proactive maintenance. I have replaced the VC gaskets and the VANOS solenoid seals then I did my timing chain guides. Changed all seals and gaskets. No leaks.
1999 540it - Schwartz II/Sand Beige, style 5 rims, Conti DWS 235/45 tires, Billy HD/Sports, Stoptech S/S BL, F1 Pinacle 35% tint, Zionsville Cooling kit
1998 318ti Cali Sport - Schwartz II/Schwartz Anthratz, staggered style 23
1997 318ti Sport - Schwartz II/Schwartz Anthratz, staggered style 68 ,
1995 318ti Active - Alpineweib III/Schwartz, squared style 32
1994 325i - Bostongrau/Tan, Billy Sports, H&R springs
1991 318ic - Schwarz/Anthratz Stoff, Bilstien HD, Z4 3.0 SS, Magnaflow, S/S Stress bar, x-brace, M20 FW, Elipsoid/HID, K&N
BMWCCA# 160411
1995 318ti Sport Schwartz II/Schwartz Anthratz - Sold
1985 635CSI - Schwartz\Sand - Sold
1984 533i "Max" - Schwarz/Schwarz, - Sold
1984 318i - Champagne/Tan, Stock - Sold
this is fantastic thank you. My alternator recently failed on me and I plan on doing this soon. Quick question for you.
my indi mechanic friend said my 98 540i uses the water cooled alternator. He changed my radiator for me last month. I called O'reily auto and their computer has it as air cool alternator. Is it possible my car is late 1998 model or something putting it with 1999up categories?
love the info thanks everyone
update.
I can clearly see it's the air alternator. He must have been confused. The air alt is much cheaper so this is a good thing.
I just installed a new alternator and a new battery. I plan on a long road trip and I call myself being proactive. I got a new battery (mine was on its way out) and a new alternator because my car is at 120K miles so I didn't want the alternator failing on me on the road. I tried an MPA alternator. It ran for less then 10 minutes then failed. I just tried a Pep Boys Alternator today. It ran 15 minutes then failed. Do I really need to get a Bosh unit at this point? Me trying to be proactive has me down a car for the past few days now. About to bite the bullet and get a Bosh from FCPEuro were I see it the cheapest.
Just finished buttoning up the car from this job. Turned the key and it ran for 5 seconds and shut down - not enough juice. Jumped it off the wife's Odyssey and all through high idle it ran fine, but my nav screen was flashing. When it came out of high idle, it stumbled a bit and the coolant needle suddenly slammed from cold to the hot peg. I'm assuming that the battery still needs more charge as it's below 12.6 with the car off. Assuming also that since the cooling system needs bleeding and topping off, that's why the needle slammed over. I'm trickle-charging the car now, so I can run it and burp it. Can't do test 9 because my display is pixelated so I'm going on these hunches. No coolant leaks, pulley wobbles, or bad noises - she just purrs nicely. I'll update once it's done and running. Meantime, anyone with any feedback to confirm or contradict my assumptions would be great to hear from.
Failure at 197k+, which finally forced me to address this issue.
1. The pop rivets are used in quite a few places so get used to them.
2. The expansion take does NOT need to be removed. It just takes a little finessing and you can angle it out the driver's side. Just remember to disconnect the plastic shield around the bleed screw and the small hose at the inlet nipple. Also remember to disconnect the wire to the expansion tank sensor as you remove the fan shroud.
3. Yup...most of us are also aware of this. I noticed the OP's were already removed. You are correct that the tensioner pulley overhangs the alt so yes, it must be freed.
Special thanks to BlackBMW for having the balls to tackle this daunting task and document it. Also thanks for posting all the additional info guys, it really does give one the confidence to march on and attack the failure. This task took me about two hours and it was my first attempt. On first start, the batt light was non-existent and there wasn't a single squeal from the belt so I'm not sure what you guys did but maybe the tensioner wasn't fully torqued? I now have a coolant warning but I KNOW that it is full so I prolly have to burp my baby now.
'00 540iA Sport w/235k+ Original TCG's, Vanos and transmission.*Trans failure at 244k+...FS Now
Have the light blinking on my dash but my test 9 has a better voltage than yours after the change, battery checked out fine aswell as alt from Advanced auto test.
Should i ride it until it leaves me stranded?
02 540i Kalahari Beige Metallic
20" Maya Wheels
I wanted to post a Thank You to BlackBMW for posting this excellent DIY. "Thank You!"
Had the red battery light illuminate recently and, with no particular mechanical skills, but a decent set of tools, was able to tackle this job on my car this past weekend. Start to finish was about 3 hours. Car started right up, red battery light off and everything tests out perfectly.
Saved me the (reasonable) $220 in labor quoted by my indy shop. They'd also quoted me an outrageous $825 for a remanufactured Bosch water cooled alternator which I found online for about $370 after core deposit refund.
More importantly.....this DIY repair gave me the satisfaction of having successfully tackled this myself!
Good Stuff! So, Thanks Again!
BMWCCA# 160411
Thanks OP. Just completed my water cooled Alt replacement on my 99 540iT (128k mi). Not a bad job. I went with a Bosch reman 150v from FCP.
A couple suggestions. If you don't have the fan removal tools, buy them now. It makes fan removal take seconds.
I didn't have to remove the fan shroud. It's a tight fit but you can wiggle the alternator past it.
99 540iT - Merlot Truckster (TCG done 134k, might sell...)
00 528i/5 - Grüen Arrow (sold)
93 740i - Grün Hornet (sold)
00 740iL (R.I.P.)
Thanks for this DIY. I particularly liked you mentioning how the M50 bolt might be tight, and some tricks to help get it off. What is the "Why" behind putting grease on the o-ring?
