Thread: What did you do to your e21 today?
  1. #4776
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    Picked up a piece of plastic from an accident no doubt from the road, it embedded in the tire,slow leak,took the tire off(optional) and put on spare, picked up a tubeless tire patch kit at HF for $5- 5 tire ropes, got the plastic piece out , reamed the hole, put the tire rope on the fork tool wet with vulcanizing glue- included , inserted in the hole leaving about 1 inch protruding, pulled the fork tool out and then cut the tire rope flush with the tire surface, filled the tire with air,all in all a couple minutes work, all signs point to good....
    Randy
  2. #4777
    Sep 2001
    Coral Springs, FL
    E21,E38,E39,F10 M5
    Drove it to the nearest gas station i found on www.pure-gas.org to fill it up with pure ethanol free gas ... I started to read up on the effects of ethanol fuel in CIS systems, and what starts to happen after just 30 days.
    ... go do it.
    Stancing is for drivers trapped in an abusive relationship of their own lives.
  3. #4778
    Mar 2018
    az
    1971 2002 1979 32oi
    Finally ditched the factory E21 seats and installed a set of 2006 Tiburon seats. They went in like butter and they feel great. I had to make a my own brackets and used a piece of channeled steel on the existing inside perch to even it out. I used the Tiburon seats because they are nice and low with no height adjustment. The whole thing is bolt in no welding required. With the price of recaros these days this is a much cheaper route. About 220 for all the bits including the seats which I found on CL. c+4E7vdmRROAW81RckG%0Q.jpg
    c
    c
    c
  4. #4779
    Feb 2017
    Greenville, SC
    '79 320i, '76 2002
    Replaced the worn out straps on the seats from my '79 with new recaro straps. Cleaned up the seats and installed them into the '82 320is shell I picked up last week. Lots of stuff left to do to get the car to run, but it does feel good to have this done. Being able to sit behind the wheel for the first time is definitely motivating!
  5. #4780
    Oct 2018
    California, East Bay Area
    1978 320i
    This was this weekend but I am pretty excited about the progress I made!
  6. #4781
    Feb 2019
    Northfield, VT
    1981 320i
    replaced the tired seat straps on the recaro seats---easy to do and a great maintenance item.
    removed rear package tray to clean it an re-cover (or paint) it
    changed diff fluid, oil and filter.
    installed hella driving lights, led bulbs, and connected the driving lights to the high beam circuit so they can run from the hi/lo beam lever.
  7. #4782
    Feb 2016
    Sacramento, CA
    1979 E21 320i
    Well! That rear subframe is fascinating! Points for a creative medium case diff swap. What’s the sway(torsion?) bar off of? I like the setup, might do that myself
    -John
  8. #4783
    Oct 2018
    1978 320i
    The sway bay is ground control's e36 swaybar. i was going to use a universal sway bar but this was the perfect size and fitment for me! I also made some changes to the sub frame to increase the height of the differential. I will take some pictures of it tomorrow. Suck having to redo the differential mounts but its completely worth it to make everything optima for my uses.
    EDIT: added picture
  9. #4784
    Feb 2019
    Northfield, VT
    1981 320i
    Cut, drilled and installed a 1 1/4" square stock thick walled steel tube for a home made 'alpina brace', it did seem to stiffen up the front suspension on the twisty roads this evening. $12 for the steel, $4.50 for the grade 8 bolts, washers, lock washers and nuts.
    Should be a good support for the aluminum skidplate I am working on.
  10. #4785
    Nov 2007
    Cool
    Yeah,noticed it lessens nose twist with Alpina Bar installed,with B Pillar and Tower Braces coupled with a lower center of G and tight springs and a few other goodies gets numbers that can be compared to the gold standard of suspensions--the ordinary go-cart. I'm not talking about aerodynamics either which obviously means lessen drag coefficient-resistance to moving in atmosphere ,,, lol,,,
    Randy
  11. #4786
    The Garage
    E30 325i, E21 320i
    Worked on plugging in and bolting everything back on after I put the motor back in this past weekend.
    Anyone here that has done E30 M10 EFI conversion? What did you use for the throttle cable to connect to the E30 throttle?
  12. #4787
    Aug 2011
    Ontario, Canada
    1980 E21 M10
    Took the vehicle finally out of winter storage. Installed the refurbished alternator (I could not get the voltage regulator off so I took it to an alternator shop that replaced the voltage regulator and did some other work on it such that it spins quieter). The vehicle started and ran great. Next thing to do is to investigate the small brake fluid leak out of the right rear wheel assembly.
  13. #4788
    Jul 2017
    Dinslaken, NRW, Germany
    New shoes. 6 and 7 inch Maxilite Alpina Style with 195/50r15 Michelin Pilot Sport. My favorite wheels on a e21. Hope you like them too.
    “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
  14. #4789
    Nov 2007
    Cool
    Put a new BMW Badge on the Hood, old one pealed off, got it locally,, made in Germany,bmw badge. $20
    Randy
  15. #4790
    Nov 2007
    Cool
    Picked up a Gallon of BMW Coolant at a dealership $27 out the door, drain, flush and fresh fill of 50/50% Coolant/Distilled Water for the hot weather.
    Randy
  16. #4791
    Nov 2007
    Cool
    Finished up with drain,flush with chemical,flush with water, and then refill.. The Engine Block Drain Coolant Plug got stripped,, Dealership had the replacement screw plug ~$6, I got two of them with washers ,its longer than the original one yet works fine with sealing washer-no drips , BMW 07119904539.
    Randy
  17. #4792
    Dec 2018
    Hialeah
    E30, E21
    Installed a few goodies I ordered... trunk light lens, brake pedal pad, some screws and also my reupholstered rear seat. The correct material is NLA, but I found one that was close enough for me.
  18. #4793
    May 2018
    NW Arkansas
    No BMWs anymore
    Where did you have it reupholstered?
  19. #4794
    Dec 2018
    Hialeah
    E30, E21
    I got the fabric on fabricguru.com and the stitching was done by a close friend that is a furniture upholsterer by trade and has been putting up with my old car obsession for the past 35 years. Thank God for good friends!
  20. #4795
    Mar 2013
    Santa Rosa, CA
    1981 320i silver
    nicely done. fabric looks good quality. double rows of stitching and pleats I suppose you'd call it, all looks straight and professional
  21. #4796
    Oct 2018
    1978 320i
    Made some shortened e34 thruster arms. Going to start working on the front suspension. Also got my Z3 steering rack in. Thinking about switching to a RHD rack so I can simply flip it upside down instead of using the US rack and a converter. Since the z3 rack is front steer and the e21/e34 are both rear steer.
  22. #4797
    Jun 2012
    Omaha NE
    1983 BMW 320i
    That looks fantastic!
    Murray
  23. #4798
    Oct 2018
    1978 320i
    Made the mounting points on the subframe for my thruster arms. Also, a photo of the Z3 rack in the car.
  24. #4799
    Feb 2016
    Sacramento, CA
    1979 E21 320i
    Huh! How’s the lock to lock on that? Just picked up the e36 rack and moving forward on converting my suspension, maybe a z3 rack is worth getting
    -John
  25. #4800
    Oct 2018
    1978 320i
    Quote Originally Posted by Somjuan View Post
    It’s 2.7 turns from lock to lock. Are you using the full e36 front suspension? The only thing I found annoying is now I have to make this rack work in a rear steer format or switch to a slower rack. Decided I’ll order one of these (http://www.colemanracing.com/Reverse...Box-P6316.aspx)in a couple weeks to remedy the issue.
Page 192 of 206 FirstFirst ... 92142167182183184185186187188189190191192193194195196197198199200201202 ... LastLast
