I'm not sure what the US term is but in the UK it's usually as Towbar. Anyway, whatever it is, I have one for sale. it comes with all the bolts and fixings, and with twin sockets (in the UK we have 7-pin and 12-pin versions for trailers and for caravans resp.).
It is a detachable one which means with a couple of 19mm spanners you can remove the ball but the mounting remains in place, which is only really useful to preserve the looks of the car so I wouldn't bother.
You'll need to cut a hole about 2 inches diameter in your rear bumper to fit.
It looks much like this:
And I'll be asking for $100 + shipping @ $100 = $200 all in, ready to fit.
Let me know if there is any interest.
...he answered and said, I believe that Jesus Christ is the Son of God. Acts 8:37
Currently/recently dismantled:
Breaking: E8 Neue Klasse 2000; E21 316; E24 635csi, 635csi Highline; E28 528i x3, M535i;
E30 316i, 316iT, 318i, 318is, 318iT x2, 320i x3, 320i Cabriolet x3, 320iT, 323i Baur, 325i x2, 325i Sport x7;
E34 518i, 520i, 520iT, 525i M20, 525i Sport x5, 525iX Touring, 525tds, 530i V8, 535i, 540i, M5 3.6;
E32 735i, 750i, 750i Alpina; E31 840i; E38 728i x3, 735i Sport, 750iL;
E36 318ti Compact x3, 318i, 318is, 320i, 323i Touring, 325i Cabrio, 325tds, 328i Cabrio, 328i Sport x3, M3 3.0 x2, M3 Evo;
E39 520i, 520i Touring, 523i, 525tds, 525d, 528i Sport x3, 530i Sport x3, 530d Sport x3, 535i x3, 535i Sport, 540i, M5 x3;
E46 318i x4, 318ci x3, 318ti, 320d x4, 320d MSport x3, 330d MSport x3, 330i MSport x2, 330ci Cabrio, 330ci MSport x3;
E53 X5 3.0i Sport x2, 3.0d Sport x3, 4.4i, 4.4i Sport
>BMW Euro parts website< >willswheels.co.uk facebook page<
I'm interested. I'd love to know how much it weighs, and shipping cost.
Also, is there a max towing weight for it?
No current BMWs.
1994 Roadmaster Wagon
1974 Alfa Romeo Berlina
Was it you that asked me to find you one before? A couple of people have mentioned them.
Max. towing weight should be rated at the same as the car itself, 1600kg, with a 50kg noseweight.
DHL are not being complete arses and I can ship it express for 100 bucks.
Looks kinda rough but kinda cool, Is this the factory bmw towbar?
On real oem it says the factory unit is a class III hitch.
Quality BMW service "street, track, race"?
Email: ZakspeedRacer@gmail.com
1999 BMW 318Ti/M Hellrot Msport DD/Fun car
1/2 1987 BMW 325is/M Future Spec e30 (track prep'd)
1994 530It/A Alpinewise III Traded out
1988 BMW 325ix/M Diamond Schwartz Recently sold :/
1986 BMW 325e/m Bronzit Beige Metallic
Get Involved!
www.bluegrassbimmers.org
OKI BMW Facebook group
BMWCCA Member# 436428
I had a CL III hitch. It had a removable ball and looked a little different. Not tryin to crap on your thread, but that does not look like a CL III hitch.
I can't drive automatics.
As far as I know it is the OEM hitch - certainly looked like it to me.
The car it came off had 206,000 miles so forgive it a bit of roughness! It's solid though.
There's no class regulations in the UK like what you have - but a towbar sold here must meet the towing capabilities of the car, hence even if it is an a/m bar, it still has to be rated to 1600kg like the E34 is.
Oh, maybe just to quell any worries, I have a very similar Bosal a/m one on my touring, and I've hauled a 1.6 ton load with it (compact car and trailer).
This is what is called a BUMP.
P.s. I also have a sedan hitch lying here somewhere, and an E36 saloon one...
What is the diameter of the ball?
Bump up again. I'd like to open this up to reasonable offers, especially as I now have another one...
Available:
TWO Touring hitches
ONE sedan hitch
and here's the second Touring hitch...
I have the 1993 touring 525it. Can you ship this to Cincinnati, Oh 45220?
ACUF
I can indeed, as in first post, $100 for shipping to North America.
You can't PM yet so let me know your email address and we'll talk there
Yeah baby, lets DO this!
I photographed the removal of a Touring hitch, so if I post the pics in reverse, we should have a fitting guide. Let's go.
Start with a Touring, for a start. Say hi to my black '93 525i. Which, incidentally, left my ownership the same day the tow hitch was removed, swapped for a Alpineweiss II 730iA.
Next, look inside your spare wheel well. Find the plastic covers and remove. There are two at each side, the two on the left being around this triangular piece of body-shell.
You'll want to now take your rear bumper off.
After that, look at the inch-high recess under the shut-line of the rear hatch. In there, in line with the holes you just exposed in the boot, are four punch-out holes in the bodywork. Simply take a bar less than an inch diameter, and a good hammer, and knock them out. They are where these bolts go through:
These bolts go through a 3/4" by 6" slice of metal including in your fitting kit, which acts as a washer and load-dissipater.
These bolts are through a u-shaped piece of metal which in turn is bolted to the bar of the hitch - pretty straightforward.
next, underneath and behind where those bolts went through (some crawling on ground required)... looking directly up from underneath...
another 17mm bolt goes in here. There are holes pre-drilled and pre-tapped for this.
And at the two ends of the main bar there are two 'wings' as you can see in the first post in the thread. Again pre-tapped holes to fit to - the rear is another 17mm, the front is a 13 or 15mm for some unknown reason. Be careful of your exhaust, it may be hot, and most likely in the way.
And then I will leave the fitting of the removable hitch up to yourselves - two 19mm (or 21mm) bolts through, which must be solid, and drill a hole or cut a slot out of the rear bumper, depending on application.
All happy now? Good. Peace out.
Hey Will, I just installed the hitch this morning, easy-peasy. Took about 2 hours total, minus cutting a hole in the bumper and reinstalling.
It was super easy, and I was stoked to see that all the holes were already drilled and tapped. I used a brush to clean out the crud and then the bolts threaded right in.
The only bit that had me worried was the first part you covered. I didn't know there were punchouts, so I just drilled holes through the mount and it went fine.
Next up I need to figure out the wiring, we use flat 5-plug wiring mostly here, so I'll just splice some of that into the stock harness.
Any other ideas on wiring Will?
And for others out there, this hitch is rated to tow 2100 kg (over 4200 lbs) well more than the e34 limits.
No current BMWs.
I guess I can't help a great deal with the wiring if it's different to our 13-plug harness. There is supposed to be a punch-out for the harness to go through as well but I couldn't find it on my T...
been tidying up a bit and keep stumbling over Touring hitches...
Time for a rather mega thread bump. I found more hitches today, buried away at the back of my dismantling area! Also just took delivery of a sedan with a factory removable/lockable hitch set-up, AND have another sedan coming next week which has one as well I believe. Still $200 shipped.
damnittttttttt, i want one so bad. someday ill be back asking for one.
-Alex
Send me some pics of the Sedan and Touring hitches you've got... A buddy of mine really wants a hide-able Touring hitch, and Im thinking about putting one of my Sedan. Just have to figure out if I can make it work without cutting my M-Bumper.
I'm going to want a touring hitch as well.
I'll be in touch when finances make it possible.
Hey guys,
tried to get a couple of fresh snaps today but 90mph wind and driving rain said no.
grabbed a couple but they're not great:
how diff are touring and the sedan versions?
IIRC the sedan ones don't have the same plates that go up under the tailgate. I need to take off another sedan one so that I can remember properly! Some of them also don't have the 'wings' on th end but that could be down to whether it's an OEM piece or not...
Right, sorry about the delay. making the most of the good weather (dont get much of it here!)
Witter fixed:
Bosal removable swan-neck x2:
The cleaner Bosal is the one I had fitted to my Touring a couple years back.
