Yeah mine worked with inpa. Succesfully read the engine errors and airbag error. Did the software mod and connected pins 7 and 8. Navcoder tells me it can't connect so there some work to find out.
Thanx for the advices.
Ok I'm about to stab myself in the eyes with my soldering iron.
Modified FT232BM Vagcom cable w/ fake ign/bat - Check
Ads-OBD adapter - Check
Set com ports, etc - Check
Inpa 4.4.7/Edibias 6.4.3 and I changed the ediabas.ini file - Check
And I still get the "IFH-0009: Can't communicate with control unit" error whenever I try to access ANY module
And now as we speak i am getting the IFH-0003 error....
Someone show me the way....
Alright I get the IFH-0009 when the cable is connected to the car
And I get the IFH-0003 error when it's not connected.
So it seems as though it's not reading the computer properly. What gives?!
Hi Guys,
Is the reason for my cable not working due to this screens lack of information? I apologise for the banility of this question, most instructions by randomy and DavidMc (particularly his READ THIS FIRST doc- most useful) have been strictly adhered. But as seen, something is awry.
Hope someone can help.
No that's the wrong menu,
Go to Administration --->>> Connection Setup
and from there, connect the Diaghead.
Yes that's it
Ignore the error, it's nothing. You can get rid of it HERE.
In the diaghead emu setup you can change the reception stronger (not really necessary).
Normal if you choose to run a diaghead emulator.
My system will not let me change the addresses one to a two?
Hi David, Is there another way?
Update edit: Plugged it all in this afternoon and it worked without the need to ignore the error message previously mentioned to get it to work.
In addition INPA is still non-functioning. Help required on that one if possible.
hi all, i'm realy new at this forum ( just registered today ) but i'm reading it from some time ago.
Currently i'm on project to f`kin update my stupid DME and there is the problem that i have crashed to.
First to apologize about my bad english
and to explain what i have so that we can be clear.
1. VAG cable with FTDI 232RL chip soft invetered and soldered pins 7 and 8 ( driver from firsl page )
2. connector with the 20 pin head ( obd to 20 pin ) my car is old and doesn't have standart OBD under the dash.
3. Inpa/Ediabas 5.0.3
4. diag head
5. vmware and SSS-Progman and DIS/TIS v55 UK
I can manage and activate any modul with this cable and so on but i cannot update the DME.
It crashes with this message
In DIS crash right about the step when i must insert the VIN number of my car.
Does anyone can give me some advice about what i'm doing wrong.
Thank you.
Well I don't think E39 is in ADS.
try full start change iso for E39
i'm using full start.isoCode:Orphee
this 15 pin present i have to check.Code:FritzP
Thank you for the suggestion.
you mean that i need to have pin 15 on roung plug under the hood ?
p.s.
Just check it out.
I don't have pin 15 so this means that i must can program with OBD standart.
Hi Guys
I bought a CD from Jimmy on another forum with the leads but after installing the Inpa it does not show the E39 model.
The model version is
Inpa V5.0.2
I loaded up BMW Group Rectification prorams UK
I am unable to get the E39 model up on any keys just all other models
Any help would be so good.
BMW I Own
E24 1983 635csi Race Car Build (Schnitzer Replica) http://bigcoupe.com/phpBB2/viewtopic.php?t=21792
E24 633csi 4 Speed Manual
E24 635csi /// 1986 4 Speed Auto
E24 635csi /// 1986 Getrag Manual
E23 735i 1986 *** 4 Speed Auto
My Business
https://www.facebook.com/pages/BMWre...68407960016698
DIY E24 Dash Removal
http://bigcoupe.com/phpBB2/viewtopic.php?t=20630&start=0&postdays=0&postorder =asc&highlight=
Hi guys
Thanks for the reply
Can someone please tell me with the INPA program I have that I downloaded, when installing the software and the page asking ADS or OBD which one do I choose as my car is a built 99 535i Msports with the pacman plug under the hood?
I plug In the plug but it shows battery on ignition off.
Do I have to load anything else on, it is set to com1.
Do I need a special driver for the lead?
I would like to get this up and running
Thanks again guys
Addam
Sorry guys one more thing, does anyone have for link for the instruction for the downloaded version INPA they found post for me a link.
BMW I Own
My Business
Hi Guys
I did the 2/17/20 thing with the wires on my 1999 E39 and the program IPNA worked and checked codes but the Ignition Light in Black on my laptop did not come on only the Battery one was on, is this normal?
Thanks guys for all your help
Cheers
Addam
BMW I Own
My Business
BMW I Own
My Business
Adam,
all the questions have been answered on the 5 forum,
you dont need to change settings in notebook if you are unsure how to, just press the shift key then f9 key and e39 will be there.
So theres no difference whatever i have the 232BL/BM or 232RL cable?
I still need to solder a transistor on it to get real battery/ignition detection before the cable is fully usefull with DIS, INPA, NCS etc...
Well.. Thats just great!
Love to pay almost 72€ (thanks to the Danish taxes) for a RL cable because people wrote other places that it would be easyer when you just need to invert the DSR# and RI#..
But why is it necessary to get real detection?
It must be more then just a simple signal since the inverts isnt enough..
