are OK?
  11. #61
    Mar 2016
    GER
    F31-325 E30-330 E31-850
    I have also a Batterydrain issue, that I cannot solve.
    My car goes to sleep (lights off after 16mins).
    Current stays at 250mA afterwards.
    I disconnected the heater valves since some times the ihka module is to blame and the heater valves are permanently energzied.
    Did not make a difference.
    I pulled all fuses. Non Change. (Thats short summery for 2h of work)
    Only when i remove the smaller positive cable that is screwed to the positive battery clamp then the 250mA are vanishing.
    Thus I assume it must be a module that is connected without a fuse.
    What would you suggest to do?
  12. #62
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    What happens to the current demand if you remove K72 and K73 the consumer cut-off relays?
    https://www.meeknet.co.uk/e31/Timms_...lay_Finder.htm
  13. #63
    San Ramon, CA
    850Ci, M5, Model-S P85D
    Unsure of the specific E31 year and model? most are different, M70, M73, M62 etc
    My first guess!!
    Bad diode or the voltage regulator in the alternator?
    Did you also pull the relays?
    Feel relays for heat?
    Look at the ETM Power Distribution Terminals: X0-X3.
    If it was my car... I would use my clamp-on DC current meter to chase the actual wiring current draw rather than pulling connectors that require taking the car/interior apart.
    FWIW: the DME's, Transmission, ABS/ASC, Body Control and Lamp Control Modules, etc, all have direct-no fuse connections to the battery.
    All the Best...
  14. #64
    Mar 2016
    GER
    Its a M70 from 1993.
    Both cut off relays were pulled out.
    I unscrewed the positive terminal to look what cable is pulling the current. It is the 50a fused smaller wire that goes to the front.
    Meaning alternator etc. are not the cause as they are linked with the thick cable.
    I also pulled all fuses, that means only unfused modules might be in question here.
    What do you mean with Body Control ? the Grundmodul GM?
  15. #65
    radlaw's Avatar
    Feb 2010
    1995 BMW 840Ci
    After trying ALL the suggestions above, I settled on plugging it in to a "Battery Tender" whenever I'm home. No more battery drain.
  16. #66
    Mar 2016
    GER
    Quote Originally Posted by radlaw View Post
    i have no power available in the parking lot…
    What I have discovered:
    in the past the warnblinker were on right after i connect the battery. no they did not anymore when i connect the battery…
    I have removed the crash relay and blinker relay. the current did not drop….:-(
    i disconnected the GM,DWA,LKM,EKM, and pulled all fuses.. no luck.
