Results 1 to 14 of 14
Thread: E36 3.38 4 clutch LSD diff excellent
    Dec 2007
    SF bay area
    1998 M3 / 2000 S2000
    Great shape e36m3 3.38 LSD.
    This has been reconfigured from stock 25% locking 2 clutch to 4 clutch 60% locking per oem design- it's lock up is much more aggressive than stock- ideal for Motorsports and highpower m car use.
    Stock 2 clutch setup is weaksauce, same design as a 325 e30!
    Complete diff with 85k miles, great seals and bearings- not a noise or leak at all. Locals to sf bay are welcome to check it out in person-
    $700 cash picked up sf bay
    $85 shipping contiusa, you are also welcome to provide your own FedEx/ups account for discount shipping
    I have both 6 and 4 bolt flanges (4 is oem, 6 I have on shelf)
    Wanganstyle Powertrain
    http://www.wanganstyle.com/
    S54B32 E36 M3 DTA S100 Sedan Street car full swap:
    http://forums.bimmerforums.com/forum....php?t=1437471
    Dec 2007
    SF bay area
    Re: E36 3.38 4 clutch LSD diff excellent
    Center unit and gear set as pictured
    Dec 2007
    SF bay area
    Details
    Dec 2007
    SF bay area
    Rear plate- you will need to supply your own speedo sensor- it's bolted on with a 10mm
    Dec 2007
    SF bay area
    This has a 4 bolt flange, I can swap to 6 for you if desired
    Dec 2007
    SF bay area
    bump. still avail!
    Dec 2007
    SF bay area
    bump to the tops.
    Sep 2008
    Los Angeles, CA
    E36 M3 S54
    Willing to sell 6 bolt flange separate?
    Tulsa, Oklahoma
    '97 M3/4/5
    who did the work on changing the lock%?
    you wouldn't need a 3.91LSD would you?
    been looking for this mod for awhile...just never jumped...
    Dec 2007
    SF bay area
    Quote Originally Posted by tokbandit View Post
    I wrote instructions on how to do this in the e36m forum
    - if you look for rebuild diy lsd, you will find it
    you basically need: a LSD, a gear ratio you like, a bunch of clutches and various other internal diff parts, the proper shims to make the gears fit properly in the case, a dial indicator to check backlash, a drag indicator to check preload.
    not hard, about the oldest muscle car modification since the beginning of hot rodding.
    the locking % changes from 25% to 60% when you remove 2 blank plates and exchange with 2 extra clutch plate for a total of 4 clutches. This is OEM bmw design, used in motorsports often. People use 3 clutch diffs for more street use, 4 is more aggressive for heavy duty track use, 5 is uuber aggressive and not fitted often.
    I do not have a need for 3.91 - If you were local perhaps, but shipping a diff to norcal is not needed- I have about 5-6 complete LSD casings and many gear sets (3.23, 3.38, 3.64, 4.10) here waiting for various operations- I build diff's for fun
    PM me if you are serious about buying it- I do have local interest as well. This diff is proven in great shape.
    Mar 2010
    Massachusetts
    E36 saloon blowntwofive
    you wanna build me a 3.64 4 clutch set up ??? pm me for more discusion
    Dec 2007
    SF bay area
    bumps.
    new york
    1993 bmw 325 is
    would you be able to build me a diff for and e36 or send me one of the rebuilt diffs u mentioned earlier I know this is an old thread but was wondering if you still built them.
    thanks
    Nov 2007
    NYC
    86 911, 91 XJ
    so tempting
