Hey All,
I'm looking to DIY the clutch and flywheel on my M5 sometime soon. So far I've got the pressure plate, clutch, t/o bearing, pilot bearing, and I've got a JRB LTW flywheel, UUC Evo3, and DSSR on the way.
Are there any other things I should change while I'm under there? Or is there anything else I'll be needing for the job? Never done a clutch replacement before, words of wisdom (aand part numbers!) are appreciated..
recently discussed similar recommendations on another thread, take a look:
http://forums.bimmerforums.com/forum....php?t=1420083
Determine whether they are worth changing first, you may want to consider these:
- clutch hose
- tranny mounts
- exhaust hangers
- reverse switch
- exhaut muffler and resonator (supersprint, eisenman )
- new flywheel bolts
Former ///M Driver SOLD: 1995 BMW E34 Euro M5 Touring
Rear main seal, trans input seal, Pilot bearing are most deffs
"...there’s nothing like the scream of an old straight six, a sound only comparable to a monster that eats children and rocks for breakfast and howls like a banshee when the loud-pedal is mashed." - Mike Burroughs
Shift bushings, shift selector rod seal, possibly CSB and guibo depending on condition. You'll probably need exhaust gaskets from dropping the exhaust.
For sure do the rear main seal. I think that part alone was around $30. I did mine after I bought the car last year and only have about 300 miles on it so it's still a bit touchy. My tech swapped the entire mess out in 45 minutes. It's nice to have a rack and a helper for taking off the exhaust system. Good time to do the 02 sensor if it's due too.
