Page 5 of 14 FirstFirst 1234567891011121314 LastLast
Results 101 to 125 of 337
Thread: ADS - INPA interface
  1. #101
    Oct 2007
    milwaukee, wi, usa
    750 IL 1990
    I finally may have a source for female 20 pin connectors and am trying to convince a company to make me Female 20 ADS to 16 pin Male OBD adapters.
    These would allow my compact interface to connect to the OBD port, if neccesary. I am hoping to get these so I can offer them for 25 or 30 bucks.
    what kind of demand is out there for such an adapter?? I probably have to buy in lots of 50 or 100 pieces.
  2. #102
    Nov 2009
    hk
    2000 Z3 3.0i
    rv8flyboy
    I will be the first one to buy the Female 20 ADS to 16 pin Male OBD adapter!!!
    please keep us updated!!
    i think the adapter is really a must to make the your cable more complete
    now the cable only works with older cars with the 20pin socket, which is under-use of the cable
    i am really looking forward to it, and I believe everyone who have bought your cable would agree.
    is there an approximate time that the adapter will be a/v?
  3. #103
    Nov 2009
    Joinville, Santa Catarina, Brasil
    BMW 540i
    Finally i bought from ebay an ADS & OBD interface, but now i need an RS232 extension cable to connect the interface in the computer. Anyone can tell me what is the correct pinage?
  4. #104
    Oct 2007
    milwaukee, wi, usa
    750 IL 1990
    my supplier withdrew his offer, now says he cannot find the female adapter
    anybody have an alternate source for the 20 pin connector under the hood??
  5. #105
    Nov 2009
    hk
    2000 Z3 3.0i
    actually are there lots of "20 pin connector under the hood" a/v in junkyard?
    i guess no one would buy this part from old cars, so there should be tons of them?
  6. #106
    Oct 2007
    milwaukee, wi, usa
    750 IL 1990
    yes, that is where i got mine from, hence the write-up
    problem is, there may be 1000'nds but they are spread out over a large country
  7. #107
    Oct 2007
    milwaukee, wi, usa
    750 IL 1990
    I have ordered some 20 pin female connectors straight from BMW, I will mate those with the OBD connectors I have and see how it looks, I will post some pics here when parts arrive.
    I am also approaching some oversees mfgs for supplying molded OBD connectors to mate with the BMW connectors
    The weak point will be the fact that the BMW connector will have a rubber booth rather than a hard shell with strain relieve.
    I do agree with Betaruce that it would be a boon to have this adapter.
  8. #108
    Nov 2009
    hk
    2000 Z3 3.0i
    good news rv8flyboy!
    BMW do provide that 20 pin female connectors? in the shape+wires like what we obtain in the junkyard? and how much do they cost?
    and what is the difference of the "molded OBD connectors" compared to the 16pin male socket shown in your tutorial?
    I believe your interface receive good response as shown in this thread and the positive review written by someone, just that sometimes this part of the forum may not always have so much visit therefore causing the delayed reply
  9. #109
    Oct 2007
    milwaukee, wi, usa
    750 IL 1990
    And i have just been informed that BMW has a problem shipping/providing the connectors till next year...... january or february. I guess if they even vaguely look like they could work I better by a bunch of them
    the difference in the OBD connectors is that in the posting example you (or me) have to solder the wires to the OBD connector. In the molded application that is taken care off which makes for a much more durable connector as the strain relief will be integral to the wire coming out of the connector. Also, buying a separate OBD connector, separate wiring, spent the time assembling, etc costs way more than having an outfit make a short run molding connectors and wires.
    my thought was to crimp terminals onto the wire ends and insert them in the 20 pin BMW diagnostics shell. That would save a lot of time.
  10. #110
    DUDMD's Avatar
    DUDMD is offline BMW Maniac Supporting Vendor
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by rv8flyboy View Post
    I have been asked about an OBD adapter for my ADS-OBD interface.
    here is a relatively cheap way to make your own adapter.
    Ingredients:
    1: 20 pin diagnostics socket from the junkyard
    2: OBD connector such as http://cgi.ebay.com/ebaymotors/OBD-II-2-OBD2-OBDII-EOBD-J1962-Male-CONNECTOR-DLC-PLUG-/370227445669?pt=Motors_Automotive_Tools&hash=item5 633467fa5
    or
    http://cgi.ebay.com/ebaymotors/New-Universal-OBD2-16-Pin-Connector-OBDII-EOBD-OBD-/130483994127?pt=Motors_Automotive_Tools&hash=item1 e6173be0f
    3:Some protection for the wiring. I used some 'snake skin' type covering from an old computer power supply.
    Remove the unneccesary wiring from the diagnostics socket. Slide the 'Snake skin' over the wires.
    solder to the OBD plug. Presto, you have made your own ADS to OBD adapter.
    (as opposed to the OBD-female to ADS-male adapter one can buy on eBay etc.)
    pin-out:
    ADS ---OBD
    7 ---- Not Connected on OBD
    20 --- 7
    17 ----8
    15 ----15
    16 ----1
    19 --- 4+5
    14 ----16
    My diagnostics socket did not have pin 17. However, my ADS-OBD interface has pin 17 and 20 already connected. I just jumpered pin 7 and 8 on the OBD connector.
    I just built one of these last week and it didn't work, until I soldered the ADS pin 15 to OBD pin 9. This was tested on an 2002 X5 and worked perfectly after that. Pin 15 to pin 15 did not even light up any of the lights on your interface.
    Performance Tuning and EWS Delete for MSS52/MSS54/MSS54HP/MS41/MS42/MS43/ME7.2/M5.2
    Virgnize DME service available to unlock DME to sync to another vehicle on EWS3 vehicles 98+. M5.2.1, M7.2, MS42, MS43, MS45, ME9.2 and more.
    Easiest way to contact me is to send me a message on my facebook page "DUDMD Tuning"
  11. #111
    Nov 2009
    hk
    2000 Z3 3.0i
    really looking forward to your adapter
    i have thought of making one myself but i am not familiar with electronics
    so i would rather buy a tested and functional adapter from you
    so btw is there any explanation to DUDMD's problem?
  12. #112
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by betaruce View Post
    It might have been the ground wire connection bad at the OBD2 plug, since when I was relocating pin 15 to pin 9, I redid the ground. It was soldered it on there pretty good before I resoldered it.
  13. #113
    Nov 2009
    hk
    2000 Z3 3.0i
    So u mean it is the ground wire problem instead of the wrong site of pin soldering?
  14. #114
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Might have been, even I will relocate pin 9 back to 15 and see if it still works.
  15. #115
    Oct 2007
    milwaukee, wi, usa
    750 IL 1990
    A quick search failed to bring up the function of Pin 9 on the OBD connector
    All info points to Pin 15 on the ADS side to coincide with Pin 15 on the OBD side.
    There are 2 pins that are grounded on the OBD side.
    I have no explanation as to why moving to pin 9 made it work, unless indeed the ground was flaky, the fact that NO lights lit up may bolster the grounding explanation as at least the power led should have illuminated as this has nothing to do with pin 15 on either connector.
    David Mc outlines grounding problems and pin-out here too:http://forums.bimmerforums.com/forum...7&postcount=33
  16. #116
    Apr 2009
    Canada
    BMW X5
    rv8flyboy, what is the difference between your interface which I am tempted to buy and the carsoft one that I have? I am using it on an x5 2000 (has both ADS and OBD) and 5 series 2003. thanks
  17. #117
    Dec 2007
    Queensland, Australia
    E70 3.0sd E21 323i
    These interfaces are designed specifically to work with INPA/DIS/PROGMAN, I own several different types of ADS interface and these are top of the range. You will feel the difference in quality as soon as you have one in your hands and I have found them to perform flawlessly. You can read my review here:- http://www.repairdynamics.com/Rv8flyboy_Review.pdf
  18. #118
    IcemanBHE's Avatar
    IcemanBHE is offline ¿pǝpɹɐʇǝɹ noʎ ǝɹɐ
    Wichita,KS/FortCollins,CO
    (4x7)+8=36
    I would think that endorsement from David and Myself would be all you guys need.
    But Im nobody special.
    (but I do buy 2-3 a month)
  19. #119
    Nov 2009
    hk
    2000 Z3 3.0i
    and i definitely think adding the 20pin female to 16pin male adapter would make it perfect by allowing it to diagnosing wider range of cars
  20. #120
    Apr 2009
    Canada
    BMW X5
    OK, you convinced me.
  21. #121
    Nov 2009
    Upper Saddle River, NJ
    1987 RX7 2+2
    I've got pin 9 on the OBD 2 connector as TD signal (engine RPM) which should be pin 1 on ADS
    Fast Track '09
    NJ S.T.E.P
    . 35 - the cake is a lie
    What do you call a BMW on a flatbed?
    -Maintenance interval.
    Zoom - Zoom
    Forever
  22. #122
    Apr 2009
    Canada
    BMW X5
    OK, just to clarify.
    For ADS (20 pin connector under the hood), this is the best interface but for OBD it's still work in progress.
    Am I better off with the VAG KKL for OBD or the 20 pin female adapter to OBD will do the job?
  23. #123
    Nov 2009
    hk
    2000 Z3 3.0i
    Quote Originally Posted by fmugur View Post
    you may say so
    the 20 pin female to OBD adapter may not be available till Jan/Feb according to previous post by rv8flyboy (maybe rv8flyboy can also update us on that?)
    but you can still use his interface on car with ADS
    of coz it depends on which socket your car have
    for my car, i have both 20pin and 16pin socket
    i can use his interface with the 20pin under the bonnet BUT in OBD mode (not ADS mode)
    obviously
    the new supplement 20 pin female to OBD adapter would make the whole thing perfect
  24. #124
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    you may say so
    obviously
    Most cars up to 2000 have a 20 pin connector under the hood, the obd2 converter works on 2000 and up, since they stopped the 20 pin diagnostic connector around that time.
  25. #125
    Nov 2009
    hk
    2000 Z3 3.0i
    My 2000 z3 got both, obviously becoz its the transition period.
    Also it use obd protocol even i connect with the 20pin socket (and it has the 15pin installed which theoretically it should be ads mode)
