Autogeek.net Car Care Products
** 10% off @ Autogeek.net - PinnacleWax.com & Wolfgangcarcare.com - Coupon Code = clubmember
Results 1 to 6 of 6
Thread: How to clean leather seat seams
    South Carolina
    2004 330 vert 2004 X5
    I was cleaning and conditioning my Dove leather seats on my e36 and noticed the seams on the seat bottom are getting a buildup of dirt. Since dirt is the big enemy I would really like to get them cleaned up.
    Can someone give me some ideas of how to get down into the seams to get this out?
    I seached and could only find one thread that someone posted about using steam to clean the seats. Any help is appreciated.
    Atlanta
    '73 Bavaria
    Horse hair brush
    “The bitterness of poor quality remains long after the sweetness of low price is forgotten” – Benjamin Franklin
    Northern VA
    Jeep
    Toothbrush, cheap and easy.
    Ponte Vedra Beach, FL / London, England
    M-B SL500
    Remove surface dirt and dust, cleaning the seams periodically is important as dirt / grit will abrade the stitching causing them to fail, use a soft brush, vacuum and then use a foam cleaner, finally wipe off with a clean, damp micro fibre towel.
    ~ Providing unbiased advice that entry level, enthusiasts, professionals and industry experts trust ~~ TOGWT Blog - Facebook Page
    Danbury, CT
    Nissan Pathfinder
    Air Gun. (Just wear goggles so you don't get pegged in the eye)
    Feb 2010
    Rochester, Michigan
    E36 M3
    Start with vacuum.
    You see how much force you need to apply to "pull apart" the seams to see down there? That is the same thing you need to do while vacuuming with a soft brush attachment, like this:
    DO NOT use liquid cleaners until you have been able to vacuum up as much as possible. Anything that gets dissolved into the cleaner (or suspended) will get into the thread fibers and possible under the leather through the holes in the stitching. Clean cleaner is not a big deal, but dirty solution, yuk!
    Use the correct cleaner for your leather and wipe as deep as possible to get any remains out. Im my experience, the vacuum gets out almost all the dirt, and a quick wipe is all that is needed to finish them off.
