Page 24 of 24 FirstFirst ... 1415161718192021222324
Results 576 to 585 of 585
Thread: E36 M3 Sedan + LS1/T56 + Samberg Kit
  1. #576
    Feb 2008
    Ventura - Baltimore
    01MCoup-02WRX-04MCS-86TV
    if there are any questions... im the current owner of the car... thanks!
    1999 - S52 - E36/8 - Alpine White over Imola Red
  2. #577
    Mar 2019
    Milwaukee, WI
    '99 LS-swapped 323i vert
    Nice! I believe you had better update the "My Cars" part of your profile!
    Diving in at the shallow end!
  3. #578
    Jan 2024
    Atlanta
    97M3, 95s14, 02s2000
    I am the owner of this car now, is there a way I can message the previous owners regarding questions I have. I have a brand new ls2 on an engine stand ready to swap in
    Can I ask you some questions? I’m the new owner
    Can we chat somewhere about this build as I am the current owner
    Quote Originally Posted by samtrak View Post
    I have some questions about the front suspension
  4. #579
    Jun 2004
    PA
    Too many to list...
    Blast from the past!
  5. #580
    Jan 2024
    Atlanta
    Quote Originally Posted by douglee25 View Post
    I know dude I really want to get this thing back to it’s original glory but there are just some unknowns
  6. #581
    Jun 2004
    PA
    Too many to list...
    What are you struggling with?
  7. #582
    Jan 2024
    Atlanta
    Was wondering if the car was ever wrecked or “tweaked” in some way. The front passenger side wheel sits deeper in the wheel well. Compared to the drivers side it looks less offset. Haven’t gone underneath it with my tape measure but it looks straight underneath. Visually it’s fine underneath, but looking at the wheels from a short distance I think it’s noticeable. It aligns perfectly it’s just bothering me that it’s like almost 1 inch difference in offset. The wheels are identical. Would like to know before I spend a good amount of time on the swap.
    both the spindles are original m3 part numbers stamped on them. Just can’t seem to find where the difference is. One bearing looks like it was replaced and the other one original but I have a hard time thinking that would cause that much of a difference if it was the wrong part# used or if that is even possible.
    maybe one of the previous owners could chime in if they ever noticed it or know anything that might have happened.
  8. #583
    Jun 2004
    PA
    Too many to list...
    A couple things to verify -
    1. Verify the struts and springs visually look ok... Same number of coils, not sagging, etc
    2. A common mod was to swap the upper spring hats from one side to the other to gain additional camber and make the car corner better. Could this have been done? Was it done correctly? Are the springs and cups seated correctly?
  9. #584
    Jun 2004
    PA
    Too many to list...
    I didn't reread the entire thread, but in it he talks about using non-M3 control arms even though it calls for true M arms. That I believe changes the caster on the car.
  10. #585
    Jan 2024
    Atlanta
    good catch, I think the owner before me but after these guys mentioned he replaced the control arms. I’ll get under it later and check if the proper parts were used today. Thank you for your help, wasn’t aware of the control arm differences so now I know to look for that. Will report back.
