John,
Unfortunately the pcms had a different chip set and programming. There is one ecu that has both dbw and cable throttle. Came out in 02 or 03 in chevy trucks and vans. Mind you, not all of them... I've only ever had one. Maybe the truck pcm would work and have can bus capabilities? But I do not know for sure.
Paul
Also late 06 they started with the 58x reluctor wheels that require a converter or a pulling of the crank.
a lot of the time when an aftermarket reader of any kind says "can bus" or related it actually means the single wire k-line communication as well - very few systems that I have seen work exclusively on can bus as CAN is inherently universal but also not at the same time - different manufacturers use different addressing schemes and what not - similar to k-line systems but hte k-line systems followed more of a defacto standard then what i've seen in the CAN bus systems.
if it says "OBDII" or similar it will likely work on k-line as well as CAN bus.
Good info to know!
John which data aquisition set up were you looking into?
John, not sure what exactly you are looking for in engine data logging, but have you seen this? http://www.scantool.net
I got their most basic kit for use with car pc that I still haven't started yet and I believe they have data logging as well. I think there is also a separate GM specific add-on too.
Might not be everything you look for, but its cheap enough to try compare to adopting 06 pcm.
He's lookingfor a race car data aquisition system. Real time data aquisition with gps data plotting etc.
Paul described it best. I'm looking to integrate rpm, temps, pressure, TPS etc with track mapping and Gps data to evaluate where I could do better on track and reduce lap times.
Aim Pista or Racepak type hardware. I'll try to find a link to some of the stuff that can logged shortly.
Great info so far though. Just learned more in these few posts than I thought.
John.
An example:
John
John
E36 LS3
Changing the computer to the version you want is going to be a lot less fun than you might imagine. The biggest problem is that the new computer (usually called an E38) is for a 58x reluctor wheel and you have a 24x reluctor wheel. You can buy a converter, but that just adds another layer of complexity.
Rob
Prior projects:
1998 540i with 6.6 LS2/T56 Chevy Power
- pictures and details
1992 325i with 6.6 LS2/T56 Chevy power - pictures and details
1995 M3 with 6.6 LS2/T56 Chevy power - pictures and details
Totally forgot about the reluctor differences. At this point, its prob. Easier to wire in duplicate sensors to feed the logger. Thanks all.
John
E36 LS3
Rao, Correct me if I am wrong.... the converters do not go from 24x to 58x, but the other way around to convert to Cable Throttle.
John,
Here is some more info on getting the Racepac stuff to work with the LSx swap.
http://www.lateral-g.net/forums/showthread.php4?t=16833
I know it's geared towards older muscle cars but the principles are the same.
http://www.lateral-g.net/forums/show...46&postcount=9
This post pretty much sums up what I was afraid of, but seems like the easiest route to go.
Their online community seems helpful as well:
http://www.racepak.com/forums/
As a side note, take a look at this Silver State Classic and One Lap Contender: http://www.onelapcamaro.com/
My old FBody is a long ways of from that caliber of a build, but we can all wish.
Another thing related to the whole CAN bus thing: http://www.isispower.com/
This is an aftermarket product that came to the market in the muscle car crowd to work with CAN bus systems. It might be a way to integrate it into a can bus car with some trick programming.
Rob
Prior projects:
What is the IGN relay? Is that the DME/ECU relay?
ign is 12v when the key is on at ignition - and at start - it's run power for most accessories (via more relays in some cases) and is run power for the DME/ECU & various other components
dividing signal is one thing - measuring signal and multiplying it to get higher resolution is asking for problems
I have another question regarding the DME relay. I am trying to figure out which red/wht wire I should be tapping into for the switched battery wires/connections. What does the 87 wire connect to and what does the 87a wire up to?
Did I scare everyone away by asking too many silly questions?
On most 5-pin relays, the numbers are the same, no matter what manufacturer and are as follows
30: +battery or other incoming power
87: a "normally open" contact that connects to pin30 when the relay is energized
87a: a "normally closed" contact that dis-connects from pin30 when the relay is energized
85: +voltage incoming control signal from a user-operated switch or the PCM or other power source
86: a ground for power coming from 85, which allows the control coil in the relay to energize; some are direct to ground or the PCM provides ground
When reading an Electrical Troubleshooting Manual, with few exceptions the power "flows" from top to bottom of the page, per SAE standards. In a few cases, the PCM provides the voltage, so the power may "flow up" the diagram
E30-LS1 Swap Guide and Kits, email us at e30ls1@gmail.com !!! or check our website e30ls1.wordpress.com
Thanks. So by that reasoning, I want the red/white on the 87a to be attached to the switched battery wires, such as starter and pcm ignition supply? If so, then what do I do with the red/wht wire that goes for the 87 NC contact?
If you don't need the NC contact for anything, pull the wire off & don't use it. A nice example of a 5-pin relay being fully used is the (3) relays which give 2-speed cooling fan control: the middle relay switches the fans from low speed to hi speed by changing the fans circuit from two fans in series to two fans in parallel.
While buying relays for my harness, I noticed what you were mentioning, Garret. Some relays were more universal, and had extra contacts on it that could either be used or not used, depending on the application. I guess I was forcing my mind too much to think that it had to have a purpose/use, since it was there.
What's the easiest way to wire up the reverse lock out wires? Did you guys wire it to a switch inside the car that you activated before reversing each time, or is there a way to make it like the factory set up, where it's triggered automatically at a certain speed. Mine is currently locking up just with the car on and not moving.
the GM PCM has a variable for the rear gear ratio as well as tire sizing. a lot of the torque output calculations (which is almost entirely what the engine in the end runs off of - requested torque & measured torque output) are based off of those numbers but as long as they are all off together (ie requested & actual) they skew doesn't really cause any problems in the long run.
long story short - just change it with HP tuners and go on your way
This is a great read Pzary, covers a lot of hard to find info on the E36 wiring!
Quick BMW A/C question - does the E36 control the A/C via the DME? Or is it simply an input to the DME to make it know to idle-up, and perhaps change part throttle maps for the additional load? If it's completely self-contained (like it is on my Volvo for example) then you can delete ECU-controlled A/C altogether from the GM ECU. Perhaps I'm just incredibly lucky, and for my Volvo, the only thing I will need to connect is the compressor to the compressor relay. The factory ECU does nothing with the A/C, and the GM ECU is plenty smart enough to detect the additional load and idle up on demand.
Thought this would be an appropriate place to link my Google DOC's spread sheet documenting the pin outs and wire connections for my swap. For reference purposes my car is a 99 e36 323is automatic. The engine is an LS1 from a 2002 Trans Am with T56 manual. Please let me know if you see any mistakes or have clarification to add and I will update the file. Happy wiring!
https://docs.google.com/spreadsheet/...2JyUFFVaVdWS3c
Thanks for the added info!!!
