I'm swapping out my cover today to replace gaskets. I noticed I only have one ground strap at the rearmost cylinder but was expecting two (one at 6 and one at 3). Am I missing one?
I called the dealership parts dept and they said I should only have one. Realoem isn't very clear on it either but I wanted to pick one up if necessary.
if i remember right one on each side of the motor one in front and one in back. but i may be thinking of the obd2 cars.
1998 estroil blue m3 sedan m50 intake manifold, turner adjustable control arms kw2 coilovers, turner fcab andeismen ann race exhaust and various other mods (sold)
1995 BMW M3 Avus Blau with Dove Interior. Active autowerke 8psi supercharger Eibach prokit, Hartge 19" Classics, 8000k HID's for the Low Beams and for the Fogs as well, JTD Underpanel Block is bored .25 over with Ross Racing pistons, Turner Motorsport Chip 24# injectors, Euro HFM, Dinan Throttle Body, Fan Delete Mod, Cold Air intake, UUC Oil Filter Lid, UUC Motor Mounts, Race Tranny mounts and Rear Subframe Bushings,UUC Short Shifter, Powerflex, RTAB bushings and FCAB. Cyberdyne Digital gauges for Water Temp, Oil Temp and Pressure and Borla Exhaust. Ac Schnitzer Pedals, Shift Knob and E-brake handle
Mine has one up front.
Walk a mile in my shoes and you are a mile away in someone else's shoes.
Goodridge*UUC sways* Black TME's and mounts( switched from Red)* x-brace*brembo rotors*Zimmerman rear*Pagid*Riken Raptors* Roja Formula 7's (Bronze)* Stromung*Powdercoated AA DSB* OMP strut bar*GC RSM's* M3 alum/leather knob*JTD underpanel *Traffic PRO (sold) *Black hella Ellipsoids w/celis rings * ACS Pedals*ACS handbrake*RE Octane SSK*Wheelskins Eurotones S/ Wheel Cover( tossed-replaced with new one)* Totally Covers Front seat velour covers with custom styling *Rieger roof spoiler-lost it on fwy Stock A/B*URI CP (ditched years ago)*540 HFM (sold) Stock HFM (BeckArnley)*FMS 24 lb inj*Alum rad and some other stuff*Konis w/adj rr's*Vogtland springs ** Passport 8500(sold)*Passpprt 7500 (sold V1-1.8 with POP) No detectors at all.
Coming...nada
BMWCCA-303681
Thought so, thanks I'll go pick another one up.
Everything else is straightfoward except for some of those nasty valve cover flakes got into the cam tray area. Ugh, have been sitting in the garage picking them out and cleaning it best I can.
Coming...nada
BMWCCA-303681
Oh ok, I was confused when you said you had one up front, I thought you meant in addition to the one at the back (thats where my current one is).
I just replaced my valve cover gaskets two nights ago.... I had ground straps on the front and rear, and then a ground from the wiring harness to the third cylinder.
Pics of the finished product for anyone who cares.
When I first got my 95 M I wondered why there was a big difference in grounding? I guess if you have another one it wouldn't hurt to have another strap to ensure grounding?
----Dave----
Probably doesn't make a big difference. The only ground I think I'll replace is the main one from the block to the body on the exhaust side, the housing on mine is all cracked and flaking.
I'm positive there's only one for the s50. Checked my car and a friend's car.
My question is, does it matter where the strap is located? A buddy of mine did the valve cover swap and now my ground strap is on cylinder one...and the motor isn't starting. Getting "Ignition Coil #6" code - 1276 when doing the obd-I test
