I have updated sss v30 with v38 files and it works fine, but much slower.
I'm currently running v31 on VMWARE and can no longer do any coding cause of this message im getting pretty much telling me to update my progman. Would you mind helping me out in the process to upgrade this? I'm trying to follow the thread but having a hard time. I'll even throw some $$ your way. Thanks guys
Hey guys...I'm fairly new at this and need some help. I followed all the steps that are outlined in this thread including running the changes. I have a device that Progman was recognizing as a DKL Radiohead device. I posted a pic of it. After performing all these changes, Progman no longer communicates with it. Do I have to get a different device? Will the one on this link work:
http://cgi.ebay.com/ebaymotors/BMW-I...item3cb3447d78
Or is there a way to make my current device work with the V38 progman files. I currently have Progman V31 installed on the VM machine. Thanks in advance fellas.
So, somebody has done a full car update (succes)with a modified progman V38 installation ?
i've downloaded the ista v39 vehicle data, can i get these installed into progman v32???
ps: the files aren't crypted or something, there are tons of gigabytes in the e**/data directories
Hi guys,
How do you actually access D:\Programme\ ???
Thanks.
Update my Progman to v40 but still getting this. Is my car's software too new?
Have you added "konv.temp" to all the data folders?
onebadmofo, has your car been to BMW recently?
Yes I was in service about a month ago.
konv.temp folder has been added to e90\data folder, that's the only one I updated.
I think your cars software is newer than V40 mate. You'll have to wait for the next version to be available to us mere mortals!
I had this very same problem with my E60 and couldn't solve it for ages but when I upgraded my progman to V40 and added "konv.tmp" to all the data folders I suddenly had access to my car.
Guys, I want to update to my v32 to v40.. can you tell me how you did it please?
konv.tmp has to be an empty file, as per post 23
its quite simple. follow the post 23. basicly you have to get into the virtual PC
and update your v40 that way, by pointing your vmware to the iso image of your V40 daten files that you have to make. because if you drag and drop from your PC to the Virtual Drive where everything is stored, it will say disc full and wont let you continue....... hope that starts you off
Last edited by d4rkchocolate; 02-22-2011 at 04:38 PM. Reason: Automerged Doublepost
Hi dark,
I do not have the full ISO but the sp-daten files from v40, but I suspect it may not be complete as it only contains the following RAR files:
E60, E70, E89, R56, E53, E83, E85, F001, F010, F025, K1X
[there is no E38, E39, E46 etc]
When you unpack the RAR, there is a corresponding ISO, so unpacking E60 RARs gives an E60 ISO file.
Do I have an incomplete version of v40?
Thanks.
If you actually read post 23 here's what it says
And none of the other folders have a *file* konv.tmp, they have a *folder* or a directory "konv.tmp".add the folder "work" in the E89 directory.
Add a folder in the E89\data directory called "konv.tmp"
Leave both folders empty.
Your E89 folder structure should look something like this now:
cfgdat
data/konv.tmp
daten
ecu
format
kmmData
sgdat
work
ok here goes............go to the \Programme\IFS\SP\E** folder
in there,you will see Your E** folder structure should look something like this:
data
cfgdat
daten
ecu
format
kmmData
sgdat
what you do is replace the above with the latest V40 files that you have.
(note the virtual drive will not let you overwrite the above as it will say disc full and terminate, you have to delete the above files and then copy over the same updated V40 files via the ISO within the VMware......
Once youve done that, and the directory looks like the above.. you then have to ADD an empty folder called WORK so it looks like this:
data
cfgdat
daten
ecu
format
kmmData
sgdat
work
then, open the data folder, and ADD an empty folder called konv.tmp
like i said before its all in post 23
I think you got the v40 files from the ftp server, the daten files are complete, I already added the missing folders (work, konv.tmp) and made them as an .iso file.
I didn't add them to the server because they are the same as the v39 files (same size as v38,v39), so if you need them, then get them from there.
waow, then that means you could well possibly have a higher file updated to your vehicle than v40 when you had it serviced last month. because it sounds like youve configured everything correctly.
Ok so to clear few things up, ill ask some stupid questions . If I want to update my cars boxes, is there way to make full backup of them so that if there are errors I can fix them by flashing the backuped data back? What are the pros on updating your car boxes? I have DIS and SSS + Progman v32 fully working on my VMware. What are the latest EasyDIS and Progman which can be used? Thanks for in advance, hope that this will clear things up for other noobs too
Please see post http://forums.bimmerforums.com/forum....php?t=1604923
I really would appreciate any help..
OK - GOT DIS 57 and Progman up and running..
got these results in Progman V32 - is this the fact that the Datens are wrong version or something if so can someone please advise..
Sorry KB120D for being so quiet, so tired trying to resolve this problem and to get Progman up and running. No have INPA - DIS44+57 and Progman running..
even changed my FRM from 6135 9153778 - 01 to 6135 9166708 -03 9166728 - but swapped it back.
also tried to program MRS to get VIN back with Winkfp and it worked but now i get errors on that too.. what a f***ing mess.
Everything has to be correct version of file i think..
Status report
Date 1 time: 1625
Session: WBAUD, Model series: E87 Vehicle ident. no.:
Vehicle data status: E89X-07-06-520
Target data status: E89X-08-09-530
Following ctrl units have failed to respond or have responded incorrectly.
EKP has failed to respond/responded incorrectly
SINE has failed to respond/responded incorrectly
CAS must be reprogrammed
Part no, progr E ECU 6943834 (is) 9147226 (should)
JBE must be reprogrammed
Part no ,progr ECU 9160189(is) 9187539 (Should)
DME/DDE must be reprogrammed
Part no, progr ECU 7807947 (is) 7812665 (should)
DSC must be reprogrammed
Part no, progr ECU. 6776056 (is) 6784764 (should)
EPS must be reprogrammed
Part no , progr ECU 6781199 (is) r 6788736 (should)
DWA must be reprogrammed
Part no, progr ECU 6974373 (is)
Part no Progr, ECU: 6781199 (is) 6788736(should)
DWA must be reprogrammed.
Part no Progr 6974373 (is) 9149671 (should)
FZD FZD must be reprogrammed
Part, no., progr. ECU. 9137485 (is) 9197743 (Should)
PDC must be reprogrammed
Part .no., progr ECU. 6982395 (is) 6982400 (should)
FRM must be reprogrammed
Part no progr ECU. 9159807(is) 9166707 (should)
IHKA must be reprogrammed
Part no progr ECU 9147299 (is) 9199260) (should)
KOMBI must be reprogrammed
Part no progr ECU. 9141478(is) 9187049 (should)
