- FS: Good stuff!
FS: Good stuff!
Items For Sale. Items are available right now, ready to be boxed, labeled and shipped immediately. I will ship items within 3 days of payment receipt or refund your money! If you have 2000 or more posts, I’ll ship them to you and you can send funds upon receipt. Check or MO…PM for address.
For detailed pictures of anything, send an e-mail to stu dot mchenry at gmail . com
See end of post for free stuff!
OEM Warning Triangle Kit. Complete, case has some scuffs and grease stains, "paper" piece has some scuffs also, reflector in great shape. $50....SOLD
New Trunk Tools.
New Heyco wheel lug wrench
New wheel chalk (used once, very glossy finish)
New tow hook
Nearly new BBS Design centercap tool
$45 shipped for all items.
Early model plate filler. This is an Air Press plate filler for an '84-'87 E30 (or any M3). Purchased new in the mid-80's and sat in storage since 1990. $160 shipped.
Factory offset front strut mounts. Can be used to add .5 degree of camber or reversed to remove .5 degree of camber. Bearings in good shape, mileage is ~40k. These run $360 a set new, asking $75 shipped.
Hawk Blue 318/325 E30 front fitment. Missing 1 of the 4 springs. Used one weekend, have about 75% life left. Excellent track pad with a high temperature range and good pedal modulation. $45 shipped.
Hawk HPS 318/325 E30 front fitment. About 50% life left. Great street pad, quiet and low dust. $30 shipped.
M42 Air Flow Meter. Pulled from working ~150,000 mile ‘91 M42. $35 shipped. Can get a pic but pretty self explanatory.
Premium Sound speaker package. Includes 2 front door tweeters. 1 clip is broken. Includes (3) rear shelf speakers (black). Missing 1 small side grill but everything else is there. $60
CDOC vented Grp. A non-power E30 mirrors. Made of extremely durable injection molded plastic, very high quality mirror mountings. No vibrations whatsoever even on a rough road with stiff suspension. Excellent for a track car, or you can run them on a road car. Unpainted black. $300 PENDING
SuperEta 154 orange label ECU. $35 shipped.
Aeromotive A1000-6 adjustable fuel pressure regulator kit (PN 13109). New in Box, includes a mounting plate, original packaging and instructions. I’m also including a gauge and some AN fittings. $145.
E30 318/325 ATE rear brake calipers, new seals 10k miles ago. $45 shipped. Pics to come.
Dove gray front floor mats. Believe they are from an E46, fit in my E30 fine. Could use a light cleaning but no major wear/stains. Camera flash exaggerates dirt/color differences. $45 shipped.
M30 engine main bearing set, .25mm oversized. Fits all M30's. New in box. Pelican sells these for $85, asking $55 shipped.
PICKUP ONLY ITEMS:
O.E.M. Black headliner kit for coupe, sunroof E30. Removed from ‘91 318is, good condition except two VERY small tears, see pictures. This is a whole roof clip cut at the top of the pillars. Includes the sunroof panel and cassette. Must be transported by a truck or van, can’t see it fitting in a car. $100 picked up, zip code 27104. Will get pics soon!!
3.91 limited-slip, small case typ 168. $250 picked up. Some surface rust, nothing serious.
FREE STUFF: (Pickup only)
-trunk carpets, door weatherstripping, window switches, hazard buttons, relays, fuses, moldings, tons of miscellaneous. If you need something small I can throw it in the box with your items. PM me if you're local and let me know what you need.
PM me if you have specific questions about anything or want a detailed picture of a certain part.
Stu
Jochmael; vhere is zee wasserpumpen!?"
Hi is the plate filler still available? thanks
I would like to purchase the super eta ecu for $35 with a side of window switches please!
You still have any of these items available?
- You may not post replies
- You may not edit your posts
Forum Rules
