Two torx screws hold the cluster in the dash. Remove them and the light switch - one screw from below.
Carefully pry the tabs the srcews were in with flat blade screw driver while pushing from the back side, accessed through light switch opening. The connectors attached to th eback are similar to OBC connectors, so have a look at them to figure out how to release them.
With four-spoke wheel cluster should come out by rotating wheel an dcluster to the right. With three spoke wheel, I believe wheel has to come off.
Lots of DIY out there.....
www.bmwpugetsound.com/vbb/showthread.php?t=27343
