Lets hear from the E46 M3 owners with significant (100k and beyond!) miles on the car's odometer.
Besides tires, oil and gas, have you had any significant maintenance issues?
88M3 AW 43k miles Project FS
No one has over a 100k on their odometer?
not on my m3...both my e24s do.
2003 M5
2007 X3 6MT
Read a thread over on m3forum about a guy with a 180k E46 M3. He said other than regular maintenance (oil changes etc...) he hasn't done much and the car is runnin fine.
Im up to 108k miles.
Ive owned the car since 62k.
Aside from oil changes, etc. I've done:
brake rotors
brake pads
tires
alternator ($140)
flex disc ($90)
rtabs + shims ($100)
rogue tranny mounts ($60)
and shocks/springs, but those were more of a mod.
never broken down, never had any issues. ive also obviously done fluid flushes and changes (tranny, diff, coolant, etc)
EDIT: other problems include the upholstery on the pillars peeling a little bit (adhesive is losing its stickiness) and i had to replace a few clips behind the interior trim, thats it.
same, but I just bought the pillars from BMW of Honolulu (a-pillars to be exact). Need to change out my driver side c-pillar soon but i'm going to wait until I really need to do it as I bet it's more expensive than the A pillar.
mines is almost at 75k and I've had the car for a month now. I had to do the water pump and the pillars. that's it.
but the water pump was $500 shipped... ima do the power pullies next and maybe a low temp thermostat...the rest were mods to the car
TeeHee
none of you have done control arm bushings? seems like they usually don't last over 50k
i just rolled over 50k, and the car still feels tight, but I am probably getting close to that point.
2003 M5
2007 X3 6MT
Since many aren't chiming in, I'll do so (94k close enough?).
I've owned since 72k, and have done the following:
Full inspection II: 1350
Replaced a leaking Oil Pressure release valve: 60
new battery: 120
new blower motor: 150
Other than that, just new tires.......... car runs great, and all suspension pieces have checked out to be in good condition.
-Bryan
what was the story with the blower motor? mine is starting to squeak a bit, and i havent attacked it yet. i do have a bentley, though, which i can consult.
2003 M5
2007 X3 6MT
101k here, but I purchased the car with 95k. I have done plugs, air filter, fuel filter, and oil change as far as maintenance. Things that have broken or needed repair are emissions reall for CEL. That's about it for me and it runs great.
2002 E46 M3 Conv SMG - M for life!
It was actually a symptom of a larger problem that might have been missed. I had been having problems with the car having "electrical hiccups", and it turns out that I had an undersized battery....and that, coupled with a blower motor that was on the outs (blower moving a bit on its own, failing some, etc) was causing the HIDs to dim in and out, and causing the car to actually stall some....not good.
New blower motor + new battery = problem solved.
-Bryan
202k '01 S54 M Roadster here. Highest mileage S54 that I know of.
Routine maintenance keeps repair costs down. Only major components that wouldn't classified under "maintenance" that needed replacement is 2 MAFs, an ABS sensor, and a few other minor things. The S54 is a very reliable motor if treated well.
mine is right under 90K miles, i have had her since low 70k mark. Just did full fluid over hall in april, drove from the pacific to the atlantic (cali to md to be more specific) and then double back to omaha. Car was solid the whole time, just think i need an alignment and such again, but a problem has seem to come out that im asking for help now
i dont know if im slightly burning or leaking oil now. the oil light warning came on about a day or two when i pulled into omaha. thought it was because i did a whole bunch of driving in a short amount of time and thought nothing of it. i did the oil change and what not and i seem to be gettin low on oil again.... any thoughts??? im hoping for dumb leak some where and not burning.
obvious question...any spots? cpv is pretty common, it seems, but most who ahve had that issue have seen spots.
how much is it using? below a certain amount is ok, annoying, but still ok.
2003 M5
2007 X3 6MT
i had it to the top line of the dip stick and in about a month and change im half way between the lines.... not much but i was worried it was a prob and i just caught it early
I have 95k on mine
Other then the normal stuff
I have had the berring recall done (covered)
had an ignation coil die on me (covered)
some switch in the AC died ($300)
and its in the shop now for a EPAP LDP issue that I couldnt figure out
I do need to do bushings RTABs and LCAs
EVAP LDP issue was caused by 2 bad coils. The car now has 6 new ones on it. All covered by BMW NA :D
Almost there, 94k...
Conrods engine 1
VANOS explode engine 2
engine 3 seems fine so far, it has about 41k on it now.
coils, throttle potentiometers, final stage (we all get that one). Lots of tires and lots spent on preventative maintenance and maintenance. I don't count plugs, brakes, fluids, or bushings as anything more than std stuff, but all thats up to date on my car. Oh my PS is leaking, but whose doesn't?
I have a very thick stack of receipts/records. My last 30k miles. Floss was all I had handy for reference.
Elective wear things I have done are: New A and C pillars, backrest, rear side cards, sunglass and center console. My car is almost 10 years old now and people are suprised its together so well. 'This is nice' they say when they sit in it. It needs new paint though on the front end. Jet Black gets pretty speckled after so many miles.
Aside from the exploding engine and VVT ruining the 2nd engine, its been ok.
In summary, it makes a really awesome Flintstones mobile, but not a very good ICE powered vehicle.
I bought the car with 80K miles on it and only choose the vehicle because it was impeccably maintained and a company car. The only issue I have had so far was the lining at the door seal came off and I had to use epoxy to get it back on...no problems since. As far as I can tell, as a daily driver it is rock solid as long as the periodic maintenance is followed.
That said, however, I am going to be looking for a low mileage E92 soon just to make sure that I don't get hit with a bunch of gremlins with the E46 after it rolls over 100k mi.
Spike :pirate
