Originally Posted by
Binjammin
I can't stress this enough: Stop posting bad info. You're flat out incorrect on this, as plenty of cars have burned with stock fuses in them. This is 100% a problem with the blower motor circuit and NOTHING to do with fuses. If fuses were so far over or under rated, we would have issues with them every time we use them, rather than having issues on one circuit. On one car. On that one generation of that car.
If you were putting a higher RATED fuse, that could cause an issue because it would never blow until the wiring on the circuit you were over fusing would become the fuse, but that's not the case in this scenario.
There aren't "thinner" aftermarket fuses. Fuses are rated for the amperage they're rated for. You can go buy a random sampling of a million fuses, and you'll find very little variance in both thickness of spades or the point they blow at.
Flat out, the issue is that the wiring is too narrow a gauge for a fan with worn brushes. The fan pulls 15 amps when new (for example) and is fused at 30 amps. If the fan were jammed the current draw would be way more than 30 amps and it would blow the fuse. However, as the brushes wear, the resistance goes up. The fuse is still rated at 30 amps, but now the current draw is 20 amps. The wiring is something like 16 gauge, run the fan for an hour or two and you'll find the wiring has melted down. The current draw was never more than the circuit was designed for, but the designers never accounted for brush wear, and the wiring does not have the capacity to shed heat.
