Feeler: Custom Stage 2 Turbo Kit w/ AA tuning - OBDI 400+ rwhp
I am putting out a for sale feeler for my custom stage 2 turbo kit. This kit was originally assembled and installed by fellow forum member DavidTm5, I purchased it from him complete about a month ago with the intentions of installing it on my 1995 M3. My plans have since changed -- see my OT thread on buying new boat. I am now looking to sell the kit almost exactly as I received it.
The kit includes the following parts (under 2000 miles on all parts);
1. Garrett T3/T4 Turbo - STAGE 5 wheel w/ 70A/R hot & 82A/R cold - journal bearing
2. SPA MANIFOLD with external 38MM TIAL Waste Gate.
3. Full 3" exhaust including; down pipe with wastegate inlet, magnaflow resonator, vibrant muffler, 2x 02 bungs & sensors w/ vband joints. 1 cut will need to be welded or vbanded for re-installation.
4. Garrett Intercooler (you will need to source mounting brackets)
5. Bosch 803 MAF w/ harness, 550CC injectors & Complete 506 ECU w/ Active Autowerke Stage 2 Chip -- OBDI Plug & play tuning.
6. TIAL Blow Off Valve, 3.5" cone air filter and all hot side and cold side piping. Minor damage to cone filter.
7. Oil feed line, oil return line, oil distribution block. (you will need to source fitting for oil pan)
8. Cooling mist water/meth injection kit w/ trunk mount tank. (lines will need to be sourced locally)
9. Complete single PLX multi gauge kit (boost/afr send modules w/ data logging control module).
10. TRM Motor Mount (not part of original kit)
The only thing NOT included is a Walbro fuel pump, which I have already installed and will not be able to include. You will also need a .140 MLS head gasket & ARP head studs to run the kit at the current boost level (~12psi+). David claimed it produced around 400-420 rwhp as currently configured. I am told the turbo is the same size as the GT35R except does not use ball bearings. Offers an easy upgrade path to GT35R down the road. Can provide more pictures for serious parties. Will accept paypal but must be of type personal, or you pay all paypal fees.
Note: current piping requires A/C deletion but with included turbo mount, some piping could be redone to retain A/C.
ABOVE PICTURED FUEL PUMP NOT INCLUDED
z0lt3c
Current:
2013 Ford Edge SEL AWD
2012 Jeep Grand Cherokee 4x4
Retired:
95 M3/5, 96 328is/5, 97 540iA, 98 528iA, 01 X5 4.4iA, 02 330cic/5, 03 325xiA, 04 530iA, 92 325iA/S50, 08 535xit
