"..Horsepower is a measure of work done over time, or the rate at which work is done."
http://www.cardomain.com/ride/579694/1
Have not posted for a while. I got a few parts left, just found a 323i in the yard down under, I got the oil filter housing and the 323i arms.
Those arms are for my buddies car.
The final push is on: Ordered some STI black ignition wires: Where can I get the coolant hoses?
[/URL]
And a custom e30 center chop into the e21 subframe - cause you can strip the diff easy in our cars...
Lordy lordy...you're screwing around too much!!! hahahaha Missin out on so much fun I tell ya!! Geezzzzzzz
My build thread M20 than S50 into 320i: http://forums.bimmerforums.com/forum...0#post23442810
More videos Ski and anything I should know about with your car? How is it running? - I will be running shortly. Do you know where you got the coolant hoses? Ski I am not screwing around to much....I am trying to get it wrapped up..
Sure....eBay! My fav place haha... Look for fill silicone, whatever color you desire... I like silicone cause it doesn't break down like rubber....
and car/engine running like a champ! Monday I'm going to the paint shop to see when I can drop her off... I'll be taking off all the trim and glass... So no overspray or missing parts! They can't screw that up, huh? Haha
Ski I have been looking for gloss black hoses all the ones on ebay are -chinese ones - and have the logos on them...
not too good. Please find me and un-logoed set of silicone BLACK hoses....I am in the home stretch now....
Just a little update ..hoping to get the car running with the new engine - in the next month...will post pics of it all together....thanks....Got the ignition wires the other day..
Guys just a update, we are in the home stretch. I have modified a 325i radiator by moving the outlet to the passenger side, also I am selling the WAR CHIP. If anyone wants a brand new one, Its for sale. I am going with Megasquirt.
A few pics. I also will be rocking louvers this year when its dialed in....
For the E30 Diff conversion:
I presume you wont be running AC?
No Ski we get snow on the ground and its freezing here today. I am going try to get the car running with AC. I know the m20 has a place for AC,
so we will see if I can do with out if for now....just get it ripping and that is fine...you got you car to work with ac.
If I put the compressor in the engine bay what would I need to do?
Awesome build
Why this change????? Not happy with the performance?
SKI I never ran it a day with the Miller war chip. Since you have to drive it, shut it off, log it, turn it on and tune it its time a lot of time to dial in correctly.
With the Mega Squirt module its one day and its tuned. You are one and done.
The Miller war chip with base stroker map is for sale....
Been too long. I sold my DINAN rear subframe to my friend is going M50 into his 320i, been helping him get all the parts for the swap.
Baurspotting parted a 323i that we got a lot of parts from for my friends swap. However the rare m20 323i 5 speed from Baurspotting turned into a 4 speed - so to get the m50 set up right we had to crack both transmissions and take the 5 speed from the 320i and insert it into the bell housing of the 323i one. More on this later...
So I took the money from the Dinan Adjustable rear subframe sale and sent my extra set of e21 323i strut housings to England.
With the strong dollar I now have Gas Coil Overs Being made for this car.
Thinking about 350 front 275 rear springs....and going to get the camber adjustment front upper strut bearings.
Also I got a second 325i wiring harness to make one wiring harness and to extend the wiring in the bay.
Performance BMW has hinted that they want to feature my car....oh man, if I could just get it finished off and take it to a few shows I would be so Happy.
My buddy will have his M50 in his e21 I hope to take a few pics with his car as well. Next up I have to get an e30 diff.....will update photos once more progress is made....
Taking to the next level with Gaz coil overs, 375 front and 250 rears, for the car. Cant wait to start driving this car...
Debating weather to get the camber plates for the upper strut bearings, the roads in Boston are utter rubbish right now....
Sweet setup Wish I remembered what springs I'm running in mine, but I think they're prefect. Still great for the freeway runs and around towns but hard enough for cornering....I guess I got lucky!?
I am running 400lb front and 325lb in the rear.
GAZ allows you to run different spring rates that it came with they can be switched out easily. M60b30530i - how do you like the spring rates that you are using, and are you running bilsteins with yours?
Ski - yes I forgot what you used. How is the handling on you car?
PS:I am going to PM You later in the week as I have a new front kidney and I want your help separating it, I am sending it out to be chromed,
and the part that goes under the dash I am recovering that in fabric and need your help.
I run 450/350 springs, but my roads are much better then yours.
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
14 f800gsa - red headed stepchild!
Been working on making the two wiring harnesses into one: Here is what it looks like today:
Here is what I need. Does anyone know where I can get these and what the name of these parts are:
part 2 is the idle control valve, can't make out part 1
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
Joe
The part 1 you are looking for is the array of hoses, check valves and fittings for brake booster vacuum supply.
If you are going to a standalone using speed density or anything other than a MAF/AFM you would most likely just want to run a brake booster vacuum hose
right to your brake booster check valve and not use the array of fittings BMW did with the Motronic 1.3.
I am glade to see progress as always with your car, it sure has been a journey!!
Jeff
Jeff thanks so much...your car was an inspiration....for this build....We are getting really close now. I have my fingers crossed, that there are no issues with the brand new engine, as I have done everything three times already.
I am running the MILLER MAF and Miller War chip, so I think I need part 1. The miller war chip plugs into the 173 ecu, and it sets the values on a lot of settings, and its like a stand alone.. Do you think I can run just a brake booster hose off the throttle body directly into the brake booster? What does the brake booster vacuum supply do?
take care,
Joe
I got totally simplified my setup so it doesn't look so crowded and ugly. You don't need sooo many hoses going into one and blah, blah, blah.....one simple hose going to check valve and that going into the booster.
I also bypassed the heating coolant going into the throttle body....Not sure what that's all about? I know in any project...street, race, drag etc...you want the coldest air going in at ALL times and they put a heating element within the TB??? Don't get it....well, mine is gone....Love it...nice n clean
So I presume there are variations of the rubber intake boot, cause I don't have that one part that connects to the vacuum hoses? One of the holes at the TB that you have 2 and I have one is plugged there....that's why simplified
