Bavarian Soundwerks
Results 1 to 8 of 8
Thread: E36 M3: 6 CD Changer Woes
    Oct 2008
    Chicago, IL
    '04 330i ZHP 6spd
    I just picked up an E36 M3 the other day. The radio was locked out. I got around to obtaining the unlock code from the dealer and after having the radio on for an hour was able to unlock it. Radio works, buttons are a little faded and it seems like I have two blown speakers (front left mid and rear left). Then I hit the trunk up so I can load some CD's and the magazine wont eject. Funny thing is, the eject button doesn't even have power. I hit "band" on the radio to switch from FM/AM to CD and I got the "Disk Error" message.
    I checked fuses 9 and 44. They are fine. I unplugged them for an hour, put them back in, tried again, no power to CD changer.
    What should I do next?
    I'm really just thinking I should get a CD43 and the BSW speaker package... call it a day. But for now, I just want to play some CD's with what I've got.
    Any help is much appreciated. Thanks!
    Los Angeles, CA
    Various Prototype BMW's
    Try disconnecting the smaller, 3 pin connector from the rear of the changer. Let the changer sit for a good half hour, then plug it back in. Any signs of life? If not, there may still be a fuse on the back of the changer depending on how old it is.
    Check it out, and let me know what you find.
    Jason Seaver | Founding Partner | Product Engineer
    e: jws@bavsound.com
    Bavsound | Audio Solutions Engineered Specifically For Your BMW
    www.bavsound.com | 404.381.1800
    Oct 2008
    Chicago, IL
    '04 330i ZHP 6spd
    Roger that. I'll report back either tomorrow or day after. Thanks.
    Jun 2010
    The Beautiful Chile
    1998 740i - 2009 318i
    Please note that the 6 cd changer has a fuse of its own that is between the 3 pin conector and the unit, check that fuse.
    Regards,
    Pedro
    Oct 2008
    Chicago, IL
    '04 330i ZHP 6spd
    Thanks. I will check that fuse also.
    Oct 2008
    Chicago, IL
    '04 330i ZHP 6spd
    Alright guys, checked the fuse behind the CD Changer and it is good.
    Attached is a pic of the cables hanging off behind my CD Changer. Which do I unplug? Or do I unplug the cables that are plugged in directly to the back of the CD Changer?
    Please advise.
    Oct 2008
    Chicago, IL
    '04 330i ZHP 6spd
    I unplugged the 3-pin connector with the red and brown wires (only 2 wires on it) overnight, right before bed. Woke up in the morning and plugged it back in. Still no power to the CD changer.
    Is there anything else I can try or should I start looking into a CD43?
    Oct 2008
    Chicago, IL
    '04 330i ZHP 6spd
    Bump.
    Is there anything else that I can try to make the CD changer work or should I just get a CD43?
