Originally Posted by
brc5
So I bought myself an E39 touring, and driving it home I found out it has a nasty vibration above 65mph. I did test drive it and look for this specifically, but where it was located there were no smooth roads, so I didn't feel it until I was on a bit of smooth freeway heading home.
The problem is a pronounced vibration in the car which appears briefly at about 30mph and disappears, only to reappear above 60. It's not through the steering wheel - it's definitely through the seat and you can see the passenger seat and sunvisors shaking.
After beating myself up about making such a schoolboy purchasing error for a couple of days, I started problem solving. Here's what I have done:
- wheel balance : no effect
- another wheel balance : no effect
- removed wheels off my other E39 and swapped over : no effect (other car has no vibration problem)
At this point I took it to the mechanic I use, who showed me the discs were all worn below the minimum spec. I had to get this fixed for registration purposes, so he fitted all new discs and pads around. While the car was on the hoist, we took the wheels off and ran the car up to full speed. Smooth as a rock, no vibration seen or felt through the car.
Re-fitted the wheels (still the ones off my other car) and ran it up to speed (still on hoist). Both left and right wheels visibly jumping the suspension up and down. Checked runout of rims - rims seem OK. Checked runout of tyres - a little bit of variation but not much.
Swapped other set of wheels to rear, and ran car up to speed on hoist. No jumping on right hand side, but wheel jumping a little on left hand side.
Mechanic concludes it must be wheels/tyres. I explain to him that my other car felt no such thing with those wheels - but the evidence was right there for me to see - no wheels - smooth. Wheels on- vibration.
While up on the hoist, checked all suspensions bushings and joints. Thrust arm bushings recently replaced (first thing he checked), slight wear in LHS transmission mount, but not serious. Guibo on driveshaft looks fine, didn't drop the exhaust to see uni joints - mainly because no noise and vibration is constant on road speed, and not on load (ie accelerating, coasting, vibration stays). There is some play in the rear subframe bushes, but they don't look visibly worn. I must say the wagon feels a lot more 'thrummy and drummy' than the sedan, I don't know if this is condition or just a wagon thing.
So at the moment the wheels are back on, and the vibration is still there, perhaps slightly less (it's hard to be objective about these things, as it depends on speed and road surface).
The original wheels are heavily kerb-damaged (every wheel) so his suggestion is to get the rims re-rolled, repaired, and put some new tyres on and see how this goes. He says this is the most likely reason and also the cheapest, because starting to replace driveline components is expensive.
The guy isn't an idiot and has been looking after a lot of E39's for a long time, so I'm inclined to believe him and try this route.
Any suggestions on what else to check, try? I know what a well sorted E39 is like, and it took a lot of convincing to the significant other to ditch her VW and get another BMW, so it hasn't gone over well. I'm very keen to get this one running smooth. It's a good car in every other respect.
My only guess is that the suspension is a bit worn, so is hyper-sensitive to out-of-balance wheels as it can't damp out any vibration inherent, whereas my other car might be a bit fresher and thus can isolate wheel vibration more (it has more miles, but has had a gentler life by the looks)
