eBMWParts
Results 1 to 25 of 35
Thread: E36 Adjustable Lower Control Arms
    Lake City, FL
    E36 Chump, E46 Off-Road
    I'm in the market for adjustable lower control arms for an E36. I would appreciate any feedback on all the available brands. Since seeing the thread on replacing the rod ends on the Turner arms (http://forums.bimmerforums.com/forum...6#post20130496), I have some inspiration to pick up some cheap chrome-moly arms and replace the bushings with rod ends.
    Has anybody tried the "K-Sport" pieces? How about any of the ebay ones? Thanks.
    JFrank
    NASA,BMW CCA,THSCC Instructor
    Eastern Wa
    I installed the Ebay ones recently that were 128$ shipped and seemed to be of decent quality and my alignment guy/bmw racer said they weren't bad at all. I'd recommend them. I just did want to pay a ton for the huge beefy ones and run the risk of potetially hitting a curb and putting the control arm through the entire subframe haha
    1994 325i W/Stock LS1+ T56 329whp/361wtq
    Wadsworth, Ohio
    BMW
    You can't go wrong with UUC Motorwerks...
    With a lowered car, non-adjustable original control arms cause unwanted negative camber as the tops of the rear tires angle in too much. This condition causes uneven tire wear and ill effects on handling.
    These adjustable rear control arm correct this problem and can be tuned for any ride height, whether on a street car or a full-on race car. Adjustment range is in the +1.0 to -3.0 range.
    Features Include:
    * 4130 Chromoly center bar
    * CNC machined billet aluminum end components
    * High durometer sqeak free bushing at inboard end
    * All installation hardware included
    Click HERE for more information.
    Please let us know if you have any questions! Feel free to shoot me a PM or email.
    Best,
    ECS
    ECS Tuning your #1 source for all things German automotive
    Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
    Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
    800.924.5172 | OEM BMW Part Number Search
    sales@ecstuning.com | customerservice@ecstuning.com
    Lake City, FL
    I want to keep the negative camber. It's a racecar. I just want to be able to make both sides the same and upgrade from the factory barbecue tong design.
    I don't want a rubber bushing, but rather a spherical bearing at the inboard end. If you have any worn-out UUC RLCA that I could replace with inboard bearings then I may be interested in some used stuff, but not going to buy them new.
    JFrank
    miami
    1996 328is
    Charlotte, NC
    '00 540it, '97 B4 TDI
    Just aligned (Thursday) a '98 E36 M3 coupe with the UUC rear arms. I was very impressed with their finish, machining & range of adjustment. Car was lowered 2" on Billy sports & H&Rs.
    Oklahoma
    996, 914, X5
    Ground Control aluminum arms with spherical inner bearings for me.
    http://www.ground-control-store.com/.../II=655/CA=254
    FL
    are slow.
    http://www.summitracing.com/parts/EIB-5-67110K/
    Eibach rebranded SPC steel lower control arms.
    -Dr. Seuss
    Edmonton Alberta Canada
    1999 BMW M3 Silver
    I have the ground control ones and they are great.
    Vancouver, B.C., Canada
    '97 M3
    The Turner ones look like the easiest to adjust.
    Sep 2009
    Southern California
    '98 E36 M3, '02 Camry
    Im interested in Getting adjustable LCA's as-well. Any recommendations would be nice. You can't go wrong with ground control/uuc but you can't go wrong with the ebay one's prices. What are the major differences?
    Dec 2002
    Silver Spring, MD
    #199 IP BMWCCA
    Quote Originally Posted by arthothezilvian View Post
    On has spherical bearings and one doesnt.
    Eric WONGer
    2012 NASA Nationals GTS3 First Loser
    EX-#121 IP/GTS3 M3 SOLD
    Now-#121 GTS3 E46 M3
    LV, Pa
    944 Turbo
    I'll tell you the ebay ones may seem nice at the beginning, but one of the reasons they are cheaper is they use inferior rod ends....you'll have to replace them sooner
    Buy American. VAC, Turner, or UUC. (not sure where Eibach's come from)
    Davis, CA
    '98 Estoril M3/4/5
    Eibachs are SPC steel arms.
    los angeles ca
    1992 325is
    just wanted to know is there a difference between a 4 door and a coupe
    Sacramento, CA
    E34 -> E36 -> E90
    Quote Originally Posted by Tutu View Post
    Nope no difference between coupe or sedan.
    I have the Ground Controls and they're awesome, picked 'em up from Mark at Ground Control in person and couldn't be happier.
    /M3/4/5
    Vegas
    E60, E34T, E28, E21
    THought I'd revive an old thread for anyone looking into the eBay RLCA's. I bought a set, ran it for 6 months with some light track use. When I say light, I mean it... street tires, and pussy-footing around the track to get my suspension setup right.
    The STEEL sleeve cracked. The crack started at the end next to the jam nut, and extended 2" up the sleeve. When the crack reached far enough up the sleeve, it finally pulled off the end heim joint... which in turn allowed the wheel to nearly come off. It pulled the axle out of the diff. Fortunately it came loose at low speeds <10mph, and in a straight line, which made controlling the car an easy thing to do...
    Needless to say, this could REALLY have been a bad day. It could have gone bad on the city streets, or while doing 75mph on the freeway. In that situation, it could have caused a serious accident. For everyone's safety - do NOT buy these cheap eBay RLCA's.
    Contact with the eBay vendor (name withheld) resulted in nothing but a return email saying 'no warranty'. I do not care about replacing them with the same, since they are obviously cheap junk, but wanted to see how a vendor would stand up to such a situation. Their response was as I expected from an eBay vendor and a cheap product.
    CURRENT:
    Racecar: '81 e21 320i Group2. GT28 @ 25psi, MS2, e28 M5 suspension/brakes underneath, forged, cammed, 400bhp, 2190lbs, etc, etc...
    Daily: '95 e34 540/6. DUDMD tuned, vogtland/koni, Schnitzers, other minor touches.
    Project: '94 525iT. S50 swapped, supercharger in the works, manual swapped, Airlift supsension, Mpars, Brembo's, clean machine.
    New daily: e60 530i sport package. Stock.
    Aug 2008
    St. Louis, MO.
    e36 332i
    Quote Originally Posted by Hova View Post
    These are the ones I have, 5 years on the street 2 years on track. No problems yet
    Quote Originally Posted by chikinhed View Post
    I do my own alignments, the arms are tough to lock the inner jam nuts closest to the diff especially on the exhaust side. Thankfully I dont adjust the rear to often. When I do I always think about the Turner arms that have adjuster and lock nuts lockated at the outer end.
    Quote Originally Posted by dangerwillrbnsn View Post
    I guess Its time to take a close looksy. Do you have rubber ends or heim joints on the inner parts of the arm where it attaches near the diff?
    Could you please post up some pics of the failure point.
    Glad to hear you didnt have a bad off, could have been really bad if you were at speed.
    Jun 2008
    Nashville, TN
    '95 M3,'04 ZHP, 01 330Ci
    The SPC arms are decent, but if you drive the car hard you need to check for this. The arm itself slides off over the bushing flange and there is metal on metal contact at the subframe.
    If you find yourself with this issue there is a member here, Motomoron, who makes a poly limiter kit to keep this form re-occuring. If you are goung to be unstalling a set, I'd recommend you spend the extra $50 on the limiters and install them at the same time, or go with the newer style Ground Controls with 100% of the adjustment at the hub.
    BTW, the oil on the diff is from the weep hole in the diff cover blowing fluid due to NSS being a Roval. NOT an actual leak
    SPC Right Side Bushing Damage by 20xclean, on Flickr
    Vegas
    E60, E34T, E28, E21
    I got the rubber ends... figured I don't need heim joints since it's not a race car. The failure was on the other side though, at the side that attaches to the trailing arm. I'll try to get pics when I crawl under to install my new ones.
    CURRENT:
    Dec 2010
    Downtown Los Angeles
    03 M3
    After reading the last few posts I will be getting ground control or something of the likes
    Nov 2011
    Malaysia
    BMW E36 N3
    You can search ultraracinginstock ebay store.
    Vegas
    E60, E34T, E28, E21
    As requested, here is a pic of the failure point on the cheap ebay arms. The male to female fitment is very poor and feels like it has a couple mm of play, as you can see in the photo's below, I can literally move it left and right inside the sleeve. Needless to say, they're junk. These could have really taken me out... worse if my better half were driving.
    Mar 2011
    Houston
    98 M3
    washington dc
    Avus Cosmos Calypso!
    go with VAC. They are super easy to adjust, deform in a crash, and the bushings can be replaced with the OE ones when they go bad.
