Ok basically the next parts I need help as I plan on doing this swap sooner than later (and I'd basically like to keep anything I can and replace as little as possible given I am on a very tight budget)
- driveshaft (and we're talking both sedans here) ... length for a 318i is 1591mm, for the 325i it's 1512 ... what gives? the m50 320i available in europe uses the same driveshaft as the 318i ... can I keep the existing driveshaft and just mount the engine that much further forward somehow (given that 320 and 325 use the same engine mount brackets)?
- Oil pan; can a e34 pan work (lots of junked 525s around here vs not so many 325s)?
- clutch and flywheel
... please tell me about any other parts that have to be changed;
I think it would be more productive to swap an m52 its only a little more expensive anyway.
things that are probably different are..
engine mounts
wiring harness
heatercore hookups
Maybe tranny mounts
driveshaft as you know
exhaust hangers
throttle cables
cruise control cables/unit
ecu obviously
I can find out about the e36 vs e34 oil pan as i have an m50 e36 and m50 e34.
1994 325is - s50/zf trans/TRM chip/s52 headers/21.5lb injctrs/3.5 HFM/M3 brakes/billy sports/hr springs/reinforced subframe/camber plates/adj ctrl arms/3.15 LSD
2004 Volvo s40 T5 - Daily
2000 GMC k2500 5.7 - 33's/frame off resto'd
1989 Chevrolet k2500 5.7 rclb
