There are a few things I want in a boost gauge and so far the only way I can get it is if I special order it from a Wika distributor and wait 44 days (the wait isn't a problem actually).
Requests of the gauge:
• -30"-0-30psi (I like being able to see vac, shows me if there is a leak in the system. I'm never going to go over 30psi)
• Drag Pointer, Max Indicator, Tell Tale (It's called a lot of things but I want a gauge that tells me where the boost got to without looking at it)
• <$150
WIKA says they make it in a 213.53 2.5" -30"-30psi wDP gauge so I know I can get it, and they say that it's around $60 MSRP so I might just go that route.
Any ideas, recommendations, or interest if I end up having to buy several of these?
I have a SPEK boost gauge that has a lot of features. I think I paid $115, which was a good deal considering the quality of the sensor, etc.
It's a 30 to 30 gauge and will record LOW and HIGH. You can also set a PEAK and it will alert you if you boost past the set point. For better or worse, they use them in NASCAR. It's got several backlight colors as well.
I only know of one good source for them right now. I'm not sure why that is, but it's a very good gauge.
NASCAR is naturally aspirated, why do they use boost gauges? Or does the company just make gauges that NASCAR uses other than a boost gauge?
It's a pretty cool gauge, a little "elektronix" for me but whatever. It's also pretty 'spensive, can only find it for $250.
Autometer 5577 and 5677 do it but they are both more than $200
OK I just ordered a small batch run of a WIKA gauge 213.53 -30" to 30PSI white face, rear mount with a drag pointer, liquid filled.
Anyone want one? $50.
damn $50 arent they like ~30 new from mcmaster?
good gauge though
If you need a source for the SPEK boost gauge, I think they are still available for $115 shipped.
The SPEK gauge also has a built in programmable output relay to activate things like an aux fan or secondary fuel pump, intercooler sprayer, etc (up to 20 amps). It uses a very nice quality pressure transducer from SSI and has a plug-n-play harness.
Finally got a pair of these in. They are $30 at McMaster but that's without a drag pointer. No one (According to wika) carries any of the gauges with drags, they all have to be specially made. I've got one extra if anyone want's it for $50.
Milo
Sorry for the shitty cellphone pictures.
Rear is a 1/4" NTP, centered. 1.5% accuracy.
Updating this with pertinent info due to a PM.
Wika Gauge (Pressure, drag pointer)
Dale Foster Sales Company
P/N: 4236557-DP
213.53 2.5 30/0/30PSI 1/4" CBM W/DRAG PT
Call us at 480-785-8600 if you have any questions about this shipment.
