so after putting my engine back in the battery light decided to stay on once the car turns off. once the car starts it goes off but when the car isnt running and the key is out of the ignition it's on and it kills the battery
'83 320i in the works
It's probably the ignition switch, but it could also be the flippin' hazard switch. When it happened to me it was my hazard switch, but it seems the ignition switch is more common.
ok thanks i will check it out
I've never tried this, nor do I know what would happen, but did did you plug the excite wire into the correct spade on the alt?
Tbd
wasnt there only one spade to plug it in? any pics of the alternator for an 83 and the correct hookup?
+1 on checking the correct spade, this has happened to me before and that was the problem for me.
BMW for life.
ok i will check that thanks guys
The correct spade for the blue excite wire is the one closest the the charge post.
The other spade is for a capacitor (reduces radio noise), which is not required/sometimes missing.
I'd post a pic but my image server has been down a few days
Tbd
ok i will make sure of that tomorrow.
That is a logical place to start, since you have apparently been working in that area and could easily have connected it wrong. If so, relax, you aren't the first guy who has done that!
I had a similar symptom when I first got my Baur running, and it turned out to be a bad resistor or capacitor (I am no electrician) in the voltage regulator, which is on the back of the alternator. The automotive electric shop diagnosed it on the phone. I pulled the alternator, and they fixed it quickly.
Good luck, and let us know how you make out.
Tom
SE Connecticut
1982 323i Baur, 1977 320i (carbed),
1978 320i (parts)
1991 325ix 5 speed, 1989 325ix (winter),
1989 325ic (summer)
1973 2002 Malaga (with frosting)
1975 Mercedes W115 300D (The Departed)
the late 1979 323i Euro (project, Now Departed)
Visit my blog: Baurspotting
http://baurspotting.blogspot.com/
BWR PWR!
I just had this issue yesterday and mine was an alternator. I had issues over the weekend and thought it was my alternator so I swapped out one from my parts car. Ended up that one was bad and a had a wiring issue but once the wiring was fixed and my alternator was in it had the battery light on so I swapped my old on back in and it fixed the light and the car fired up.
83 BMW 320i
76 BMW 2002
sweet thanks guys i will let you know if it fixes it
Sweet the light has gone off. Thanks guys. Now I need to figure out why my temp guage isnt working and that's it. my car will be back to 100%
bump answer to the above question that seemed to but put on my last post:
"Sweet the light has gone off. Thanks guys. Now I need to figure out why my temp guage isnt working and that's it. my car will be back to 100%"
I read this thread yesterday and this morning went out to the car and found the battery light on! Pulled the air box, found the wire (red). As I removed it the wire fell out of the connector. clean cut, new connector, box in and zoom. Wasn't even late for work. Thanks forum!
