Thread: What did you do to your e21 today?
  1. #4601
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    Installed New Wheel Bolts all around, Once the nuts where tight--I removed the studs with impact wrench on low setting.
    Randy
  2. #4602
    Nov 2007
    Cool
    Realized I installed my used Bosch Fuel Pump and not the new one both in new boxes, waited to get the new copper sealing washers that seal the banjo metal fuel line to the fuel pump-not a common size being 1.5mm thick.. Anyway the used pump is good. Also got the sealing washers to the Warm up regulator to have on hand. Install the new Bosch fuel pump tomorrow.
    Randy
  3. #4603
    Sep 2015
    North Carolina, USA
    1981 BMW 320i
    This morning my brothers and I did a few laps at VIR for charity.
    The fastest I could get it was 7k rpm in fourth gear (5 speed, 3.91 LSD) on the back straight. My needle ends at 85 so if anyone has any idea what that is in miles per hour please feel free to chime in as I have no idea
  4. #4604
    Nov 2007
    Cool
    Installed the New Bosch Fuel Pump( exchanged for older one) and New Bosch Fuel Filter, old fuel filter less than 1 yr old, yet new filter is recommended.
    Randy
  5. #4605
    Mar 2013
    Santa Rosa, CA
    1981 320i silver
    I came up with 123 mph if you have 185/70-13 tires on the turbina wheels. That's quite a distorted picture. What type of lens was used or how did it get that way?
  6. #4606
    Sep 2015
    North Carolina, USA
    1981 BMW 320i
    Quote Originally Posted by okieflats View Post
    There was a photography group up there who gave a free print to everyone participating. I assume because the photographers were taking a picture of every single car they must have had trouble getting the focus right for a few.
    Our dad came with us and took some pictures from the oak tree turn and the paddock near the timing booth. I'll see if I can post a couple when I get them.
  7. #4607
    Nov 2007
    Cool
    These are ring terminals I just bought that fit the small and larger studs on the Main Fuel Pump, what I prefer about these they are both 16-14 AWG, the smaller ring terminal once the plastic insulation is removed has a removable-reinstall able wire guide tube that is crimp able.
    Randy
  8. #4608
    Mar 2016
    Moorpark ca
    1981 e21 1990 e30
    Swapped in a custom rear crossmember with e30 center section
  9. #4609
    Feb 2016
    Sacramento, CA
    1979 E21 320i
    Quote Originally Posted by Mattgmz View Post
    Helloooooo there big ol' engine. What'd you go with, 3.15lsd?
    -John
  10. #4610
    Mar 2016
    Moorpark ca
    1981 e21 1990 e30
    Quote Originally Posted by Somjuan View Post
    3.73 welded e30 diff
    Sent from my SM-G900V using Tapatalk
  11. #4611
    Corona California
    79 320/6 81320i 65malibu
    To Drew320
    On the dyno with 225/45 15 Rs-3s (22.7" OD) 7,200 rpm in forth was 125.xx
    https://www.youtube.com/watch?v=t3HX-PfZ-mA
    Always FUN TO DRIVE - Build Thread & Tech info - 79 320/6 track car build thread -- Videos of track car -Adam in car Auto-x video - Start-up video - 4/2011 Adam's TOP BMW time San Diego BMWCCA - 4-5-15 Dyno break-in run new M20B25 - Exhaust Thread - Link
  12. #4612
    Apr 2014
    Tulsa, OK
    76 2002, 82 e21, 83 e21
    You stuck that big-ole front end in our faces and went to talking about crossmember...I don't see a crossmember, but I sure do like the front end of your car...NICE!
  13. #4613
    Mar 2016
    Moorpark ca
    1981 e21 1990 e30
    Quote Originally Posted by SilverPuddle View Post
    Haha thank you so much heres the crossmember lol
  14. #4614
    Nov 2007
    Cool
    Applied dielectric grease to all fuses,relays in distribution box and the ev1 connectors in the engine bay plus transistorized ignition chip, Distributor plug, and Backup light switch then did all the bulbs on the back and front end.
    Randy
  15. #4615
    Dec 2017
    Vancouver, WA
    Z3 coupe, Z3 Roadster, Z
    I just bought mine today, so gave it a good washing to see what I'm up against!
  16. #4616
    Mar 2016
    Moorpark ca
    1981 e21 1990 e30
    Quote Originally Posted by mybmwhabit View Post
    Congrats!
  17. #4617
    Dec 2017
    Vancouver, WA
    In the middle of hunting down parts, I used some Glare compound and polish to bring back the finish quite a bit! It was a very sunny day, so a nice time for a little bit of cleanup. Serious mechanical stuff to start soon!.
  18. #4618
    Nov 2007
    Cool
    Got these at Sears today $8.65 out the door plus a bunch of coupons some of Sears goodies will surprise ya , these are for those Hex Situations. I have a Husky Set cost twice as much, both with lifetime warranty, I dont want to have 8 mm CV bolt left in or left out because of a cracked or broken tool and have to hassle up a replacement on the fly, plus wear factors.
    Randy
  19. #4619
    Wichita Falls, Texas
    1997 BMW Z3 2.8
    Got out my $9.95, "POPS-O-DENT" tool that I bought years ago for some reason, and tried it out on some small dimples in the car's sheet metal. It actually works pretty well if you take your time. John
  20. #4620
    Sep 2014
    Minnesota
    E21 323i, E36 M3
    Quote Originally Posted by 320iAman View Post
    I finally had to pick up a set last summer when I was putting a new flywheel on my e36 and realized I couldn't properly torque it with the hex keys I had been using on everything up to that point.
  21. #4621
    Nov 2007
    Cool
    Quote Originally Posted by hotdish View Post
    Hex keys on e21's warm up regulator,transmission support brackets,drums/ rotors and CV shafts and a few other places, I was surprised at mens dress shoes many styles starting at $30 on up.
    Randy
  22. #4622
    Dec 2017
    Vancouver, WA
    I took it over to the local independent guy that specializes in older BMWs. Gonna get it to at least stop and go before I dig in on other stuff!
  23. #4623
    1997 BMW Z3 2.8
    Got out the clay bar in an attempt to re-hap the alpine weiss paint a bit. Shines up well for a 33 year old paint job.
  24. #4624
    Nov 2007
    Cool
    Just got this in and installed from Germany, New. Its the 17 degree Celsius Switch that part of Open/Closed Loop Lambda System. This part was sent from BMW Dingolfing, DE.
    Randy
  25. #4625
    Mar 2016
    Moorpark ca
    1981 e21 1990 e30
    Installed my axles that i shortened to accomidate my wider e30 diff
Page 185 of 206 FirstFirst ... 85135160175176177178179180181182183184185186187188189190191192193194195 ... LastLast
