Okay...
I don't run style 5, but planning to
I'm not pro at style 5 fitment or anything
I don't know if this had been done before
I create this thread is trying to get those who run style 5 to teach those who are interest in style 5 including myself.
Okay here what i get from some reading
Most people run 215 and 205 without rubbing fender
Roll fender seems like the only solution to fit bigger tire
10mm or 10mm+ spacer is needed. (Not sure)
Questions:
Are those 215/205 good for performance?
Can I run 235/215 or something bigger?
Where can i get those spacer that has the hub for 5er wheel but fit e36?
How thick is the spacer should be?
Is steering wheel shaky?
Some people who run style 5 plz correct me if i'm wrong
and plz put some more detail to teach us who want to run style 5
Hope this will help everyone
You do NOT want to run a spacer. You just need a hubcentric ring that will fit between the wheel and the centric lip on the hub. You can put a wide tire on with fender rolling+pulling, however 215s should fit fairly well with maybe only a slight roll. You can always get stickier rubber if you want more grip to maybe counter act some of the width loss - just be aware that the tire WILL wear quicker than a wider not so sticky tire, even though they will have equal amounts of traction (depending on tire of course so don't flame me).
BBS RC041/BMW Style 29
where can I get the hubcentric ring that is needed to run style 5's on an e36?
ebay
Tire Rack little over $20 bucks!
Nice! Thanks guys! just ordered them off ebay!
Style 5 ain't Style 5.
They came in various sizes and offsets (model specific) as well as center bore sizes - and all of them are named Styling 5. But next to this there is another individual "naming" which is:
RC035 for 8x17, offset 20
RC038 for 9x17, offset 22
RC039 for 9x17, offset 26
RC040 for 7.5x17, offset 41
RC009 for 8x17, offset 10
RC010 for 9x17, offset 19
all of the above have the smaller 72.5mm center bore.
Then there are the E39 specific versions with 75.2mm center bore (HCR required for non E39 bimmers):
RC090 for 8x17, offset 20
RC091 for 9x17, offset 27
A complete list including model reference and all data you find here:
http://felgenkatalog.auto-treff.com/?felge=52
I hope this helps a little
any more discussion?
So wut is up with spacer?
Need or not?
isn't the stock E36 offset +37?
On an M3? The M3 brakes are larger calipers than a 325 so thats Y they are not rubbing...
On an M3 yes you need atleast a 5mm spacer.....only when you have new brakes and rotors.....
I thought I didnt need a spacer till I put new brakes on and BAM! my caliper rubbed the wheel....bad
So in conclusion:
Non m3......no spacer
M3...once you put new brake pads on.....YES need spacers.(fronts only)
Question:
At the local junkyard I found a set of these (actually I spotted 5) from an E34
(just a sample pic not the actual wheel obviously)
http://www.autoindependent.com//uplo...pics%20042.jpg
From what I've read the offset is the issue fitting these on an E36.
With stock suspension, and a lower profile tire, is it feasible to run these?
The wheels at the yard are 15".
Nice choice! Reminds me of the set I refinished my self and sold. Added zinc coated gold bolts...
Bump!!
Anymore questions and discussions ?
I realize now the ones I posted aren't style 5s (I'm new to BMW wheels),
but can you or anyone identify the one in the link I posted?
I thought they were 17s but the weave/slots are different.
Also wondering if with a lower profile tire if they will fit an E36 with stock suspension.
How about torque specs on the nuts? I did 25 ft lbs. I hope they don't come loose.
E30 318is - E36 M3 - E36 Hamann STW - F31 328ix - F36 440i - 72 Nova - Tacoma
Just wondering Has anyone build there own style 5?
Or get those lip to make it wider
http://cgi.ebay.com/ebaymotors/17-IN...Q5fAccessories
what size hubcentric ring do i have to run for a 97 m3?
72.56-74.1 frm ebay? sound right?
where can i get gold plated bolts that are splined. i know that blackforest has bolts but they are for the bbs rs and they are not splined
