Page 2 of 2 FirstFirst 12
Results 26 to 41 of 41
Thread: High Mileage E46 M3s
  1. #26
    Feb 2010
    watertown, SD
    2004 M3
    I think I win with 156k, and I have done nothing to it so far but I have only had it for 4 months. I just drove it an hour ago and I have a shutter taking off. I need to check my flex joint and cv shafts. Hopefully its just a flex joint.
  2. #27
    Feb 2008
    Lansing MI
    M3, M5, 850i, 325
    100k here. I've had clutch, RTABs, motor/engine mounts, subframe, brakes, drive shaft bearing, and countless other things.. lol
    Current:
    '03 E46 M3 - full bolt on
    '95 E36 M3
    Past:
    '02 E39 M5
    '94 E36 325is M-Technic
    '91 E31 850i
  3. #28
    May 2009
    ATL
    alpine white m3 s54 e46
    149462 miles on mine running perfectly! Replaced basically every part in the suspension, new water pump, cooling system, coils, 02 sensors, uuc bushings front and rear, 90mm studs, csl carbon fiber intake, ss headers, high flow cats, shark injector(race) Car redlnes at 8600rpm. Been through many track events pushing the car to its limits and expeienced zero problems.
  4. #29
    Honolulu, Hawaii
    what car?
    I previously posted and i'm now at 76k...
    I just did the Upper and Lower radiator hoses, Idler, Tensioner, Temp Sensor, and New TMS PP set and that's it for the new stuff.
    I just ordered from TMS a new OEM Clutch Kit, Guibo, Fuel Pump & Filter and Full Rear Suspension Package with SS Clutch Line. I'm also about to order a new pilot bearing and rear main seal...don't ask how much that all was LOL
    TeeHee
  5. #30
    Wake Forest, NC
    2001, 132k (bought with 58k)
    Big wear items, and non-wear items:
    - clutch
    - brakes
    - throttle position sensor
    - exhaust cam position sensor
    - rotation rate sensor (yaw sensor)
    - rear main seal (oil pan gasket is now leaking)
    - sunroof clip (x2)
    - hood latch
    - power steering hoses
    - belts (x2 or x3)
    - battery
    - guibo
    Currently broken/annoyances:
    - trunk handle
    - all fabric on pillars peeled off (car sits in the sun all the time)
    - water leak through windshield
    - windshield bottom trim worn (will replace when windshield is replaced)
    - cracked fog lamp
    - groaning from diff (need to try a fresh fluid change, lock to lock on steering)
    It was my daily driver for over 5 years. It's only the ultimate driving machine when you're driving it, afterall :-)
    Now, unfortunately, I'm getting ready to fix it up to sell it!
  6. #31
    Jun 2010
    New Jersey
    2002 M3
    I have 160k on my 02. Bought it off a family member's 2-year lease with 99k (he drove....a lot). I've just had to do regular maintenance items and its been fine so far. Always garaged, never raced or beat on, etc.
  7. #32
    Jul 2010
    Salem, OR
    2006 M3 SMG ZCP
    Check e46fanatics for this topic, there is a HUGE thread about high mileage SMG's and I think there is another thread about non-SMG cars as well.
  8. #33
    Jul 2010
    Quebec city, Qc, Can
    2002 BMW M3 Coupe
    Quote Originally Posted by AlpineWhiteM3xx View Post
    Just wanted to know if you always run 93 oct gas with this shark injector program. Do you also use 91 oct gas. I plan to install this prog in my E46 M3 but I can't always find 93 oct gas here in Quebec.
    Thank you
  9. #34
    San Diego, CA
    S54 and S62
    130k here.
    I DD the car and track it as much as I can.
    I've replaced RTABs/FCABs/ steering column guibo.
    The cooling system went at around 100k (which is always about when they go on BMWs).
    Clutch around 120k.
    Also replaced brakes and suspension but that was more of a mod than anything.
    Other than that just a few minor issue like a broken window switch or the fabric falling off an A-pilar.
    Only major issue was the rear frame (pics and story here)
    $4000 but taken care of by BMW NA.
    I'm thinking about replacing the wheel bearings, just as a preventive measure.
    The car runs strong, 288whp/239wtq at 125k (which is no less than 200 000 km!!) and is just great all around.
    I love this car!
    Current:
    Alpine White E46 325i Touring S54 6MT
    Titanium Silver E39 540i Touring M-Sport S62 6MT
    Past:
    Alpine White E46 330i ZHP Sedan S54 6MT
    Interlagos Blue E85 Z4 M Roadster 6MT
    Le Mans Blue E92 M3 6MT
    Japan Red E46 325i Touring S54 6MT
    Estoril Blue Individual E46 M3 Coupe 6MT
    Cosmos Black E36 M3 Coupe S54 6MT
    Alpine White E92 M3 6MT
    Alpine White E90 M3 6MT
    Laguna Seca Blue E46 M3 Coupe 6MT
    Jet Black E36 325is S52 5MT
    Lagoon Green E36 325is 5MT
  10. #35
    May 2009
    ATL
    Quote Originally Posted by mathjonc View Post
    Thank you
    My shark injector is set up to run at 93 octane. You can get your shark injector custom made by jim for the right amount of octane. Pretty much the whole software is programmable.
  11. #36
    Nov 2003
    Los Angeles, CA
    '04 M3, '95 318, '03 R6, RIP: '99 318TI, '01 M3
    Just over 116K here.
    2004 M3 Vert w/ SMG
    Other than the normal oil changes and inspections the following has been replaced.
    Warranty Mechanical Replacements
    Alternator <50K
    Exhaust Temp Sensor <50K
    O2 Sensors <50K
    Headers\Cats <50K
    Water Pump and Thermostat <50K
    Xenon LCM <50K
    Main ECU <50K
    DIY Replacements
    LCABs <50K
    RTABS <50K
    Fan Clutch ~50K
    Flex Disk ~110K
    Tranny Mounts ~110K
    Engine Mounts ~110K
    Oil Constant Pressure Valve ~110K
    BMW Special Tools: RTAB, FCAB, Shim Kit & Tool, Cam Holder, and Flywheel Lock
  12. #37
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    How about an update on this. Who has crossed a serious mileage mark? Any new issues with the car?
    I'm curious about the giubo's life span. How long are these lasting?
    88M3 AW 43k miles Project FS
  13. #38
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    I am at 96k now, and I have done the regular services every year.
    The couple of items I had to replace already:
    1) CPV gasket, it started to leak a couple of years back.
    2) Passenger side A-pillar trim. From reading others comments, this seems common.
    3) VANOS. The dealership replaced it a 45k under warranty, and now I had it rebuilt because I hear a rattle around 2k-2.5k Funny enough the noise is still there even with all of Dr. VANOS anti-rattle stuff in place, so the search continues.
    4) Tires, well that is to be expected as in I bought the car with 62k on it, fairly new tires in the front and about 2mm-2.5mm on the backs. Drove on that for about a year and replaced them. This summer purchased all new Pilot Sport 4's and I really like them.
    5) Brakes - replace all corners with ECS Tuning Slotted Geo-met rotors. Okay I am not happy with these, and they warped out in 3k of driving. Yes I did break them in properly, and after a couple of 170MPH runs on the autobahn, they are now crap. I am going to the BMW cross drill rotors now, while they are a bit more, I get a 2 year warranty on them, ECS Tuning says no warranty on rotors, what a load of crap.
    That's about it for the past 7 years of ownership, so I am quite happy.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
  14. #39
    Feb 2004
    Malvern
    05 M3, 98 euro M3, 01 M5
  15. #40
    Jul 2016
    Sacramento, California
    E30 325
    2002 M3 Vert Alpine, Bought It At 192k now has 198k.
  16. #41
    Jul 2012
    Yardley, PA
    98 M3/2/5
    Quote Originally Posted by MauiM3Mania View Post
    Lets hear from the E46 M3 owners with significant (100k and beyond!) miles on the car's odometer.
    Besides tires, oil and gas, have you had any significant maintenance issues?
    You just replied to my thread, but I just bought an '03.5 with 185,xxx in Arizona and drove it back to Philly -- didn't miss a beat the whole time.
    01/98 Porsche 996.1 911 - 2/6 - Current
    '03.5 M3 2/6 - Arizona bought - Wrecked 09/2018
    '06 WRX fully built/6 - Sold
    '95 323is/5 - Sold
    '95 325i/5 - Sold
    '01 540i/6 - Sold
    '03.5 M3 2/6 - Sold
    '02 M3 vert/6 - Sold
    '98 Cosmos M3/2/5 - Stg 2 AA Supercharged - Sold
    '98 M3/2/5 - Sold
