Page 3 of 14 FirstFirst 12345678910111213 ... LastLast
Results 51 to 75 of 327
Thread: My DIS/INPA/SSS/CARSOFT/NAVCODER Interface.
  1. #51
    Nov 2010
    Madrid(Spain)
    e39,e46
    Quote Originally Posted by poteroa View Post
    Well, go and try it!
    Could you tell me if the pin nš14 of bmw interface 20pin(power pin) go with 5v or go with 12vŋ?
    Nothing, I just try. I do not know why not go, I'm going crazy.
  2. #52
    Finland
    525dA E60
    Quote Originally Posted by Marcys View Post
    Sorry??!? I didnīt understand your question.
    Do you mean that what voltages are in car side OBD-Connector?
    If that is what you are asking, check this link:
    http://pinoutsguide.com/CarElectroni...c_pinout.shtml This is the 16-pin new model
    http://pinoutsguide.com/CarElectroni...g_pinout.shtml This is the old 20-pin version
    So if your car is pre 2000 and you have the round connection, you have to buy/make an adapter to use this application
    But if you are asking that regarding the cable, you donīt need that information, just make this cable and follow instructions.
    If you are looking info for some other application, then for that you have to start a new topic.
  3. #53
    Nov 2010
    Madrid(Spain)
    e39,e46
    No no!
    I asked about the voltage that reaches at the 14 pin of connector
    motor (http://pinoutsguide.com/CarElectroni...g_pinout.shtml)
    and i solved my doubt, the power and the Ignition pin's will come +12V
    but the cable does not work, I tested the resistences and are
    correct, not how to test the transistor to see if it works
    correctly.
    The current programming interface are:
    I / O CONTROLS
    c0 rxtled
    c1 txled
    c2 poweron
    c3 poweron
    c4 sleep
    And RI # INVERT .
    All by MPROG 3.5
    I do not know what else I can try ... : (
    THANKS
    TESTING TRANSISTOR:
    Among leg E and C and my tester in 20Kohm the value is 9.93
    In other combinations of testing do not get any value.
    :S
    you have this values in your transistor?
    THANKS
  4. #54
    Finland
    525dA E60
    No no!
    correctly.
    I / O CONTROLS
    c0 rxtled
    c1 txled
    c2 poweron
    c3 poweron
    c4 sleep
    And RI # INVERT .
    All by MPROG 3.5
    THANKS
    TESTING TRANSISTOR:
    :S
    THANKS
    Hi, I donīt have a multimeter at the moment, so canīt test the 546.
    But one thing, DO NOT INVERT ANYTHING WITH THE SOFTWARE!
    If you do this real ignition modification, the chip has to be in "factory state".
    Only change those:
    I / O CONTROLS
    c0 rxtled
    c1 txled
    c2 poweron
    c3 poweron
    c4 sleep
    Leave the DI# and DSR# blank (No selection) when you flash the chip.
    Check after flashing that the DI# and DSR# donīt have any invertion.
    The Battery "dot" is black in INPA when the cable is connected to PC, the Ignition is White. If you get INPA in that state, the cable should work.
    Always after flashing, take the cable off from usb port, and plug back in, (Close m.prog before that). Also check that your computer has not taken a new comport for the cable, other than com1 wonīt work. (my computer changed the cables com port to com28 after flashing, and had to set it manually after that to com1).
    And I donīt have any knowledge of that old connection, I have E60 bmw, and it has the new OBD2 connection. If you have the old one, you should try to find a person that has made this modification to 20-pin adapter.
    Check the Locumīs post in the beginning of this topic, there is picture how to connect to old OBD-port.
  5. #55
    Nov 2010
    Madrid(Spain)
    e39,e46
    Only change those:
    I / O CONTROLS
    c0 rxtled
    c1 txled
    c2 poweron
    c3 poweron
    c4 sleep
    I tryed the invert by hardware, solding the two points, RI# AND GND (not DI, IS RI, no??)
    I have unchecked all options in Mprog and programmed the chip.
    i have interface in 1 com port and latency in 2msg.
    I tryed to disconect the interface after each step, but still my INPA DOT Baterry ARE BLANK without connect at the car or connecting at car.
    I think the chip is damaged... but... if i invert DSR both dots in INPA are BLACK connected at the car or not.
  6. #56
    Finland
    525dA E60
    If you are using BC546 and the resistors are the right ones, you have made a mistake in soldering the components or the npn transistor is damaged. Check, and recheck everything.
    Be sure that the 4K7 resistor is in +5 volt that comes from computers side, AND THE C-LEG IS IN THE LINE AFTER THE RESISTOR!
    If you have connected it before 4k7 resistor, you might have fried the npn.
    It should be like this: +5volt->4K7->C-leg>-Pin9 of FT232RL
    Try to find a camera, and take a picture of your cable.
    Sorry, but canīt help you more if you have done everything "by the book"
  7. #57
    NJ
    2003 325i 4D
    What wattage for the resistors?
    Can anyone tell me if 1/8 Watt (0.125W) nis enough for the 4.7 Kohm resistor? That's what my local radio shack has, and I don't want to order online, and they have 0.250 Watt for the 10k or higher.
    Thanks for any replies!
  8. #58
    Finland
    525dA E60
    Quote Originally Posted by evotronix View Post
    Less watt means that the resistor is less heat resistant, but its more compatible for low amper applications. The 4k7 is better to be a 1/4, cause your USB-port +5volt wonīt give much ampers.
    I bought 1/4 watt resistors, and they work fine with this cable modification. Take the 1/4 watt ones. (.250) and you wonīt have any problems.
  9. #59
    Jun 2010
    Isafjordur, Iceland
    '99 e39 540i Shadowline
    Could someone post a link to a cable that does include the chip ? I've looked at some cables on ebay and asked if the chip is included but no one answers. Thanks!
  10. #60
    Finland
    525dA E60
    Quote Originally Posted by geiristudio View Post
    Hi, allmost any 409.1 KKL VAG-COM cable (USB) has either the RL/BM chip, so if the connector is blue in color, it should have one of the compatible chips you can modify to your needs. Its all the same witch chip you get, the chips pinout is just different.
    It is possible that you might get a cable that has totally different chip technology too, so do not blame me if you get a cable that can not be modified.
    That cable from the link should be modified:
    http://cgi.ebay.com/ebaymotors/VAG-COM-USB-KKL-409-1-cable-AUDI-VW-OBD2-OBD-2-/250667563984
    (I have that cable, and works perfect)
  11. #61
    Romania
    e999
    actually , any vag409 will do, price is 6-8$/pcs from china , there are 2 blue versions.
    version1
    version2
  12. #62
    Apr 2009
    UK
    BMW E63 M6, RR L322 4.4
    anyone tell me how they get dis to work with this cable ? i have v57 in the vmware image but very stuck - no connection?
  13. #63
    Finland
    525dA E60
    Quote Originally Posted by pyro225 View Post
    Hi.
    http://forums.bimmerforums.com/forum...php?p=20157823
    Follow that guide, and you WILL NEED the BMW Head Emulator 1.2 software, try to search the forums for that.
    I know that the V44 (M5-board.com) "easy DIS v44" still has the Programming function, the later versions do not have them, so try to find that package.
    btw the isntallation is very hard to get to work if you donīt know any UNIX..
  14. #64
    Jun 2010
    Spain
    E39 530d
    Hi.
    You don't really need diaghead emulator, installation is not that difficult i made some video tutorials but in spanish language
  15. #65
    Feb 2009
    France
    BMW 325 TDS E36
    Hi, I have a question please :
    I have a FT232BL chip.
    I soldered everything to make the ignition detection work.
    But something seems to be bad : the when I check the solder with a ohmmeter (?) it seems PIN 20 and 21 are wired...
    Is is true ?
    When I check my solder on the pin 20, I don't think I soldered 21 too...
    THank you for your help !
    Edit : I checked again, I scratched a little beetween pin 20 and 21 with a needle ... I now there not wired anymore...
    Edit again : IT WORKS !! YES !! INPA detects Battery and ignition !
    Thank you for ALL !
  16. #66
    Nov 2010
    Madrid(Spain)
    e39,e46
    please, someone open the BMW 20-pin connector and tell me when cables
    go to the skewers.
    I have 4 wires, so that:
    1k
    1L
    1 12v battery power
    1 GND
    As the power of this cable have avoided it?
    someone I open one and count the wires passing through the cable please?
    you delay 1 minute to remove 2 small screws and check the cables of the connector!!
  17. #67
    The Netherlands
    BMW 330CI DropTop
    go to the skewers.
    1k
    1L
    1 12v battery power
    1 GND
    I have:
    pin 15: red wire
    pin 19: black wire
    pin 14: orange wire
    pin 16: brown wire
    pin 16 and 20 are connected to each other.
  18. #68
    Nov 2010
    Madrid(Spain)
    e39,e46
    Quote Originally Posted by Beemer187 View Post
    I have:
    pin 15: red wire
    pin 19: black wire
    pin 14: orange wire
    pin 16: brown wire
    huuummm your circuit of real ignition detection runs well?
    you tell me pin 16(ingnition) go with pin20(ISO 9141-2 K Line)...
    you should have the pin 17 and 20 together
  19. #69
    The Netherlands
    BMW 330CI DropTop
    I've checked it again....
    Forget pin 16. you were right, pin 17 & 20 together, my bad.
  20. #70
    Nov 2010
    Madrid(Spain)
    e39,e46
    I NEED Someone with DIS fully configured vmware and it works, and interface
    INPA correct:
    1-NO CONNECTION TO CAR INTERFACE
    2-Opening IFH-service.exe
    3-Connecting the interface to your laptop ONLY!
    4-Open VMWARE AND EXECUTE DIS
    5-CODIFICACION/PROGRAMATION
    6-CAR MEMORY
    7-forward arrow (below right)
    8-When say we put the contact ON and it will start
    automatically detecting the car, NOT EVEN THE INTERFACE TO CONNECT
    CAR, only the laptop, I repeat, only the PC, we give the following ...
    9-He will say that is reading data, what is the error ????
    it said the following?
    "Control unit description file not present?"
    "Please insert CD and repeat process present!"
    10-Just let go you back ...
    Well, that's what I want you to try, if you give that error, because I now
    until this weekend I can not test the car in front and I have the theme
    sw and hw prepared to reach out and connect and do not go setting sw.
    I ask this because I think that gives a rare error that says insert a cd ŋ?
    if I have not even connect the interface to the car!
    PLEASE try it, try it you delay 5 min
    THANKS
  21. #71
    Nov 2010
    Madrid(Spain)
    e39,e46
    Now works correctly DIS
    I enabled 'Follow me home'
    But even with it on, if I open or close the car, still do not turn the
    lights.
    Anyone can tell me if so when you have to turn on lights, or
    While that option is to give the high beam lever without a key on?
  22. #72
    New York
    E53
    In order to trigger the function, once you have parked that car, stop the engine and pull the high beam lever towards you (just like you would flash it). It would stay on for the preset period of time, even if you lock the car. It will then turn off after the preset time has elapsed. In addition, you can code which lights are on for this function.
  23. #73
    Feb 2009
    France
    BMW 325 TDS E36
    Hi,
    Just a question, I did the real ignition mod, but battery is always ON when I plug the cable to the computer... the cable is not plugged to the car.
    Ignition detect works well, but battery always ON. Is it normal ? Or can in be a problem ?
    Thank you !
  24. #74
    Nov 2010
    Madrid(Spain)
    e39,e46
    Quote Originally Posted by Orphee View Post
    Hi,
    Thank you !
    your cable it's ok, it's normal!!!
    Thanks chas3!!!!!
  25. #75
    Feb 2009
    France
    BMW 325 TDS E36
    Hi !
    I can read somewere latest BMW use D-Can interface... It means this cable does not work for them ?
    We must buy a D-can cable ?
    It is really more expensive than KKL cable :s
    Thank you
