got two error codes over the weekend...
210 / P0330 knock sensor
211 / P0325 knock sensor
prelude to this was car cutting out briefly on a prticularly hot day & iddling crappy - for a bit, before it calmed down by itself.
pulled the plugs, & they were orange / brown in color - LEAN.
can anyone tell me if these codes a reaction to an actual ping sensed (timing retarded by the ecu / mixture leaned out) OR a faulty set of knock sensors (causing the same)?
not sure what is going on... HELP.
p.s. - unplugged the battery over night - reset the program - car runs fine for now.
If that code returns, the knock sensors are bad.
Jim Levie, Huntsville, AL
