Breaking the Motronic code, Redux. 404DME M60's https://www.bimmerforums.com/forum/s...x-404DME-M60-s
ECU Power Wiring Diagrams https://e30goodies.com/wp-content/up...grams-Menu.pdf
Bosch Motronic 1.1/1.3 , Basic ECU operation, Signal processing, Adaptive function, Self Diagnostic function, Limited Operating Strategy (LOS), Anti-theft protection, Automatic Stability Control (ASC), Engine Drag Torque Control, Service lights, Reference voltage, Signal shielding, Maximum speed cut-off, Deceleration fuel cut-off, CAS, Ignition, Ignition timing, Amplifier, Ignition coil, Distributor, Cylinder Identification CID, Fuel injection, Air Flow Sensor (AFS), ATS, Co pot, CTS, Throttle switch, Electronic throttle control, ISCV (2 and 3 wire type), Relays, Fuel pressure system, internal pump operation, Fuel pressure regulator, Catalytic Converter and emission control, CFSV, voltage and resitance measurements, 28 pages for download http://www.944online.com/yabbfiles/A...tronic-1_3.pdf
M-Motronic Engine Management 68 pages https://e28goodies.com/wp-content/up...nstruction.pdf
Combustion in the gasoline engine
Gasoline-engine management
Ignition
Gasoline-injection systems
M-Motronic engine management
Motronic M1.7 Catalytic converter protection function - Ignition circuit monitoring
The ignition circuit is monitored by the cylinder detection sender (pin 16) on ignition line 6 (or 12). If it detects no ignition signal on ignition line 6 (or 12) , the fuel supply to to the relevant cylinder bank is cut out by shortening the injection signal. The sender monitors the entire primary side of ignition, and cylinder 6 or 12 on the secondary side. See page 19 S70 engine manual
BMW S70 engine manual 39 pages https://www.scribd.com/doc/75202979/...ine-Manual-39p
https://en.bmw-club.cz/engine_detail.php?id=60
https://workshop-manuals.com/bmw/8_s...eral_s70_b_56/
http://www.unixnerd.co.uk/s70.html
M70 engine docs
http://bmwe32.masscom.net/sean750/M70info.pdf
http://bmwe32.masscom.net/moswald/docs/BMWv12manual.pdf
