Thread: What did you do to your e21 today?
  1. #4676
    Sep 2015
    North Carolina, USA
    1981 BMW 320i
    Did some rust control inside my trunk, spent about 4 hours with a couple wire wheels in a drill to bring it all down to bare metal and taped it off for overspray. I couldn’t find POR-15 in my area and by the time it ships home I would have already been getting ready for Parris Island. I wanted to get this done before I head out before it gets any worse.
    I found some Rustoleum in a can that seems promising, I’ll have one of my brothers report if anything fails while I’m off at boot camp.
    I hear NAPA sells spray paint that “matches” oem paint so I’ll give them a try, it is just the trunk after all.
    I’ll finish it off by jigsawing a couple pieces of plywood and stretching some gray fake leather over it to match the toolkit.
  2. #4677
    Jul 2010
    San Jose, California
    E21 320i, E30 325i
    Quote Originally Posted by Drew320 View Post
    I did something similar using leftover snap together wood flooring after doing all the bedrooms at my mom's place.
    Found some old books on craigslist and picked them up today....
    '81 E21 320i / '90 E30 325i / '̶9̶2̶ ̶E̶3̶4̶ ̶5̶2̶5̶i̶t (sold) / '15 Toyota XW30 / '̶̶8̶0̶ ̶E̶2̶1̶ ̶3̶2̶0̶i̶A̶ (sold)
  3. #4678
    Sep 2015
    North Carolina, USA
    1981 BMW 320i
    Found the paint, but not what was expected, an e30 forum said that there’s a rattle can called “arctic white” for General Motors vehicles that closely resembles BMW Alpine White. This is not the case. I gave it a shot and it is a lot whiter and brighter than I was hoping.
    I guess it is safe to say I shouldn’t have trusted the forum as the words “dope” “mint” and “stance” were mentioned quite a bit:
    Regardless, this is just a temporary fix to stop the rust from going to anything important like body panels as the trunk pan is pretty much toast and it will be covered up.
    I have another car I’m planning on turning into my daily after my service and this one I believe I’ll turn over to my brothers to make it an HSR car for VIR while I’m gone.
    Trunk pan will likely be tossed for sheet metal to fit a fuel cell so I’m not worried as to how it turned out as long as it retards the rust until a permanent solution is installed.
  4. #4679
    Sep 2014
    Minnesota
    E21 323i, E36 M3
    I installed new wiper damper rings since mine were completely missing. They were a little expensive, but my wipers no longer wobble around and make scraping noises on the fast setting.
  5. #4680
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    Rebuilding a WUR 0438140071 with new ceramic resistor heater coil, New Viton 75 o-ring(in bound) and other new items with aluminum soldering- that's done, resistance the same, its all a part, after rebuild I'll calibrate it and install and then rebuild my spare as well same way...
    Randy
  6. #4681
    Nov 2007
    Cool
    Viton O-rings came in today, I assembled it. Calibration for Warm and Cold Control Pressure next. Ran into a problem,, The Ceramic Resistor heater in the Wur, I changed it out for a new one and found no warm control pressure, I tested it by placing 12 v across the pins and found it was defective even though it showed 22 Ohm resistance, I had a good old one and placed 12 v across the pins and it heated up real fast, so I installed the older one with new Viton o-ring new aluminum solder and its works just fine after warm and cold calibration. So to check the Wur resistor is good or defective you put 12 v across the pins and touch it, if its hot after a few seconds its good, if slow to heat--its still good for a while and if no heat its defective. Needless to say I wont be doing business with Colin( K-jet Colin)again nothing but excuses and he does not test them from what he said to me and he wont make it right, I wont trust him with my car parts again. I got a refund on my second order. Update 3/14/18--just got refund on my first order,,evidently he tested some and found they were defective.
    Randy
  7. #4682
    Nov 2007
    Cool
    Passed Cal Smog today, good for 2 years.
    Randy
  8. #4683
    Nov 2007
    Cool
    These are bearings for the Reverse Gear-small shaft-30X22X15 mm needle cage ( qty 2),, BMW 23211206957, for my Getrag 245 5 Sp. I now have 4 bearings total, Input/Output Shaft and Reverse Gear. There are 14 Bearings total in 10 different sizes.
    Randy
  9. #4684
    Nov 2007
    Cool
    If you want to rebuild your differential small case 168mm Ireland Motor Sport just posted a kit for $183 plus shipping. My spare Open 3.91 Differential I rebuilt just recently. This is a good deal.
    Product Description
    Replacement
    This is a rebuild kit for your 2002 or E21 differential that replaces all the common wear items. Some E21 differentials came with a larger pinion bearing (Late Model '80-'83 w/ 6-bolt side covers), make sure you know which bearing your diff has.
    Kit includes:
    X1 Front pinion bearing
    #33 12 1 204 305
    X1 Rear pinion bearing
    #33 12 1 204 306 (Small) or #33 12 1 206 739 (Large)
    X2 Side bearings
    #33 13 1 205 117
    X1 Input seal
    #33 12 7 621 206
    X2 Side seals
    #33 12 1 205 302
    X2 O-rings
    #33 11 3 604 119
    X1 Crush sleeve
    #33 12 1 200 259
    X1 Lock plate
    #23 21 1 490 120
    X1 Cover gasket
    #33 11 3 604 117
    X8 or X12 Side cover 10.9 bolts w/ washers
    http://www.iemotorsport.com/bmw/item/scdrk.html
    Randy
  10. #4685
    Sep 2014
    Minnesota
    E21 323i, E36 M3
    I fitted a trunk mat since the one in my 323i went missing in the 80s. I completely forgot about the US/Euro trunk difference until I got the mat in and realized it was ~3" too short. It's an improvement, at least.
  11. #4686
    Sep 2015
    North Carolina, USA
    1981 BMW 320i
    Fuel pump came in from FCP euro, I like the idea of a lifetime warranty on everything they sell.
    Spent the weekend pulling out the fuel pump regulator and filter cluster from the rear and reinstalling it with a new pump.
    The hose from the top of the tank running to the pump was completely gone. Crumbled away in your hands when you touched it.
    My dad gave me the ingenious idea to duck-tape the end of the old hose to the end of the new one, that way I could easily pull out the old hose while feeding in the new one.
    Just make sure you wrap enough duck-tape around the old hose to prevent it pulling loose.
    Pic dump:
  12. #4687
    Jul 2010
    E21 320i, E30 325i
    Did some Pick N Pull shopping over the last 2 days. Got the front strut uprights, some tail light reflectors and wiring to make quad brake lights, ignition control module, some other little odds and ends, and my favorite, lots of old paperwork which includes the original window sticker and invoice. The glove box was stuffed with maintenance and service done at the dealer and 80's and 90's SMOG test results. Shame it ended up at the yard like this.
    It was over 2 days because when I first went on Saturday to try and grab the struts I just could not get the ball joint off from the right side control arm. Probably spent an hour whacking it with the jack from the trunk and trying to pry with my Harbor Freight breaker bar but it would not budge. I had also conveniently forgotten my hammer. So I left for the day and got a $10 pickle fork from Harbor Freight and went back today. 2 seconds with the right tool and it slipped right off on both sides.
  13. #4688
    Nov 2007
    Cool
    Your RockAuto discount code 5873926951769857 will expire on April 15, 2018.
    If you or anyone you know is thinking of doing some vehicle repair, now is the time to order the parts!
    How to Use Your Discount Code
    Taking advantage of this discount is easy, and will save 5% off our reliably low prices. Enter the code above in the "How did you hear about us" box without any other numbers or characters.
    Please note: Discount only valid for orders placed online. Discount cannot be applied once an order is marked as shipped.
    Randy
  14. #4689
    Mar 2018
    az
    1971 2002 1979 32oi
    Bought a new engine for the E21. it'll be here next week. Can't wait
  15. #4690
    Mar 2018
    Gilbert, AZ
    1982 BMW 320is
    Quote Originally Posted by jshep79 View Post
    Woooo! Stoked that worked out for ya Jshep79. Been fitting that intake manifold and connecting misc bits but next weekend I’m fully reassembling everything and hopefully going to hear the idle I’ve been waiting for!!!!
  16. #4691
    Nov 2007
    Cool
    Made,tested, and finished up on making the Warm up Regulator Ceramic Heater Coil. The Black Color material is thermal concrete.
    Randy
  17. #4692
    Jun 2016
    Austin, TX
    1978 323i
    Took my wife out to dinner in the 323i the other night, and right after she put her seatbelt on, she said, "hey, your car doesn't smell anymore!"
  18. #4693
    Jun 2016
    Austin, TX
    1978 323i
    Forgot to add, just before this, she opened the passenger door and the quarter panel trim popped right off onto the ground right at that moment. I thought maybe Id done something wrong, but realized this is one piece of the car I've never touched before - like other things on the right side of the car the threaded retainer for the trim was plain missing, just held on by the two snap-clips
  19. #4694
    Nov 2007
    Cool
    Bought a tube of Hylomar Universal Blue 100 gr, Wide operating temperature range (-50 to +250ºC), in bound,, I like the non setting Gasket Sealer, seal gaskets better to keeps leaks in check.
    Randy
  20. #4695
    Dec 2011
    Long Island, NY
    1980 320i 5 speed
    Took today off and finished up my ignition switch replacement. If you've read my thread on "Ignition Switch Search" I was having trouble replacing the electrical part of the ignition switch. Good thing too because when I took the whole column lock assembly out I found out what the real problem was. The end of the shaft on the key tumbler side was partially broken off allowing for lost motion in the lock and the inability to fully shut off the system. Likely in its life someone was trying to start the car with the column lock engaged. This condition was evident when I bought the car last October. Key off and out of the cylinder the accessories remained on. Had to keep the fuse out for the clock etc.
    I had already bought a new electrical switch and the tumbler felt real healthy. Luckily I found just the column lock housing on eBay for $57 with free shipping. (someone was looking out for me)
  21. #4696
    Nov 2007
    Cool
    Good to see you got it sorted, while you got it out new parts in there keep it working like new.
    Just negotiated for and bought a part for my car, more on this later..
    Randy
  22. #4697
    Jun 2016
    Austin, TX
    1978 323i
    Daily driven!
  23. #4698
    Nov 2007
    Cool
    Hylomar Universal Blue 100 gr in,, $11 including USPS 1st class shipping, ready for any Gasket Job, I also Have Curil T which is more expensive.
    Randy
  24. #4699
    Sep 2001
    Coral Springs, FL
    E21,E38,E39,F10 M5
    I finally got around to pulling off all the old under hood foam insulation that was deteriorating.
    WHAT - A - PAIN - IN - THE - ASS.
    Stancing is for drivers trapped in an abusive relationship of their own lives.
  25. #4700
    Dec 2011
    Long Island, NY
    1980 320i 5 speed
    Quote Originally Posted by Manny G. View Post
    Are you replacing it? Factory or otherwise?
    Mine needs to come down.
Page 188 of 206 FirstFirst ... 88138163178179180181182183184185186187188189190191192193194195196197198 ... LastLast
