Results 1 to 6 of 6
Thread: No obd2 plug under dash?
    Oct 2007
    Cape Breton, Canada
    '97 528i, Pacifica, Fiat Spider, '73 Austin Mini
    I just opened the little obd door under the dash, and all that is there is an empty bracket! There isn't any sign of cut wires, etc. Is there supposed to be a regular OBD plug there? If so, why would the PO move/ remove it?
    2006 328i
    2007 X3
    2004 Jeep Rubicon
    1973 Austin Mini
    Cape Breton, Canada
    Florida USA
    X3,528i,
    yeah there is suppse to have a obd2 port under the steering wheel colum cover...
    2000 BMW 528i / Manual Tranny / Sport & Premium package / Xenon headlight / Sport seats / Premium sound / DSC /
    2011 BMW X3
    NeilM is offline Member BMW E36 M3 Expert
    Fort Wayne, IN
    96 M3, 15 Golf R, 18 Q5
    It may be dangling down behind the knee bolster. You'll have to remove that if you want to find out.
    Neil
    BKLYN, NY
    98 M3/4/6, 16 M3/6
    Yea, as Neil said. you should remove the underpanels to expose the wiring harnesses under the steering wheel and try to find the port inside there.
    a previous owner could have relocated it or possibly used a OBD2 monitor somewhere and routed the wires behind the dash so it looks cleaner.
    SF
    M3
    you've just been punked!
    Menlo Park, CA
    99 estoril m3 vert
    Yeah it'll be back there. I've accidentally pushed it all the way back when re-installing my knee bolster.
    Brian - DEPOs + 6x HIDs (straight cutoff), MM Underpanel, RE RSMs + reinforcement, AKG 80A RTABs, OEM FCABs + motor mounts + sway bushings, OEM shocks + struts, ASC delete, Pioneer DEH-80PRS, BSW Stage 1 + Sub
