Page 1 of 4 1234 LastLast
Results 1 to 25 of 79
Thread: Timing guide rail replacement
    Nov 2009
    Los Angeles, CA
    2014 ZL1
    below is a link to BMW's TIS instructions and tips on setting the timing on an m62 tu engine.
    http://dc227.4shared.com/download/YE...tinstructi.pdf
    this link is for a writup on replacing the timing chain guides, and timing a m62tu engine.
    http://dc534.4shared.com/download/tj...uidesonM62.pdf
    Nov 2009
    CA
    01 540i
    I can host it for you whether for d/l or just to link images from. pm me.
    West Michigan
    98 540iA (Prd 11/97)
    Quote Originally Posted by nighttowl
    that would be great. where can i email it to?
    What kind of file is it?
    Fyi: precisionpoint posted that you should private message (PM) him.
    Ohio
    540i/6, 02 Excursion Pow
    "If everything seems under control, you're not going fast enough. - Mario Andretti"
    atlanta
    2004 BMW 545i 6
    Ahhhh sweet memories... looks good! To those yet to do this fun job you should probably replace the Valley Pan at this point if you havent already done so.
    Nice Job on the write up!!
    Dec 2009
    Cincinnati
    1998 740il
    I am in the same boat friday night. i might do a write up if I am not too frustrated at that point.
    Sep 2009
    The Lou
    E39 530, 540/6, E70 X5
    Quote Originally Posted by jnyost View Post
    I think it would be slick if you included a tool rental program along with the parts list.
    Most excellent DIY btw!!!!!!!!
    L.
    Laurelton, New York
    1973 BMW Bavaria 3.0S and 2003 540I6
    Thanks Nighttowl
    Links you provided were very helpful. Should be back on the road soon
    Mar 2011
    Winfield, PA USA
    1999 540i
    So guys, I'm at the point where I'm ready to put the car back together (had to replace the OSV). Missed a step when taking everything apart, so the cams and crank are going to be way out of position. Without the special tools, it seems that setting the timing will be next to impossible.
    My plan is to install the new OSV, have the crank positioned at TDC, install the new guildes and re-assemble the lower timing chain cover/oil pan. At this point in time, should I make plans to tow the vehicle to the dealership to have them complete the timing procedures? Are these tools readily available on line somewhere? Do I even bother sweating and worrying that I'll mess up the timing and bend valves?
    Kinda having an anxiety attack, if you couldn't tell ....
    Ohio
    Quote Originally Posted by Tommy O View Post
    You have to go through the timing procedure.
    You basically have three options:
    1. Tow it to a dealer/indy to have it timed.
    2. Rent the timing tools (we have them, but there's a wait list)
    3. Purchase the timing tools
    Mar 2011
    Winfield, PA USA
    1999 540i
    The procedure looks straight forward to set the timing.
    You know of anyone in the Central Pennsylvania area that would rent the tools? I suppose I could call the dealership and ask.
    Loosing my shop at the end of the month, so time is of the essence.
    Thank you.
    Ohio
    Sorry, don't know of anyone. I'd call around to local indys and dealers.
    Mar 2011
    Winfield, PA USA
    1999 540i
    Put the car back together and it runs. Did not use or have access to the necessary tools. Check engine light is on stating that timing is advanced on Bank 1. Engine still runs just fine. What's the drawl back to driving it this way?
    Portland, OR - USA
    e34, e39
    I'm not sure there is a drawl back, unless it's a southern car.
    But if the timing is too far off you run the risk of the valves kissing the pistons. Just a little off will shift the power curve and affect driveability. How does it run compared to before?
    No current BMWs.
    1994 Roadmaster Wagon
    1974 Alfa Romeo Berlina
    Ohio
    Definitely not going to be running optimal.
    atlanta
    2004 BMW 545i 6
    The first time I did this, I had the cam right, but the solenoids were not right, basically the degree wheel acts as a position sensor. just a little off on the position wheel and the cams don't "know" where they are at exactly so the computer defaults to a simpler mode. You will still need the tools to get it right... take your time and make sure your up against your stops with an ohmmeter.
    Mar 2011
    Winfield, PA USA
    1999 540i
    This might be a stupid question, but if the crank was at TDC, and nothing it hitting anywhere, the only parts I would need to remove from the engine to set the timing are valve covers and the upper timing chain covers, correct?
    Sep 2009
    USA
    any time, any place
    correct.
    CA
    2002 540I Sport PKG
    hey can you pm me and give me a price on labor for the guides. I can buy all the parts needed. I am norcal but i can drive down to socal. My car is 2002 540ispeed.
    thanks.
    BTW, I cant pm anyone here for some reason.
    Portland, OR - USA
    e34, e39
    Nader83, who are you asking? You can't PM because you need more posts...
    No current BMWs.
    Jul 2005
    Appleton, WI
    2014 435i, 2004 M3 vert
    i have the m62 non vanos tools available if anyone wants to rent them
    hi i'm nickmanderfield.com and i hang out on the internets,
    i also recently started to sell carbon fiber coasters.
    MA
    01 540i6 Sport
    Well done on this DIY.. Does anyone have a DIY for removing the heads?
    Sep 2009
    USA
    any time, any place
    Check this site to look at the TIS. should offer you some insight to head removal.
    http://tis.spaghetticoder.org/e39/
    Nov 2009
    Los Angeles, CA
    2014 ZL1
    Quote Originally Posted by frnkwhte View Post
    you have to remove the timing gear, then pull the intake off, then head bolts.
    MA
    01 540i6 Sport
    ^Thanks guys
