Hey guys and gals thanks for taking your time to help me. I want to know how much you would pay for this m3.
I found an E36 1997 M3 w/:
-150,000 Miles
-Recently painted blue interlagos
-Orion V2 Angel Eyes
-European Ellipsoid Housing with 6k HID Bulbs
-90% on Front tires, 98% on Rear tires
-New Grey Headliner
-Manual Vaders in great condition
Has the following problems:
-check engine light(vapor emissions leak) and says it is "vacuum leak associated with the evaporator emissions"
-airbag light (not sure)
-needs a new alternator
Comes with the following extras:
All stocks parts
Borla Cataback Exhaust (Uninstalled)
H&R Springs(Uninstalled)
make sure it has some maintainence records. I would say 5500-6500
Yeah, it's worse than mine and I got mine for 6.2K.
Closer to the 5k range considering the thing has been re-painted & needs and alternator.
Where in MD are you? I'd be glad to put it up on the lift, and take a look at it for you. You really need to find out why it's had a color change. Plus, a PPI is never a bad thing. You can also see my car, and see what they should look like...lol
GreenMobster- Thanks I was going to ask for them right before I took it to inspection.
MasterKwan- PM'd about the problems
Brinkmann0- Okay thanks
RRSperry- PMED
i would pay 6k...
and whats the reason of repaint?
eva leak and air bag lights are common.. a loose gas cap could cause the eva leak also.
2000 BMW 528i / Manual Tranny / Sport & Premium package / Xenon headlight / Sport seats / Premium sound / DSC /
2011 BMW X3
Rarely does a loose gas cap ping an EVAP leak code in our cars... especially at around 80k+ miles, more commonly, the plastic expansion tank starts to crack. (like a catch can for the fuel tank). It's about a $65 to $85 part and an hour install.
The airbag light is common - usually the stupid seat belt sensor or the steering wheel airbag/horn ring ( you can test the latter, if the horn doesn't work, the ring needs to be replaced.)
None of the stuff you mention are serious show stoppers given the car is well over 150k miles. But keep in mind at 150k you are looking at most likely replacing...
1. Brakes
2. Clutch
3. Suspension, bushings, guibo, etc.
4. Steering rack, pump, etc.
I've crossed 175k in my 95 and I've dropped an easy $5k in the last 20k miles.
BMW CCA Member 186373 - Golden Gate Chapter
Former (e)Bombe Magazine Editor, "The Toy Box" product review writer | Current member of Team Jesus
Gone: 1995 E36 M3 Arctik Silber, 1996 E36 M3 Cosmos, 1991 E30 318is Cosmos
ganzibye- The owner wanted to "freshen up the car" and gave me the same reason for the EVAP code.
LuxoM3- Thanks
i wish i can find 97 m3 for 5 grand. you guys are crazy.. i will say 7g at least where i live that's what they wroth.
I didn't get a PM.MasterKwan- PM'd about the problems
I think 5kish with what you have mentioned. Remember you will have to pour in a few $k to get this car up to par.
Yellow 1995 BMW M3 1 out of 8,515. Build Date: 10/94
Engine- S52 OBD1 Swap, TRM Chip, 21.5 lb. inj., 3.5 HFM/ECIS, AA catback exhaust
Transmission- Aluminum flywheel, 3.23 Diff
Suspension: H&Rs and Bilsteins, Powerflex/ AKG Bushings, X-Brace, UUC Swaybarbarians
Rims: 18x8.5 BBS RCs FORGED
Brakes: Brembo Rotors, Hawk Pads, Steel Brakelines
Dynojet RWHP: 250.9 TQ: 237.72 CA SMOG LEGAL POWER! =)
Best 1/4 mile: TBD
Weight: 2650 lbs w/ 1/4 tank of gas
7K for a car that won't pass safety or emissions inspection? You don't even know what's really wrong with it. It might take a couple grand to get it through inspection. Mine at 6.2K was fully inspectable and emissions legal. Worn, yes about like this one but, still usable.7-9k consider this car is EC.
It's worth 7K if it wasn't broken. It's not worth 7K the way it is.
Do you guys think HID headlights will be a problem? as in too bright?
Nah, you should be fine with 6k. It will have a hint of blue to it. Just make sure they are aimed and adjusted right so you dont blind other drivers, and possibly cause an accident. Cops wont like it as well.
Sorry to revive this thread but i thought id update people who have posted. I bought the car for 5 g's at 149,420 miles. Since then I've replaced the alternator, driver seat belt latch, done an oil change, replaced pre cat o2 sensors, changed the cabin filter, roof ledge trim, vent window trim/moulding and seals. In 2 weekends from now I will be replacing the selector rod/shaft seal, transmission mounts, guibo/flex disc, and the wishbones. Spent about 1.9 g's so far after buy all the parts for my latest project, I'm working on just bringing my car up to par and then converting Jet-Hot headers my friend gave me for free from OBD1 to OBD2 and installing a borla because I found a deal on one.
$5k sounds like a good deal and not too bad spending the $1.9G. Bought my 95 with 187k for $3800. I had the RTAB/Shims, rear shock mounts and alternator replaced. Bought two new Yokohama S Drive tires for the rear. So far, in it for about a $800 in repairs and tires. Looking for LCA and tie rods to eliminate front end play. Also, gonna spend another $500 having the scrape on my drivers door repaired and hood painted by a pro. Then I'll be around $2 G or $5800 total.
Edit: saw update. How do you feel about the carat this point?
I feel that its a great car, but there is always going to be work to done. Mostly work that I can do as a 17 year old with a lift and the right tools. What killed me is the roofledge trim and real window trims/seals added up to like $550 and I'll need to replace the door seals which are $560 for both. Oh well, its an m3 and being an older car it needs a bit of refreshening.
you're not purchasing that stuff from the dealer are you? There are a ton of vendors out there you should be researching to save some dough. Pelican Parts, GetBMWparts, etc. The vets will chime in with more.
Good luck with the car. When I was 17, I had an '86 Camaro. V6...
Probably been in a wreck people dotn just paint 10 - 15 year old cars for no reason.
It'll cost you about 10k. Doesn't matter what you pay for it, but to have an M3 that is solid, all maintenance up to date, you're spending 10k. So buy a well sorted car at a higher price and save yourself some work. You buy a cheap one you're going to be dumping some money into it.
How bad was the re-spray? Was the engine pulled and the engine bay and door jambs repainted? Pull the trunk carpet out. Does the color match the exterior? How about the rear door panels, is the metal behind them a different color than the exterior?
Nope, I've always shopped around for the cheapest parts. I couldnt purchase roofledge online (tried rmeuropean) but they said it would just bend.
I guess you missed the update, there are no obvious signs of a wreck like
a drooping fender.
It was actually a really good respray, they missed behind the mirrors and thats it but ill be taking it back so they fix that. The door jambs have been painted but i can read the vin off of them. The color doesnt match the exterior because its been painted.
Offer the focker $4k. AND be prepared to spend another $6k =)
Best 1/4 mile: TBD
