alright, thanks anyways.
p.s. i did change out the last one and that didnt do anything, ( just for future help reference) thanks alot bud
on to the next project!!!!
i just can't seem to get over this post so here i am with desperate measures in reviving this thread that seems to me mattered in asking a more decent, clear looking photo. Please send me a clearer photo of this
As for the capacitors, just to add some dimensions/sizes:
I have been told by the electronic guru of the German 7 forum many years ago: you can replace them with higher voltage such as all with 35 Volt ones or more as long as they fit by size/dimensions.
You just have to pay attention to the diameter, otherwise they do not fit, max. thickness/diameter of 10 mm is possible and NOT higher than 16 mm.
The distance between the "feet/legs" of the capacitor should be 5 mm.
So the dimensions are the most important, the rest does not matter much.
Has anyone done a repair on a Blue back Gen II cluster? Mine is a June 1992 cluster.
Mine is flashing and 'gong-ing' non-stop!
see here, in my case the problem was the OBC, not the cluster - chime/gong randonly comes on - solved https://www.bimmerforums.com/forum/s...highlight=gong
blue cluster caps replacement https://www.youtube.com/watch?v=z4MwIlhJpKA
