Alright I did some searching, and they said to pull the back seats and, get a hammer, and screwdriver and replace the unit....I'm assuming this if for a 2 door though. How do I take off the rear seats to get access to the pump? Anything else that I should know about changing the pump so I dont burn get a spark and burn to hell and replace it correctly? I heard i should replace the gasket as well while im at it.
-Rich
M3 Sedan Club President #21
To remove the rear seat, grab the front edge of it and pull up. The rear seat is only held in by two metal tangs.
Disconnect your battery before starting and keep the place well ventilated. If your garage has a water heater in it, turn off the gas supply.
E36 DIYs: Air Pump | Vent Gauge | E46 Armrest | SmarTire TPMS
E46 DIYs: Hella TPMS | Aftermarket Horns | Window Regulator Notes | Trunk Wire Harness | Trunk 12V Socket
pull off from the front
philips screw driver take off the metal plate
take of the fuel hoses and unplug the sensor
take 2 large screw drivers make an X with it and twist off the top rubber part
and you are in just pull up and the fuel pump will come out.
did you get your motor man
EUROPROJEKTZ-WORLD.COM
www.KCollection.org
Sorry for the slow replies, have no internet at home. Alright, changed the fuel pump, I need to take off the back rests also though cuz I need to change something there, how do you do that? hehehe. And yes, the engine is being shipped, I need to find a couple of guys and a pick up truck though to figure out how to pick it up from the shipping company station.
s
is your seat the fold down or ski hole?
www.KCollection.org
Niether, its old skool 92...I didn't know if there is a so called "ski hole....
