Hi Guys,
Does anyone know where to find the pinout for all the connectors going to the DME / ECU? I checked e38.org without any luck.
I'm going through the issue where coolant crawls up the thermostat sensor wire all the way to the DME and I will be cleaning up the pool of coolant this afternoon. http://forums.bimmerforums.com/forum...php?p=19245217
I can't tell which hole on the connector that the coolant is coming from since there are so many pins on the DME connector and the pool of coolant was high enough to soak all of the pins. On a side note, if you have a coolant leak that you can't find check your DME connectors! Thanks in advance!
ettore38
the bmw wds has the pinout. tho i dont have it on this machine.
Hi,
Thanks for the info! I searched for BMW e38 WDS on google and found this website:
http://spaghetticoder.org/bmw/wds/e38new/
ettore38
I know the post was from 2007, but spaghetticoder is still there. However, I can't get it to go anywhere but ads. Am I missing something?
That WDS has been gone for years. Here is the pin out for the 2000 model.
A6000 Engine control module (DME)
Connector overview
Pin assignments at connector X60001
Number X-pin, color Description X60001 9-pin, black Connector Engine control module (DME) Module 1 X60002 24-pin, black Connector Engine control module (DME) Module 2 X60003 52-pin, black Connector Engine control module (DME) Module 3 X60004 40-pin, black Connector Engine control module (DME) Module 4 X60005 9-pin, black Connector Engine control module (DME) Module 5
Pin assignments at connector X60002
Pin Type Description / Signal type Connection /
Measuring notes1 Not used 2 Not used 3 Not used 4 M Ground Ground connector X6460 5 M Ground Ground connector X6460 6 M Ground Ground connector X6460 7 E Terminal 30 voltage supply Fuse F4 8 E Terminal 87 Fuse F1 9 Not used
Pin assignments at connector X60003
Measuring notes1 M Heated oxygen sensor ground Heated oxygen sensor II behind catalytic converter 2 Not used 3 E/A CAN-bus low AGS transmission control module 4 E/A CAN-bus high AGS transmission control module 5 Not used 6 E/A Diagnosis signal TXD Splice, TXD X6866 7 M Heated oxygen sensor ground Heated oxygen sensor I behind catalytic converter 8 M Heated oxygen sensor ground Heated oxygen sensor II behind catalytic converter 9 M Heated oxygen sensor ground Heated oxygen sensor I in front of catalytic converter 10 M Heated oxygen sensor ground Heated oxygen sensor II in front of catalytic converter 11 M Heated oxygen sensor ground Heated oxygen sensor I behind catalytic converter 12 Not used 13 M Heated oxygen sensor ground Heated oxygen sensor II in front of catalytic converter 14 E Heated oxygen sensor signal Heated oxygen sensor II behind catalytic converter 15 E Heated oxygen sensor signal Heated oxygen sensor I in front of catalytic converter 16 E Heated oxygen sensor signal Heated oxygen sensor II in front of catalytic converter 17 E Heated oxygen sensor signal Heated oxygen sensor I behind catalytic converter 18 Not used 19 M Heated oxygen sensor ground Heated oxygen sensor I in front of catalytic converter 20 Not used 21 Not used 22 Not used 23 A Terminal 85 control Engine control module relay 24 Not used
Pin assignments at connector X60004
Measuring notes1 A Injection signal Cyl. 2 fuel injection valve 2 A Injection signal Cyl. 3 fuel injection valve 3 A Signal Evaporative emission valve Evaporative emission valve 4 A Temperature signal, E-box fan E-Box fan 5 M Ground for electronic components Ground point left-hand drive Ground connector X6460 6 Not used 7 A Voltage supply for hot-film mass air flow sensor (LMM2) Hot-film mass air flow sensor 8 E Signal Electric throttle actuator Electric throttle actuator 9 M Hot-film mass air flow sensor ground Hot-film mass air flow sensor 10 A Multimeter Electric throttle actuator Electric throttle actuator 11 Not used 12 E Voltage signal, terminal 30h Starter 13 E Generator D+ (terminal 61) signal Generator 14 A Injection signal Cyl. 7 fuel injection valve 15 A Injection signal Cyl. 6 fuel injection valve 16 E Signal, VANOS valve VANOS valve, cylinders 5-8 17 Not used 18 Not used 19 E Camshaft position sensor signal Hall-effect sensor, camshaft 2 20 E Camshaft position sensor signal Hall-effect sensor, camshaft 1 21 M Ground Dual temperature sensor 22 E Signal, coolant temperature Dual temperature sensor 23 E Hot-film mass air flow sensor signal Hot-film mass air flow sensor 24 E Signal Electric throttle actuator Electric throttle actuator 25 E Ground Electric throttle actuator Electric throttle actuator 26 Not used 27 A Injection signal Cyl. 8 fuel injection valve 28 A Injection signal Cyl. 5 fuel injection valve 29 E Signal, VANOS valve VANOS valve, cylinders 1-4 30 Not used 31 A Signal, cooling characteristic map Characteristic map, cooling 32 E Crankshaft position sensor signal Crankshaft position/RPM sensor 33 Not used 34 E Hot-film mass air flow sensor signal Hot-film mass air flow sensor 35 M Shield, knock sensor Knock sensor 36 E Sensor 2 signal Knock sensor 37 E Signal, sensor 4 Knock sensor 38 M Shield, knock sensor Knock sensor 39 E Oil level - thermal Oil level sensor 40 A Injection signal Cyl. 4 fuel injection valve 41 A Injection signal Cyl. 1 fuel injection valve 42 E Signal Electric throttle actuator Electric throttle actuator 43 E Signal Electric throttle actuator Electric throttle actuator 44 Not used 45 M Ground Shield, crankshaft sensor 46 E Crankshaft position sensor signal Crankshaft position/RPM sensor 47 Not used 48 M Shield, knock sensor Knock sensor 49 E Sensor 1 signal Knock sensor 50 E Sensor 3 signal Knock sensor 51 M Shield, knock sensor Knock sensor 52 E Signal, secondary air injection pump valve Secondary air injection pump valve
Pin assignments at connector X60005
Measuring notes1 A Charge indicator signal (terminal 61) Instrument cluster 2 A Voltage signal, terminal 30h Integrated instrument cluster control module (IKE) 3 A Activation, secondary air pump relay Secondary air injection pump relay 4 E Signal Electric fan Electric fan 5 Not used 6 E Start signal terminal 50 Ignition switch 7 M Ground Pedal position sensor Pedal position sensor 8 E Signal Pedal position sensor Pedal position sensor 9 A Power Pedal position sensor Pedal position sensor 10 A Activation, fuel pump relay (EKP) Fuel pump relay 11 A Oil pressure indicator Instrument cluster 12 M Ground Pedal position sensor Pedal position sensor 13 E Signal Pedal position sensor Pedal position sensor 14 A Power Pedal position sensor Pedal position sensor 15 Not used 16 Not used 17 A Engine speed signal output (TD) Data link connector 18 Not used 19 E Signal Back-up light Integrated instrument cluster control module (IKE) 20 Not used 21 A Signal Oil level sensor Light module 22 E RH rear engine speed signal ABS/DSC control module 23 E Signal Clutch pedal position switch Clutch pedal position switch 24 E Brake light switch signal Brake light switch 25 Not used 26 E Voltage supply, terminal 15 Fuse F24 27 E Data link MFL Coil spring 28 E Brake light test signal Brake light switch 29 E A/C compressor signal Heating and A/C control module 30 E Signal, leak diagnosis pump Leakage diagnosis pump 31 Not used 32 A Diagnosis signal TXD Data link connector 33 E/A Communication link (EWS) Electronic drive-away protection control unit (EWS) 34 E Signal, leak diagnosis pump Leakage diagnosis pump 35 Not used 36 E/A CAN-bus high CAN link 37 E/A CAN-bus low CAN link 38 M Ground Coolant outlet temperature sensor 39 E Signal Coolant outlet temperature sensor 40 A Start signal Starter relay
Measuring notes1 A Terminal 1 signal Cyl. 7 ignition coil 2 A Terminal 1 signal Cyl. 8 ignition coil 3 A Terminal 1 signal Cyl. 2 ignition coil 4 A Terminal 1 signal Cyl. 3 ignition coil 5 M Ground Ground point 6 A Terminal 1 signal Cyl. 1 ignition coil 7 A Terminal 1 signal Cyl. 4 ignition coil 8 A Terminal 1 signal Cyl. 5 ignition coil 9 A Terminal 1 signal Cyl. 6 ignition coil
Ditto the Mayor..."spaghetti" has been gone for years...you need to update your favorites/bookmarks. There's a new TIS (in town)
Here's direct link to the new TIS: https://www.newtis.info/tisv2/a/en/
