Page 14 of 14 FirstFirst ... 4567891011121314
Results 326 to 337 of 337
Thread: ADS - INPA interface
  1. #326
    Dec 2014
    Stuttgart, Germany
    One Too Many
    Are these still for sale? Anybody have one they want to part with?
    "So we've come to the conclusion that BMW just has parts laying around they decide to throw on cars for no reason."
    Interest on a Very Budget Supercharger Build??
  2. #327
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    Email or PM the OP, im sure they are still available. Im never letting mine go
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
  3. #328
    Oct 2007
    San Jose, CA
    '66 DVC '95 325ic
    Quote Originally Posted by kahlilj View Post
    I think there is a setting done with one of the INPA files that allows you to switch between the two modes: ADS or OBD.
    I know this is old, but anyone coming along later and doesn't want to read through hundreds of posts, the file is ediabas.ini in the bin directory. change OBD to ADS.
  4. #329
    Mar 2013
    Green Bay, WI
    1992 750il / 1991 560 SE
    Old thread, I know. But I bought the cable kit and assembled it. Great directions, lot of fun. But the software side... not so much. My laptop can run VMWare 6 but has no real serial. My desktop has serial, but VMWare 3 is the newest that will run (maybe 4, I forget).
    So can anyone recommend a laptop that can run VMWare 6 or newer and has a physical serial port? If not, then a desktop of sufficient vintage will be fine. As I have a new desktop, whatever machine I get will be used for my E32 (750iL) only.
    ______________________________
    1992 750iL
  5. #330
    May 2015
    Atlanta, GA
    540i6 S2M5 M2C 135 S52ti
    I can offer exactly 0% help on this... However, I do LOVE the sound of an older desktop set a top A garage work bench running wires to an E32 750il, that's a beautiful thing.., GL
    I would check newegg.com for used desktops or is CDW.com still around? Idk I've gotten some good windows XP comps from out there for stuff LIKE this, not exactly for cars tho
  6. #331
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by unity View Post
    Old thread, I know. But I bought the cable kit and assembled it. Great directions, lot of fun. But the software side... not so much. My laptop can run VMWare 6 but has no real serial. My desktop has serial, but VMWare 3 is the newest that will run (maybe 4, I forget). So can anyone recommend a laptop that can run VMWare 6 or newer and has a physical serial port? If not, then a desktop of sufficient vintage will be fine. As I have a new desktop, whatever machine I get will be used for my E32 (750iL) only.
    You can run ifhsvr on the desktop with real serial + ADS interface and DIS on the laptop. DIS talks to ifhsvr over the network and the tutorials assume you will run them on the same physical machine, but that is not necessary.
    Do you really need DIS though? I find INPA quicker/easier for many tasks.
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
  7. #332
    Mar 2013
    Green Bay, WI
    Well I really dont know all the terms yet. DIS, INPA, etc. I just read a few times that for the E32, DIS was the best method and worked well. The networking idea is interesting if not cumbersome. If I get really bored I may try it.
    1992 750iL
  8. #333
    Mar 2013
    Green Bay, WI
    I found the Toshiba A10,A11 series has a physical serial port. So I grabbed an A11 for $75. It should do the trick.
    1992 750iL
  9. #334
    The Netherlands
    DE-spec E36 328i/M3 cab
    Anyone have or know one for sale?
    Contacted Gert, but he is out of housings and has been for a long time.
    IG:
  10. #335
    Feb 2009
    Arizona
    1998 e36
    Quote Originally Posted by MParallel View Post
    I want to know the same.
  11. #336
    Mar 2011
    Tampa Florida
    840 ci
    I've recently downloaded and install the full INPA/EDIABAS from https://mega.nz/file/WwUiFTrY#wFt8Zx...pu3j2ErYzbOqeo. I have a OBD1 which requires the use of a serial port. The software appears to have a selection during the installation that allows you to choose OBD or ADS. Once I completed the install and launched the application and tried E31->Engine->M60, I'm not about to read the engine information and getting the error "AppCheckJobStatus: Error #95 SYS-0005: OBJECT NOT FOUND API job error or no such result! Continue script processing?". However with this version I am able to read the transmission, chassis, and body information. I have the Dinan chip installed, should will this matter with my inability to read the ecu data? I fell like I'm close to being able to read the engine information but not there yet. Is there a parameter I forgot to set?
  12. #337
    Dec 2020
    Montreal, QC
    98 E36 328is 5spd manual
    I just shot him an email, I hope I can get my hands on one of these cables.
