Results 1 to 25 of 66
Thread: Rear doors coverings trim (exterior trim) - cracked rubber
    Sep 2009
    Bvlgaria
    04/2001 €38 730dA
    I need some sound advice amigoes ... the rubber on those Rear doors coverings trim - (exterior trim) (#3) is so cracked - i really hate it .... but the OEM parts new ones are quite expensive. Are they 1 piece with the rubber? I think there is nothing that can be done to replace the rubber only??? How about if I remove it carefully - will it be OK for the water to go there? Wont this mess the car? Wont the clips that hold it be seen a lot if the rubber is removed?
    How about black silicone or hot glue?
    Any other ideas?
    Actually how are those removed?
    03 COVERING LEFT SCHWARZ 1 51138208405 $109.37
    03 COVERING RIGHT SCHWARZ 1 51138208406 $109.93
    Pittsburgh, PA, USA
    06 530xi E61, 1993 850Ci
    Sep 2009
    Bvlgaria
    04/2001 €38 730dA
    I really have not seen these fixes - I posted in one of the threads and forgot about it.
    So there is a solution - I see Timm fixed his SICK Individual - gotta try something.
    Thanks for the links Mo.
    Sep 2009
    Bvlgaria
    04/2001 €38 730dA
    Gents I think I have found a very elegant solution very, very close to the OEm look and qualit
    May 2010
    Winnipeg, MB, Canada
    9/94 740i, 5/06 X5 4.4i
    Post up pics when you're done. I'd like to see this.
    (9/94, GF61, JPN: M60B40, ZF 5HP30, 3.15:1)
    (5/06, FB53, US: N62B44, ZF GA6HP26Z, 3.46:1)
    Calgary, Alberta
    2014 320i xDrive
    I'm interested in this as well. Mine aren't too badly cracked, but it's bad enough, so if there's a nice cheap solution, that would be great!
    2014 320i xDrive, Alpine White on black
    Sep 2009
    Bvlgaria
    04/2001 €38 730dA
    OK.
    Livermore, CA
    2000 BMW 740il Aspen Silver, 2005 X5 Titanium Grey
    Interesting......I might try.
    PDX baby!
    The whole car lot
    I have my pieces off currently shadowlining them and tore the rubber off as it was done with. Can you show a pic of exactly which one you think will look right and how you are putting it on the piece? Thanx all the stuff above is a little confusing.
    2dam ez!
    Nov 2008
    Amsterdam NL
    735i 2001 E38
    Make a write up on what you get and how it looks!
    Have a technical question, don't send me a PM but post it on the board so others can benefit from it!
    Jun 2010
    The Beautiful Chile
    1998 740i - 2009 318i
    7Breyton:
    Looking forward to your pics!!!
    I have the same problem so I would love to see your results.
    RGDS
    Pedro
    Sweet Car of Mine, You make me so happy...
    '09 E90, just clean
    '98 E38, Oxford Green, new 18" wheels, new tires, new front & rear suspension, new rear struts
    New tail lights, new headlights, 6000°K xenon lamps
    New Zimmermann rotors, Akebono pads, new valve cover gaskets.
    New spark plugs, new MAF, new Lambda sensors, new ICV, new camshaft sensors
    New Radiator Hoses & Coolant Fluid, new steering hoses, new OSV valve, new TPS, new ASR sensor.
    Icebox Owner&User, Leather seats treatment & restoration
    This is definitively a endless list.
    Sep 2009
    Bvlgaria
    04/2001 €38 730dA
    Thanks guys - I will post pics soon. I'm also excited/ all the piks above are examples of the rubber seal types I found. the one that is for us is great - super OEm look.
    it is on the smallest pik above in the middle.
    I started thinking of actually doing the trim all over the sides + the rear window - there are gaps all around. What do you think might be the problem if I put rubber trimm in all around. i tried it today and it looked pretty good.
    my car is durty, I still dont have the exact seal size (I have 1,5 and 4 - I need number 2) and cant upload piks from my stupid laptop. but once i get it done there will be a ton of pics.
    May 2010
    The kaixinseals.com pic is the type of stripping you will use?
    PDX baby!
    The whole car lot
    Still don't have a clue how any of those would fit and look right, please post up some pics w/ the stuff your using and how it is fit on. TIA
    2dam ez!
    Sep 2009
    Bvlgaria
    04/2001 €38 730dA
    I have just received the 20 m long rubber seal that I think will do the job.
    My car is not close to me now. But the one that is almost like the one I got, is on this pic below at the lower left corner.
    Once I install it, I'll do a full pictorial.
    I think to put this seal all over the car sides not only like the small strip where the original rubber was. Also I think to put it on the rear window as well. I think to use black silicone , but it sticks pretty good even without any silicone.
    Ireland
    2005 E66 740Li
    Nice, can't wait for pics.
    Sep 2009
    Bvlgaria
    04/2001 €38 730dA
    Nice
    Ireland
    2005 E66 740Li
    Holy crap, looks great! Any online source for this stuff?
    Sep 2009
    Bvlgaria
    04/2001 €38 730dA
    No idea dude. I'd love to send you some but you guys are far away. I still have not glued it/siliconed it. Will post more when i finish it.
    What do you think of doing the trim all around the sides and the rear window?
    I still can not appreciate it 100%. And I'm seem to be turning in to a OEM freak - so not sure if i will do it. may be only the rear as the original was on the sides and the rear window . Any thoughts?
    Ireland
    2005 E66 740Li
    I'm closer than most, i'm in Ireland! I'd only replace what needs to be replaced to be honest.
    Aug 2008
    Austin, TX
    2001 E38 740I Sport
    It turned out great. If it were me, I would leave the rear window as is. since water from the roof goes in that channel and drains trough the side but it does look good.
    -Messan
    The above is my 2 cents. Take it or leave it.
    01 Shorty Sporty BLK/BLK
    Jul 2010
    Sarasota,FL USA
    98 BMW 740iL
    Where did you get this stuff from, and if you got enough interest would you be willing to buy enough for a vehcle and ship it out to us. Maybe a Paypal to you and you ship to us kinda deal. Im pulling mine off to shadowline and would love to replace the rubber. Mine was pretty cracked i cut it all out...
    PDX baby!
    The whole car lot
    I think it looks great every where you put it, the only thing I would worry about is water draining properly where it is supposed to. I don't think you would have a problem though, if anything it might seal up better! LOL
    Quote Originally Posted by 7BREYTON View Post
    Where did you get yours? Locally? What kinda store? What is the rubber made for? Automotive, door seal, house windows, etc? Thanx
    2dam ez!
    Sep 2009
    Bvlgaria
    04/2001 €38 730dA
    2
    PDX baby!
    The whole car lot
    I say do it just don't silicone it, if any issues show up pull it off. What kinda store did you get it at locally? Auto, home improvement or what?
    2dam ez!
