Page 1 of 206 12345678910112651101 ... LastLast
Results 1 to 25 of 5148
Thread: What did you do to your e21 today?
    Canada
    e84, e36, e21
    This thread became huge in the e36 section. Lets see how it goes here.
    What I did to my 323i today...
    - Removed rear rotors and calipers.
    - Removed fuel pump/accumulator/filter, por15'd rusty accumulator and mounting bracket.
    - Removed fuel tanks, por15'd rusty areas. Will give them a coat of rubberized undercoating tomorrow.
    - Removed the long fuel feed/return lines from the tank to FD (pain in the ass).
    Sep 2009
    Houston, TX
    1983 BMW 320i
    Ummmm....I just drove mine. It was fun!
    Nov 2007
    Orlando, FL
    1982 320i
    New plugs , red plug wires from a member here, distributor cap and rotor. Installed air slide valve. Replaced the wiper blades and painted my side mirrors. Measured the strut towers so I can draw up a strut brace design, oh, and drove it! Last week, replaced the radiator and temp sender, which solved the running hot problem and also semi cured the hot start problem I was having. Also had the steering rack worked on and two new front tires, plus front and rear alignment.
    Bozeman, Montana
    '83 320i turbo,'80 320iS
    Installed a wideband 02 sensor
    Bozeman, Montana
    CT USA
    1982 323i Baur & 6 more
    Today I drove my Baur to a local British Car show, but yesterday I had taken it out for a "Shake Down " Cruise, since I just gotten temporary plates on Thursday. Shake down cruise is right.... running it on a back country road about two miles from home I 'shook down' the right side exhaust pipe and muffler, to the point where I heard it dragging. Day um! Apparently, the previous owner had it wired up with a flimsy wire which worked itself loose on the bumpy roads. I foolishly hadn't noticed it at home in the garage, naturally, so here I am on country road with no tools, dragging half of my exhaust system. Shee it. I limped it a couple of hundred yards slowly to a parking lot for the town public works garage (closed of course), and pulled in to see what could be done.
    Luckily I had fabricated a tool from a coat hanger to remove my Blaupunkt radio the other night, and had left it on the console... two pieces about 12 inches each. YES! There IS a God! I twisted the two pieces together using the leatherman tool I always carry on my belt. I then used the jack to lift the hot exhaust pipe up off the ground high enough to where I could wrap the coathanger where the rubber connectors are supposed to be... and drove it home! No problemo! What was I worried about!!???
    Damn lucky I had left those coathanger pieces in the car. When I went to the car show today, I made sure that I brought a full set of tools with me, along with enough sturdy cable to wire a bumper on, if I had to! Lesson learned. Since I was prepared for any eventuality today, the car ran flawlessly, of course. And I now have some additions to the parts list needed as I begin my restoration project.
    Tom
    SE Connecticut
    1982 323i Baur, 1977 320i (carbed),
    1978 320i (parts)
    1991 325ix 5 speed, 1989 325ix (winter),
    1989 325ic (summer)
    1973 2002 Malaga (with frosting)
    1975 Mercedes W115 300D (The Departed)
    the late 1979 323i Euro (project, Now Departed)
    Visit my blog: Baurspotting
    http://baurspotting.blogspot.com/
    BWR PWR!
    Sep 2008
    Los Angeles
    82 e21, 70 '02, 07 650i+
    so I took a Mother's clay bar and worked every nook and cranny of the car from top to bottom. standing in the rain. and it worked great because the rain kept the surface clean and fresh as i scrubbed. it was awesome.
    the gunk coming off what I thought was clean paint was amazing.
    Current: 1987 Zinnoberrot 535is - M-tech body kit and other Euro parts
    Previous 1970 Turbo Look 2002, 1982 320i - Both with Metric Mechanic 2300 motors, dual side-draft Webers and track-mods
    Finger Lakes Region
    '79 320/6
    Quote Originally Posted by joey79 View Post
    Joey, You're my hero. I so have to do that to the '80 323i but really don't want to. The PO hacked up the fuel lines and jimmy-rigged the whole setup (Sender, filter, pump and accumulator). Now if I could just source the larger braided fuel lines!!
    I still drive daily with no commute...
    The Hazard is All, Praise the Hazard!
    Canada
    e84, e36, e21
    I know what you mean. I didn't want to do it either, but I figured I had to. It was very satisfying to see that rusted pile of crap come out. As for the fuel lines, try Walloth & Nesch.
    Houston TX
    E60 M5
    I stared at it for a while and then wonderd why the fuel distributor looked so nice but does not work.....
    Mar 2008
    Portland, OR
    '80 320is
    Finished installing clutch, transmission, driveshaft, exhaust, then got frustrated trying to remove the bolts for the clutch master cylinder so gave up for the day. Also found the battery is dead after sitting in the garage for the past two months.
    Aug 2008
    Scotts Valley, CA
    83 320i
    Used it as a rescue vehicle to go get my Daughter who is driving my F-150 and thinks it runs on air. Both tanks were dry. Sheesh.
    Everything they say about blondes is true.
    Sep 2008
    Los Angeles
    Quote Originally Posted by midlifebmw View Post
    I love the use of the "jimmy-rigged" term.
    Much mo better.
    -Gerry
    Regina, Sask, Canada
    82 320i 89 325i
    bought it a truck lol
    Melbourne, Australia
    1982 323i, 1997 318iS
    Quote Originally Posted by cheap320i View Post
    What, that they have more fun?
    May 2010
    Hobart, Tasmania Australia
    1982 BMW e21 320i
    thought bout her a few times, dreamed up more things to put on its never ending wish list.
    B Road Blaster
    Jun 2010
    Blue Mountains, NSW, Australia
    VK Commodore
    I didn't
    Feb 2009
    District Nine
    sold 78 BMW 320i
    I put 8 gals of fuel and washed the glass in mine today.
    (which reminds me, thanks - I have to check the oil)...
    My wife drove it to the grogery store twice
    My son drove it all over town yesterday while finding custom parts for his supra suspension.
    Tbd
    Aug 2003
    SoCal
    E21, E24, M3
    This weekend: Installed bilstien sports, GC coil overs, tie-rod ends, rear shock bushings, steering rack boots. Drove about 150 miles, spun the rear in the mountains, took a poop on the side of the road after that.
    Nov 2005
    Mills River, NC
    '82 E21 320i
    I did the 'zact same thing you did!
    You need to start a separate thread so I can follow how you're going to fit and flare those lines!
    Quote Originally Posted by blitzed310 View Post
    Eric P.
    Canada
    e84, e36, e21
    Quote Originally Posted by pommeree View Post
    Will do. I'll probably be attempting it next weekend.
    May 2010
    vic Fayetteville, NC
    '81 320i, '09 328i
    Kinda excited since this was the first time I popped the hood and actually did something more than just stare at her. I drained and flushed the radiator and changed original thermostat for 75 since it was overheating while idling...didn't help a whole lot...water pump is next. Any ideas if its not that?
    Then quickly discovered the air chuck on my brand new can of R-134 doesn't fit on Gretta. Anyone know how to recharge the A/C on these things? Do I need to take it to a shop or can it be done myself? But good news, the wife's Jeep now throws ice cubes.
    Portland, OR
    80 320i, 87 325 i & is
    Newark 2 Nashville
    82 320i/4, 89 535i/5
    Nothing but dream about buying the M30 @ pull apart for a swap or get the 318i from the mech for a swap.. help....
    Wes
    E34 535i/5 (Dirty D)
    RIP E21 320i/4 (Hammerhead)
    Mar 2010
    Gilbert, AZ
    99 F250, 86 CJ7, 2005 4r
    Gave her a bath, a little shine for the tires & drove her to BMW to get a gasket for a 740 I'm doing some sidework on. I LOVE driving that car!
    Quote Originally Posted by Tom D View Post
    throttle lift oversteer is a way of life and should be celebrated. there are few things as much fun as steering a car through a corner with the throttle.
    He who dies with the most unfinished projects wins
