Page 5 of 5 FirstFirst 12345
Results 101 to 111 of 111
Thread: Ford 302 E30 build...
  1. #101
    Austin, TX
    04 Golf TDI
    Damn these look great.
    I also have amassed the parts I'll need to run a hydraulic clutch on the T5, using a Datsun slave cylinder as outlined in Laminar's E36 302 build...
  2. #102
    Austin, TX
    04 Golf TDI
    Got a lot done today. Started by running the clutch hard line, looked at what it will take to make a hydraulic clutch mount.
    Moved to the front after that, finished the 5 lug swap, installed steel braided brake lines, and swapped the stock steering rack for a Z3 2.7 lock to lock rack.
    Found a pinhole leak in the oil pan, Already have the new pan here so I'll work on that sometime in the near future.
    Next on the agenda will be reinforcing the 318ti rear subframe I have, that way I can finish the 5 lug swap. I also want to reinforce the spare front subframe I have, possibly do a tube setup similar to Arc Asylum, I can have the tube bent at work. Will think about that.
  3. #103
    Austin, TX
    04 Golf TDI
    Radiator arrived last night, looks great.
    Checked it loosely in front of the car, looks like it will work, will come down a bit low, but not lower than the oil pan. Picture obviously not at install height
    Might work on fitting that this weekend. I'm going to wind up needing hood pins if this works out, as I'll have to remove the hood latch up front to fit it. I'm going to use the AeroCatch hood pins I think.
  4. #104
    Austin, TX
    04 Golf TDI
    Finally got some time between rain... Welded the castors onto my welding table, and tack welded my new oil pan to it so this time it won't deform while I'm modifying it. Started hacking, and welded an inner support to the oil pan, will give me some metal to weld to in that corner, hopefully make it less likely to burn through.
    That's when I ran out of argon. Gonna have to pick some up tomorrow. A storm also started building up.
  5. #105
    Austin, TX
    04 Golf TDI
    Ordered the JagsThatRun Heavy-duty driveshaft flange for BMW V8 engine swaps, as well as a Spicer yoke for the transmission end. Will have a driveshaft built that uses 1310 u-joints, going to try to get it in queue at a local shop this week.
  6. #106
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    Quote Originally Posted by AdamBath View Post
    I'm running this cam kit:
    http://www.compcams.com/Company/CC/c...csid=1058&sb=2
    I'm running it with 1.6 Comp Cams roller rockers on 3/8" studs, using the stock GT40P heads.
    The XE282HR is popular with the 347 guys, it might be a liiiittle wild for a stock 302. But if you have to have that idle chop...I have one sitting on my shelf, I intended to use it for a 393 build, but may go custom. We'll see.
    I don't remember which position I put the cam timing at, just kind of picked one and figured I can change it later.
    Do it before final assembly. Pulling the timing cover once the oil pan is installed gets sketchy, you risk tearing the oil pan gasket and dropping timing cover gasket material into the oil pan. Do it once, do it right.
    I assume you're not pulling the heads to check for piston-to-valve clearance. That cam has quite a bit of lift and duration, I'd be at least a little scared of it getting close, though the P valves aren't that big. What springs are you running?
    If you haven't seen my build, I did an Explorer 302 with Megasquirt and LS coils, I may be able to help if you have questions.
  7. #107
    Austin, TX
    04 Golf TDI
    Quote Originally Posted by Laminar View Post
    I'm running the springs that come with that cam kit, forget the specs.
    I'm using a Felpro molded rubber/steel gasket, not that worried about tearing it. I actually finished up the new oil pan this weekend, so I'll be removing that again soon.
    I'll eventually get a set of high flowing heads, just not in the already bloated budget right now.
    I'll stick an inspection scope down the spark plug hole and see how things look.
  8. #108
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    Yeah, I ran the same gasket and it tore when I tried to pull my timing cover to do a cam swap without pulling the oil pan. No prob, I can just RTV that. I ended up pulling the oil pan anyway, and managed to find bits of timing cover gasket and sand down in the oil pan even though I thought I had protected it well.
  9. #109
    Austin, TX
    04 Golf TDI
    Got some work in today. First thing I did was put an endoscope down a spark plug hole to make sure there was no contact between the valves and the pistons. So far so good.
    Then I started working on the fan and radiator. The fan is from a Ford Fusion (thanks Laminar for the idea).
    Have about an inch of clearance.
    So started working on the radiator. Welded in some metal that I could use to actually mount the radiator. Still a work in progress, but a good start.
    And the radiator sitting in its new home.
    I had to cut a hole in the top of the core support for the fill hole, but that's not a big deal. I also had to remove the hood latch, I'll patch in some new metal next time. Need to go grab some self etching primer, don't want this stuff to rust.
  10. #110
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    Looks like the same fan I have! You have the metal control box, right? This thing doesn't mess around, it moves a lot of air.
  11. #111
    Austin, TX
    04 Golf TDI
    Yep got the whole shindig, and there are plenty more at the junkyard if I ever need them I figured if you could fit one in your E36 I could finagle one into my E30. Moving the radiator is an interesting experiment, still need to finalize the mounting on that. I need to get more time to actually work on this thing.
    My drivers side core support and frame rail are a little more banged up than I originally thought, not sure how that's going to work out. Maybe I should weld in some replacement metal from a good car...
